Old Mar 11, 2011, 01:21 PM
JossyRC is offline
Find More Posts by JossyRC
JossyRC dot com
JossyRC's Avatar
Canada, ON, Toronto
Joined Feb 2010
Question
What TX do you use for your multicopters?
Was looking at a new TX? Considering many of the features available to add onto DIY flight controllers (GPS, FPV, stabalization modes etc). I figure the more channels the better... so I had the JR11X in mind. However I was tipped of to the use of FrSky's modules to increase range and have better spread etc. For what I understand this means going to a TX where modules can be swapped out (9303, 10C etc.). This got me thinking that "newer" might not be better and Futaba, Spek, JR might not be the best choice either.
So I'm interested to know:
What TX do you use?
What limitations have you come acrosss?
Do you wish you had, or had bought something different?
With your current set-up are you limited in what you can do with your copter etc?
Like to make a choice that an old pro would make... 'cept I'm not an old pro so would really appreciate your input.
Cheers, Jossy
JossyRC is offline Find More Posts by JossyRC
Old Mar 11, 2011, 01:36 PM
matwelli is offline
Find More Posts by matwelli
1400 watt RW Zephyr
matwelli's Avatar
Taranaki New Zealand
Joined Sep 2003
Turnigy 9x , has all the options I need, lots of mixes (if you ever want them)
Running the FrSky 2,4 ghz system (module designed for JR fits the turnigy)
Fly in both airplane and heli mode with it (use heli mode-no mixing so i can get an adjustable throttle curve)
NO issues, except only 8 model memory and the build quality is a bit poor, pays to open a new one up and check the connectors etc
matwelli is offline Find More Posts by matwelli
Old Mar 11, 2011, 02:19 PM
JossyRC is offline
JossyRC dot com
JossyRC's Avatar
Canada, ON, Toronto
Joined Feb 2010
For $60! Geez that's an afternoon bar tab! I guess you can't go wrong with that kind of cash!
http://hobbyking.com/hobbyking/store...idProduct=8992
Old Mar 11, 2011, 02:53 PM
matwelli is offline
1400 watt RW Zephyr
matwelli's Avatar
Joined Sep 2003
yea, but do the frsky upgrade - much better 2.4ghz technology
Old Mar 11, 2011, 09:04 PM
alainphoto is offline
Find More Posts by alainphoto
Japan, Tokyo, Chiyoda
Joined Oct 2010
thank for the info !
got a link to buy that frsky upgrade ? does HK sells it ?
alainphoto is offline Find More Posts by alainphoto
Old Mar 11, 2011, 09:09 PM
timecop is offline
Find More Posts by timecop
Joined Dec 2010
You should actually *order* it and wait for it to be in stock (I was quoted takes 2-3 weeks). If you sign up for notify, by the time you get in-stock email, it will already be sold out.
I think for frsky modules he's referring to this stuff:
http://hobbyking.com/hobbyking/store...&ParentCat=190
But which one works for 9X? Futaba or JR?
timecop is offline Find More Posts by timecop
Reply With Quote  (Disabled)
Old Mar 11, 2011, 10:10 PM
matwelli is offline
1400 watt RW Zephyr
matwelli's Avatar
Joined Sep 2003
this one, the JR http://www.hobbyking.com/hobbyking/s...4349&aff=95764 its what i use, works very well.
Old Mar 11, 2011, 10:17 PM
n3m1s1s is offline
Find More Posts by n3m1s1s
UK, Buckinghamshire, High Wycombe
Joined Feb 2007
yep turnigy 9x with some $8,99 RXs
n3m1s1s is offline Find More Posts by n3m1s1s
Old Mar 11, 2011, 10:34 PM
Joined Oct 2010
thansk for the link matwelli
why not the v2 version that has some telemetry info by the way ?
http://www.hobbyking.com/hobbyking/s...dProduct=14355
(sorry I am a newbie)
Old Mar 12, 2011, 04:43 AM
kickstart01 is offline
Find More Posts by kickstart01
Joined Mar 2011
does the turnigy 9x with the frsky produce the proper signal for UAVP and mikrokopters flight control?
If not is there an adapter or converter? where can i get or make? and how would that work?
sorry im pretty new trying to understand lots
kickstart01 is offline Find More Posts by kickstart01
Old Mar 12, 2011, 05:50 AM
timecop is offline
Joined Dec 2010
There's QuadroPPM12 which turns a mix of channels into PPM sum if you just wanna buy something, and I believe there's a bunch of opensource/cheap/etc projects to do same.
FrSky V8R7SP directly outputs PPM sum without any mods, so no adapter is needed.
Old Mar 12, 2011, 05:55 AM
onlyifamppowered is offline
Find More Posts by onlyifamppowered
onlyifamppowered's Avatar
brisbane
Joined Jul 2005
My 2 cents worth
I am using the Turnigy 9x V1 with corona 2.4 in tricopters and planes and it's great.
Lots of people using it so help is available for the setting up for tri's etc
onlyifamppowered is offline Find More Posts by onlyifamppowered
Old Mar 12, 2011, 12:20 PM
JossyRC is offline
JossyRC dot com
JossyRC's Avatar
Canada, ON, Toronto
Joined Feb 2010
I have a Walkera 2801PRO already - wondering if DIY boards wil work (with a switch) on the Walkera gear? The DHT would be nice. http://www.frsky-rc.com/ShowProducts.asp?id=76
Discussion What Kind of Camera do you use for FPV on your Quad? awa202 Multirotor Talk 34 Feb 28, 2011 04:53 PM
Discussion What did you do to/for your Heli today? roady89 Mini Helis 20 Oct 04, 2010 09:24 PM
Discussion What stopwatch do you use for DLG contests? Fly2High Hand Launch 34 Sep 20, 2010 06:30 PM
Question What is your program you use for design your plane??? daniel_F Indoor Pattern/F3P 29 Dec 13, 2007 11:51 PM
for all you in the north what do you use to keep your hands warm? kushal_22 Electric Plane Talk 42 Dec 11, 2002 10:26 AM
