Old Mar 11, 2011, 04:31 PM
Cable Guy is offline
Find More Posts by Cable Guy
Pittsburgh PA
Joined Dec 2004
Data
mCP X (non chat) setup and tips owners thread
the amount of initial negative pitch at zero stick makes it difficult to manage.
as a quick fix i used 62% pos/H sub trim on the pitch and also increased my throttle curve to really smooth it out.
on the DX7
steps for proper pitch:
1 bind and initalize the heli.
2 rotate the blades in the grips foreward(looking from the side you will notice the blades now point down)
3 sub trim until the blades are just below level
steps for a better throttle curve in normal mode:
L=0
1=46.5%
2=72.5%
3=85.5%
H=100%
CG
Cable Guy is offline Find More Posts by Cable Guy
Reply With Quote  (Disabled)
Old Mar 11, 2011, 04:33 PM
destinbeachman is offline
Find More Posts by destinbeachman
destinbeachman's Avatar
Florida
Joined Jul 2010
Didn't see the "tips and tuning" thread? I know you're just excited like the rest of us.
destinbeachman is offline Find More Posts by destinbeachman
Old Mar 11, 2011, 04:36 PM
Pittsburgh PA
Joined Dec 2004
it is so far off topic already and most of the posters dont even have one yet.
Old Mar 11, 2011, 04:42 PM
Florida
Joined Jul 2010
Ahh..My bad.I haven't even taken a look at it yet.Good luck on keeping this one pure.
Old Mar 11, 2011, 05:04 PM
Pittsburgh PA
Joined Dec 2004
The main gear as stated in other threads is something to really keep an eye on. right before liftoff the heli sounded a little weird and there it was, slipping down the shaft on battery 4. Perhaps a screw or a tiny collar will fix this, however, the main shaft can be slipped out from the bottom of the heli as the head is screwed on. I hate to be the first, but i am thinking a drop of CA will keep the gear in place without much recourse unless the main gear strips. for now i just pushed it on(carefully) but tight. If it comes loose again it is getting glued.
The gear mesh is incredibly tight and doesnt seem very adjustable. it does slow the blades down quick on power-off but it is also cuting into flight time. so far i have seen 2-3 minutes at a time and i am not even flying it that hard. I loostened the motor screws and tightened the foreward one first really tight and then the rearward with a little less torque. any suggestions?
Old Mar 11, 2011, 05:10 PM
Pittsburgh PA
Joined Dec 2004
the servos....
as posted in other threads the servos shiver while the heli sits in neutral. I assume this is due to the sensativity of the gyros and is normal. so far the other owners in my area have the same symptom and it doesnt seem to cause any problems during flight.
Old Mar 11, 2011, 06:59 PM
Pittsburgh PA
Joined Dec 2004
ok, found a better throttle curve
L=0%
1=50%
the rest 100%
Old Mar 12, 2011, 05:24 AM
turboparker is offline
Find More Posts by turboparker
Gopher huntin' stick jockey
turboparker's Avatar
Joined Jul 2009
Futaba 10CHP settings
All,
For those who plan to fly Futaba + module, here are the settings I'm using on my 10CHP.
Joel
D/R (switch D):
Low: 70%
High: 100%
Expo: -30%
Note: D/R & Expo on Ch 1 & 2 only
End Point
1 Aile 100/100
2 Elev 100/100
3 Thro 100/100
4 Rudd 100/100
5 Gyro 100/100
6 Pitch 75/75
Reverse: 1 Aile, 2 Elev, 3 Thro, 4 Rudd, 6 Pitc
Parameter
Type: Helicopter
Swash: H-1
Modul: PPM
Gyro Sense
N/A
Condition
Idle-up: Switch E
1) Center
2) Down
3) Inhibit
Throttle Hold: Switch G Down
turboparker is offline Find More Posts by turboparker
Old Mar 12, 2011, 07:42 AM
babblefish is offline
Find More Posts by babblefish
Yes, that is Jamie
babblefish's Avatar
SF Bay Area, CA
Joined Jul 2002
Thanks turboparker! I've got the same Futaba TX and a buddy has a 9CHP so this will come in handy. We've been flying ours already, but will try these settings.
babblefish is offline Find More Posts by babblefish
Old Mar 12, 2011, 11:50 AM
Pittsburgh PA
Joined Dec 2004
loc-tite is a must on the featheringshaft screw! the screw is so tiny and short it is hard to work with. to make it a bit easier, put a tiny bit of CA on the tip of your screwdriver and glue the screw to it, then dip it in loc-tite and reinstall it... it really makes it easier.
Discussion Blade MCP X - owner's thread rchelijc Micro Helis 13338 Yesterday 11:41 AM
Discussion Mcp x Tips and Tuning only (plz stay on topic) Rif Micro Helis 1668 Jun 23, 2012 02:29 AM
Discussion Blade mCP X Discuss anything thread A Rdnek Micro Helis 457 Jul 26, 2011 11:34 PM
Discussion Blade mCP x - strictly on topic Q and A thread jdog83 Micro Helis 58 Feb 07, 2011 02:28 PM
Question Any Espada R(X) (non RL(X)) owners ? Jurgen Multi Task F3X 18 Jul 07, 2008 08:09 AM
