Old Mar 11, 2011, 08:37 PM
Brill 1 is offline
Find More Posts by Brill 1
Artillery! King of Battle!
Brill 1's Avatar
USA, KS, Scammon
Joined Mar 2002
Question
Parallel Charging and Voltage Difference?
Quick question; what is the acceptable voltage difference for parallel charging between battery packs? The packs are same make, model and capacity.
Brill
Brill 1 is offline Find More Posts by Brill 1
Old Mar 11, 2011, 08:39 PM
mrforsyth is offline
Find More Posts by mrforsyth
So. Cal.
My rule is .1 volt per cell. This guarantees that there will be no problem.
Mark
mrforsyth is offline Find More Posts by mrforsyth
Old Mar 11, 2011, 08:43 PM
Raphael L. is offline
Find More Posts by Raphael L.
Joined Mar 2011
I think 0.05V is acceptable
Raphael L. is offline Find More Posts by Raphael L.
Old Mar 12, 2011, 03:34 AM
slipstick is offline
Find More Posts by slipstick
Staffs, UK
Joined Nov 2003
If you mean the difference between the packs before you connect them together in parallel for charging I don't really worry about it so long as I'm sure I don't have one empty pack and one full pack . They soon equalise themselves.
Steve
slipstick is offline Find More Posts by slipstick
Old Mar 12, 2011, 04:25 AM
rebell is offline
Find More Posts by rebell
JustFlying
rebell's Avatar
Joined Dec 2005
It is even not a problem connecting a full and empty pack together, only negative point is that you waste one cycle of the full pack, the same as you waste a cycle when you discharge a full pack you did not used at the field with a charger. You can do storage charge / discharge at the same time with a full and empty pack together without charger.
rebell is offline Find More Posts by rebell
Old Mar 12, 2011, 06:40 AM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
The fact that you can nonnect two LiPoys of greatly difference voltage to gether and not have smoke is one thing but please be advised that initial current in-rush to the lower voltage one can be extreme.
http://www.rcgroups.com/forums/showt...6#post16290354
How many would chage at such a rate? How much long term damage does ir do?
Charles
Old Mar 12, 2011, 07:27 AM
Staffs, UK
Joined Nov 2003
Of course the inrush current lasts only for a short time. I don't think anyone has yet worked out how much damage, if any, a very short period of high rate charging will do. It would be interesting to know but it would be a really tricky experiment to conduct, particularly if you wanted accurate and repeatable results.
Steve
Old Mar 12, 2011, 07:52 AM
The Tug is offline
Find More Posts by The Tug
Barbados
Joined Jan 2011
I am a noob, but i have read that it is wise to connect the discharge plug first and then the balance plug as the initial rush of current goes through the bigger wires of the discharge plugs and that makes sense to me .
The Tug is offline Find More Posts by The Tug
Old Mar 12, 2011, 07:55 AM
jfflyer is offline
Find More Posts by jfflyer
John Foltz
jfflyer's Avatar
Woodstock, GA
Joined Jan 2011
If the cells are off much, they should be discharge-balanced before charging any of them.
jfflyer is offline Find More Posts by jfflyer
Old Mar 12, 2011, 08:19 AM
Southern Pride
Balancing discharged LiPolys is not a very good idea,IMO also cells which are completely or worse yet over-discharged should really be charged at a lower rate initially.
Charles
Old Mar 12, 2011, 12:21 PM
Rodney is offline
Find More Posts by Rodney
Florida
Joined Aug 2004
What slipstick says is the same as my findings; as long as one of the packs does not have a shorted cell, one can be fully discharged and the other fully charged and you can still connect them in parallel.
Rodney is offline Find More Posts by Rodney
Old Mar 12, 2011, 12:38 PM
Brill 1 is offline
Brill 1's Avatar
USA, KS, Scammon
Joined Mar 2002
Cool! Thanks for all the replies!
Discussion Parallel Charging is GREAT! jygwkuo Batteries and Chargers 4 Oct 21, 2010 09:46 PM
New Product parallel charging board‏ warbirdguyn951 Batteries and Chargers 43 Oct 13, 2010 03:03 AM
Data Parallel battery charging current test 4Dim Batteries and Chargers 25 Oct 02, 2010 02:07 PM
Sold parallel charge and balance cables for charging up to 6 lipos at once ff954 Aircraft - Electric - Batteries & Chargers (FS/W) 1 Sep 27, 2010 11:09 AM
Question 1S lipo battery Voltage Charging question. nemoskull Batteries and Chargers 2 Sep 05, 2010 09:51 PM
