Old May 08, 2012, 04:26 AM
Kambalunga is online now
Find More Posts by Kambalunga
Kambalunga's Avatar
Deutschland, Hessen, LA
Joined Jan 2009
I see no problem with PCM frequncies between 8 and 16kHz and max ~4000Hz on full trottle.
But you can decouple your TM1000 with an optocoupler.
Then need you a extra voltage source for the TM1000 lost the RX voltage but antenna information is still avaible.
Kambalunga is online now Find More Posts by Kambalunga
Old May 08, 2012, 12:39 PM
ProLogic is offline
Find More Posts by ProLogic
ProLogic's Avatar
Portugal, Setubal District, Setubal
Joined Dec 2006
Regarding my question about connecting Gps to Spektrum rpm port i have found the problem, is my mistake, the formula is round 32768, not 32754, going to the lake testing the results.
ProLogic is offline Find More Posts by ProLogic
Old May 21, 2012, 07:45 PM
scoris is offline
Find More Posts by scoris
Canada, ON, Burlington
Joined May 2012
I am now installing the air speed indicator on my hangar P51 mustang sport (with Spektrum DX7s). I m going to drill a whole in the wing's leading edge and insert the Pitot tube. Can anyone advise me on how should I glue it to the wing? Epoxy or silicon?
I noticed some have used Robart Quick Disconnect to facilitate connecting/disconnecting of air tubing when putting the wings on or off. I have another idea - i wonder if I can make it work: install the sensor in the wing, very close to the tube (so then I'll have the air line very short) and run an X_BUS extension through the wing to the TM1000 in the fuselage. This way all I'll have to connect/disconnect will be an electrical cable. Problem is that I can't find a proper male/female XBUS extension cable. Any thoughts?
scoris is offline Find More Posts by scoris
Old May 21, 2012, 08:39 PM
AndyKunz is online now
Find More Posts by AndyKunz
AndyKunz's Avatar
Illinois
Joined Sep 2001
Silicone might be better, give it a little shock absorbing for those in-hangar bumps. Get as much of the tube as possible out in front as far as you can. They work much better the farther in front you get it. The value in the manual is the bare minimum. I try to get the crotch of the Y right against the inside of the LE.
The connectors are not rated for lots of insertions. If you go that route make it so you can replace the wire easily (assuming you take the wing off to go home). We have several extensions - choose the one that's right for you.
Andy
AndyKunz is online now Find More Posts by AndyKunz
Site Sponsor
Old May 21, 2012, 09:58 PM
Harry H is offline
Find More Posts by Harry H
Harry H's Avatar
Los Angeles
Joined Oct 2010
I use the Robart Quick Connects. Works very well.
Harry
Harry H is offline Find More Posts by Harry H
Old May 22, 2012, 06:40 AM
scoris is offline
Joined May 2012
Thank you for your replies, Andy and Harry.
Ok so I will be using silicone (the one used for sealing kitchen counter tops) to "glue" the pitot tube to the wing (after drilling a hole, of course). I'll try to stick it out as much as possible.
I am gonna give up on my idea of using electric cable extension +connector and I will go with Harry's suggestion of using quick connects. But all that I could find was "Robart Quick Disconnect" - see photo. I assume there are the same thing. Also Robart 169B air line (photo also attached).
Just trying to get everything right without breaking anything
One more question, please, Andy: what is the latest software revision (firmware) for DX7s? Mine seems to be at v 1.00.
Thank you again and happy flying!
Old May 22, 2012, 09:12 AM
Harry H is offline
Harry H's Avatar
Los Angeles
Joined Oct 2010
Yes, you got it right. I used the silicone supplied from the pitot tube to the connectors and then the Robart line the rest of the way. Depending on how big your wing is, you may have enough silicone to do the job. I was short about 1 1/2'. Remember to get the pitot out far enough to get it out of the prop wash.
Harry
Old May 30, 2012, 06:07 PM
sap_2000 is offline
Find More Posts by sap_2000
Artic jetflyer
sap_2000's Avatar
Stabekk, Norway
Joined Sep 2004
Any news on the GPS module?
Will it be availiable in June as planned?
Looking to buy 3-4 of them
sap_2000 is offline Find More Posts by sap_2000
Old May 30, 2012, 09:24 PM
dee-grose is online now
Find More Posts by dee-grose
Wishing I was at Torrey Pines
dee-grose's Avatar
Tanner, Alabama
Joined Oct 2003
I want the vario module. I'm liking the altimeter module but I seem to be having range issues at times.
I'll pick up a GPS module when they are available.
Andy
dee-grose is online now Find More Posts by dee-grose
Old Jun 04, 2012, 07:21 PM
sap_2000 is offline
Artic jetflyer
sap_2000's Avatar
Stabekk, Norway
Joined Sep 2004
Anyone?
Old Jun 04, 2012, 08:04 PM
7oneWo1f is offline
Find More Posts by 7oneWo1f
AMF Years
7oneWo1f's Avatar
Joined Nov 2011
Looks like it was pushed out for yet another 30 days.
7oneWo1f is offline Find More Posts by 7oneWo1f
Old Jun 04, 2012, 08:44 PM
Retiredtech is offline
Find More Posts by Retiredtech
Joined Mar 2011
Not in the 'near future'!
Removed by User
Retiredtech is offline Find More Posts by Retiredtech
Old Jun 04, 2012, 08:50 PM
AndyKunz's Avatar
Illinois
Joined Sep 2001
It's enabled in the DX18...
Andy
Site Sponsor
Old Jun 05, 2012, 12:26 AM
Joined Mar 2011
Removed by User
Old Jun 05, 2012, 01:58 AM
aerocal is offline
Find More Posts by aerocal
Central California
Joined Dec 2006
Originally Posted by Retiredtech View Post
I'm trying to read between the lines ... are you indicating the GPS sensor will only be available on the DX18; or are we going to be able to use it with the DX8 after firmware updates? If so, when can we expect the updates?
Thanks.
RT
I think we can probably expect them when they are released.
aerocal is offline Find More Posts by aerocal
Discussion Telemetry Options Paul5910 Radios 18 Mar 04, 2011 08:57 AM
Alert Spektrum Telemetry TM1000 shuts down!!! freirem Radios 15 Oct 14, 2010 07:13 PM
Sold spektrum telemetry $45 shipped ff954 Cars - Accessories (FS/W) 1 Oct 03, 2010 10:25 PM
Sold Brand new Spektrum AR8000 RX & TM1000 Telemetry birdy233 Aircraft - General - Radio Equipment (FS/W) 2 Sep 30, 2010 09:44 PM
Poll Telemetry options Daemon Xtreme Power Systems 181 Jul 02, 2008 09:59 PM
