Old Mar 11, 2011, 07:51 PM
djdaveq is offline
Find More Posts by djdaveq
I'd rather be flying...
djdaveq's Avatar
New York City
Joined May 2005
Can someone recomend some motors for my quad?
My quad is now slightly diffent than as shown below...
hey men, i was wondering if someone can recommend some new motors for my quad. right now i am using the FY90Q quad brain with turnigy 30 amp plush esc.
I have been trying these motors.
Turnigy 2217 16turn 1050kv 23A Outrunner
http://www.hobbycity.com/hobbyking/s...idProduct=5690
with 10x4.5 props on mikrokopter frame and 3 cell 2200 mah lipo.
issue is, it flys good indoors, but in the wind it gets all crazy and wants to flip on me. not sure what it could be. esc are set the right way to nimh mode, low timing, soft cut off. im thinking i need some better motors. wish to lift 500 grams payload? any hobby city motors can anyone recommend? thanks!
Dave
djdaveq is offline Find More Posts by djdaveq
Old Mar 11, 2011, 09:51 PM
jesolins is offline
Find More Posts by jesolins
Tri-Quad-Hexa-Octo-copters!!
Joined Feb 2007
Hi ,
You should put your posts in the FY90Q thread. http://www.rcgroups.com/forums/showt...04595&page=126
There are other reasons you could be having your flipping and oscillation issues. Things to check are the way the module is mounted(sometimes the isolation mount FY provides is not the best choice), if the board is loose inside(an easy mod to make it tight is in the thread) and if you have done prop and motor balancing(see the info in the Mega Index for prop and motor balancing solutions.
Those Turnigy motos should be OK for that size of quad. I have had good success with those and RCTimer 2830-14 750Kv and the APC1047 props. If your quad weighs less than 1Kg you should try the lighter EPP1045 props too. did you do the ESC throttle calibration?
Cheers,
Jim
Quadrocopter and Tricopter Mega Link Index
jesolins is offline Find More Posts by jesolins
Old Mar 12, 2011, 12:43 AM
mbsteed is offline
Find More Posts by mbsteed
Multicopter AP centric
mbsteed's Avatar
Canada, AB
Joined Jan 2011
Doesn't sound like motor problems - perhaps gain issue or bad ESC would be my guess.
mbsteed is offline Find More Posts by mbsteed
Old Mar 12, 2011, 03:17 AM
Covax is offline
Find More Posts by Covax
Moscow, Russia
Joined Nov 2010
You have good motors, man! What is your motor to motor dimensions?
Covax is offline Find More Posts by Covax
Old Mar 12, 2011, 08:24 AM
djdaveq is offline
djdaveq's Avatar
New York City
Joined May 2005
the motor dimensions are on that hobby city page above. but thank you so far for your input so far men. i will double check those things!
Idea Can you think of some alternative uses for brushless motors other than RC models? LMF5000 Electric Motor Design and Construction 21 Dec 23, 2010 05:33 AM
Discussion TrackR1 upgrade, can someone give me some insight ? wac FPV Talk 3 Dec 20, 2010 08:21 AM
Question based on the equipment i have, can someone recomend a 3d plane? istandalone Foamies (Kits) 28 May 13, 2009 06:20 PM
Discussion Can someone recomend me an onboard Video setup kov Aerial Photography 1 May 02, 2007 09:27 AM
Can some one please recomend me the weigthless servo for the eco 8 tail ? ermit Electric Heli Talk 8 Sep 21, 2002 11:01 AM
