Old Jan 05, 2012, 06:35 AM
Franco2fly is offline
Find More Posts by Franco2fly
AMA 84248 since 1964
Joined Jan 2011
Since I Easter Egg the Telemetry package between planes, does anyone know if I can purchase just the Pitot tube and extra silicon tubing?
My plan is to build All subsequent models with a pitot tube permanently installed in the wing leaving short stubs mid-wing, color coded (red on the straight through tube) so that I can easily attach AirSpeed sensor.
KKKKFL
Franco2fly is offline Find More Posts by Franco2fly
Old Jan 05, 2012, 07:37 AM
AndyKunz is offline
Find More Posts by AndyKunz
AndyKunz's Avatar
Illinois
Joined Sep 2001
You can check the Eagle Tree site. The pitot is theirs.
Andy
AndyKunz is offline Find More Posts by AndyKunz
Site Sponsor
Old Jan 05, 2012, 01:17 PM
aerocal is offline
Find More Posts by aerocal
Central California
Joined Dec 2006
They are available from Horizon Hobby.I picked up a couple from the website.
Part # SPMA9588
aerocal is offline Find More Posts by aerocal
Old Jan 06, 2012, 05:20 AM
Joined Jan 2011
How about a good source for tubing that has a 1/16th outer diameter? Years ago, when living in Germany, I used to use plastic Nyrod from Graupner that was white plastic outer with a solid inner rod. I wish I could find that stuff here in the US cuz it would be perfect. I think the stuff they sell at Fish (Acquarium) stores is going to be too big.
I've heard that the pneumatic lines used for retracts might work, but don't think that our local Hobby store carries the stuff in bulk. Also thought of going to the Auto Junk yard, looking under hoods for the squisher hose, but again I believe that it is too big.
Has anybody found a good resource?
KKKKFL
Old Jan 06, 2012, 07:32 AM
AndyKunz is offline
AndyKunz's Avatar
Illinois
Joined Sep 2001
I use real small fuel tubing. I buy it at the LHS. It's the size you use for a TD .051. Fish air line comes in several sizes, too.
Andy
Site Sponsor
Old Jan 06, 2012, 07:35 AM
pavcon is offline
Find More Posts by pavcon
Κύπρος, Λευκωσία, Πέρα Χωριό
Joined Jan 2010
I'm glad you are here andy.. maybe I can get an answer to my question on your message box cheers
Pavlos
pavcon is offline Find More Posts by pavcon
Old Jan 06, 2012, 09:37 AM
Harry H is offline
Find More Posts by Harry H
Harry H's Avatar
Los Angeles
Joined Oct 2010
I used the Robart air line. Works great. Got it at my LHS - they stock just about anything you can think of
Harry
Harry H is offline Find More Posts by Harry H
Old Jan 06, 2012, 12:00 PM
Joined Jan 2011
Lucky day,
I found some Robarts air line, and also a SPMA 9569 hanging on the wall. There are no instructions in the package, but I think someone said to check page 8 of the Dx8 manual. Scary thing is that I read in some reviews that it didn't work on a Saito 4 stroke. I plan on bolting it to the bottom of a Saito .40 and will be holding my breath.
Maybe I'll get a reading if I spin the motor w/o the plug using the starter motor.
KKKKFL
Old Jan 06, 2012, 09:36 PM
Joined Jan 2011
One thing to report, the plastic bracket does not fit on a Saito .40 and it was a bear to get to work. Frankly, I don't know what we did to get it to work apart from tinker with the position initially without the bracket. I had to remove the bracket completely, file it a bit then re-install with the sensor backwards in the bracket. The sensor needs to be nearly touching the backplate, at least that's what we wound up with once we got it to start working. Watch for the red light to come on when powering up. I think this is an indication that the RPM sensor likes the magnetic field it is seeing.
This sensor really needs a bracket that has more options for adjustment both in regards to different backplate spacing as well as depth and vertical variation.
KKKKFL
Old Jan 23, 2012, 05:38 AM
Joined Jan 2011
I scored another Air RPM sensor, and with a good deal of tinkering got it mounted on a Super Tigre .60 taking a picture of the final set up. I'll post it here too, so folks don't need to troll through threads.
http://www.rcuniverse.com/forum/m_10...m.htm#10922782
KKKKFL
Old Jan 23, 2012, 01:52 PM
2.4g shaun is offline
Find More Posts by 2.4g shaun
2.4g shaun's Avatar
United Kingdom, England, West York
Joined Aug 2008
Alternative sensors....
I've had the Spekky telemetry system since it was released ( I use an IPOD Touch for the readout) and I've been very pleased with it.
The only thing that's letting it down, is the cost of the Altimeter / Speed sensors etc.. they are relatively expensive.
Has anybody managed to integrate / modify any of the cheaper sensors from other manufacturers yet so they talk to the Spekky software app... i.e Frsky Variometer $9.00, GPS module $41.00 ( speed lat / lon) etc.
I would like to measure speed and height.
What would be great would be a GPS module from Horizon as you could get speed, height etc from this one unit.
Also does anybody know if the X-Bus is actually an I2C bus ???? It would allow so many sensors to be added if wanted easily (after the software has been updated)
Shaun
2.4g shaun is offline Find More Posts by 2.4g shaun
Old Jan 24, 2012, 05:23 AM
Joined Jan 2011
I see what you mean as I just checked the price of the Altitude sensor and was suprised to find it over 40 bucks here in the US. I will say it is very sensitive, and probably gives more accurate readings than you will get from GPS. Before the wintery mix closed in on us I flew my Telemetry package w/altitude, and my son reading out the data. I was surprised that the data indicated the aircraft was bouncing between 70 and 140 feet. It was a windy day, but to my eyes, I could not detect the 40 foot bounce.
KKKKFL
Old Jan 24, 2012, 05:39 AM
pach is offline
Find More Posts by pach
United States, FL, Miami
Joined Aug 2009
Most of the sensors are the same as Eagle Tree , you just need to change the connector.
I would imagine the GPS module is coming out soon, its just a matter of programming for the radio.
Xbus sensors have a passthrough, so I imagine you could link them serially.
pach is offline Find More Posts by pach
Old Jan 24, 2012, 08:08 AM
AndyKunz is offline
AndyKunz's Avatar
Illinois
Joined Sep 2001
Pach,
We use a different communication protocol. The stock ET ones won't work.
Franco,
You were probably seeing pressure changes from the gusts, too.
Andy
Site Sponsor
Old Jan 24, 2012, 01:32 PM
2.4g shaun's Avatar
Joined Aug 2008
Hi Andy,
is the X Bus I2C or your own propriety one?
.....or can't you tell as it's secret squirrel
Cheers
Discussion Telemetry Options Paul5910 Radios 18 Mar 04, 2011 08:57 AM
Alert Spektrum Telemetry TM1000 shuts down!!! freirem Radios 15 Oct 14, 2010 07:13 PM
Sold spektrum telemetry $45 shipped ff954 Cars - Accessories (FS/W) 1 Oct 03, 2010 10:25 PM
Sold Brand new Spektrum AR8000 RX & TM1000 Telemetry birdy233 Aircraft - General - Radio Equipment (FS/W) 2 Sep 30, 2010 09:44 PM
Poll Telemetry options Daemon Xtreme Power Systems 181 Jul 02, 2008 09:59 PM
