This thread is privately moderated by Nogahyde, who may elect to delete unwanted replies.
Old Mar 11, 2011, 11:20 AM
Nogahyde is offline
Find More Posts by Nogahyde
Trader Rating: 64
Strings, Wings, and a Prayer!
Nogahyde's Avatar
Hoschton, Ga.
Joined Mar 2004
Trader Rating: 64
Sold
Astroflight 109 charger!!!
I have here a "used" AstroFlight 109 Deluxe Digital Battery Charger/Discharger in Very Good-Excellent condition.
It chargers 1 to 9 cells Lithium Polymer and up to 8.00 A.
Can be used with 12Volt Battery or 12V Power Supply.
There is a firmware upgrade available for $10 from AstroFlight.
Spec's : Astro Flight 109 Lithium Digital Charger/Discharger is one of the finest chargers available. This charger is specially designed to charge and discharge Lithium Polymer battery packs and can handle any pack containing from one cell up to nine cells (4.2 volts to 37.2 volts). Cell sizes can range from 140 mAh to 8000 mAh. This charge uses a proprietary 8-bit microprocessor to perform all of the necessary mathematical computations required to insure foolproof charging and discharging of Lithium Polymer battery packs. A two line digital display indicates the status of the charging sequence and tells you the charge current, the number of cells in the battery pack, the battery voltage, the duration of the charge, and the actual number of milliamp hours of charge put into te battery pack. A built-in voltage converter boosts the input from 12 volts to 40 volts so that battery packs containing up to nine cells can be charged. This charger is designed to be powered from a 12 volt regulated power supply, or a 12 volt automobile battery. Never use an automobile charger as a power source, for it could damage your new Model 109 Lithium Charger. There are two power cords on the charger/discahrger. The four foot long cord with the alligator clips is the input cord and should be connected to the 12 volt power source. The short cord is the output cord and is fitted with a deans connector. Connect the output cord to the Lithium Polymer battery being charged or discharged. The charger has a current adjust knob on the front panel. Charging current can then be adjusted between 50 milliamps and 8 Amps. Discharging current is electronically limited to 1.25 Amps.
$55.00 shipped in lower US.
Paypal as "gift" or you pay fee.
PM me if interested, and thanks for looking.
Nogahyde is offline Find More Posts by Nogahyde
Old Mar 11, 2011, 02:00 PM
modestmagi is offline
Find More Posts by modestmagi
Trader Rating: 60
modestmagi's Avatar
Joined Jul 2004
Trader Rating: 60
Astro 109
Sent PM
modestmagi is offline Find More Posts by modestmagi
Old Mar 12, 2011, 08:46 AM
Nogahyde is offline
Trader Rating: 64
Nogahyde's Avatar
Hoschton, Ga.
Joined Mar 2004
Trader Rating: 64
Still for sale.
Old Mar 12, 2011, 09:50 AM
Trader Rating: 60
modestmagi's Avatar
Joined Jul 2004
Trader Rating: 60
Payment sent!
Sold AstroFlight 109 Lithium Battery Charger Beerbox Aircraft - Electric - Batteries & Chargers (FS/W) 2 Apr 23, 2011 10:15 PM
Sold FS: Used Astroflight 109 Lipo Charger Jdeiter Aircraft - Electric - Batteries & Chargers (FS/W) 3 Jan 11, 2011 08:39 AM
Sold Astroflight 109 LiPo charger $55 Shipped gkamysz Aircraft - Electric - Batteries & Chargers (FS/W) 0 Dec 04, 2010 09:06 AM
For Sale Astroflight 109 Lithium Charger mwhitman Aircraft - Electric - Batteries & Chargers (FS/W) 1 Dec 03, 2010 02:26 PM
Sold Astroflight 109 Deluxe Lithium Charger/Discharger ~ $45 SHIPPED! mcalliej Aircraft - Electric - Batteries & Chargers (FS/W) 4 Oct 15, 2010 06:53 AM
