Old Dec 20, 2012, 02:33 PM
madbugger is offline
Find More Posts by madbugger
madbugger's Avatar
Ayrshire, Scotland
Originally Posted by Tiernan85 View Post
the Gopro gives a bit of a false sense of speed.
Gopro or not, your boat looks fine. I've got many streams like the one at beginning of the vid, but few bits of open water like the dock area featured later. Then again, nowhere's perfect. For example, I envy Chi his nearby lake/pond (call it what you like), but he is bemoaning the lack of local streams. Reminds me of a joke, but this is hardly the place for it. In fact no thread is the place for it, unfortunately
madbugger is offline Find More Posts by madbugger
Old Dec 20, 2012, 04:55 PM
nickatredbox is offline
Find More Posts by nickatredbox
nickatredbox's Avatar
Joined Jun 2012
I'm to ashamed and I'm sure its out of policy for YouTube its a bit like catching your reflection when you don't expect to only worse
nickatredbox is offline Find More Posts by nickatredbox
Old Dec 20, 2012, 06:16 PM
chidago is offline
Find More Posts by chidago
United States, IL, Chicago
Joined Dec 2009
T, Steve is gonna be doing a larger boat, about the length of the kmb hull, but, it the plastic that works for crawlin, with the kmb jet, it will do double duty, which is the BIG answer...
chidago is offline Find More Posts by chidago
Reply With Quote  (Disabled)
Old Dec 20, 2012, 06:59 PM
Tiernan85 is offline
Find More Posts by Tiernan85
Tiernan85's Avatar
Ireland, Leitrim
Joined Oct 2009
Yea just had a quick word with him about them. Need to save a few pennies, now is not the greatest time for that!
Tiernan85 is offline Find More Posts by Tiernan85
Old Dec 20, 2012, 08:21 PM
chidago is offline
Joined Dec 2009
Good..BUT, you'll get 2 boats in one, actually a better value, cause the big one will be good for crawlin too..
Old Dec 21, 2012, 05:17 AM
Tiernan85's Avatar
Ireland, Leitrim
Joined Oct 2009
Very true
Old Dec 21, 2012, 09:51 AM
chidago is offline
Joined Dec 2009
Yup..and so much nicer to have room inside to rig it YOUR way..batts on the side, for one thing, gets the CG where you want it..
Old Dec 22, 2012, 02:17 AM
Joined Jun 2012
Yellow Boat 3 Power Tests with Turnigy 500W H450 2100kv
Scratch Built hull, water jet and cooling pump made from Coroplast and junk Yellow Boat 3 Power Test (0 min 45 sec)
Boat build log here
Jet pump build here
Cooling pump testing here
Test results
Dynamic loses
29.5 Watts
2.3 Amps
Peak power
532 Watts
47.5 Amps on a 3C
Home brew cooling small centrifugal pump made from junk, with a scoop on the hull. The pump is mounted directly above the scoop and primes its self with the standard trim at rest.
I also found that if I re-introduce the out let from the cooling circuit into the jet ramp, there is a tendency for the water to be sucked through by the main drive when the throttle is up thus improving cooling flow at high loads, a win win. I wanted a circulation pump because taking a tap from the pressure side of the jet unit uses some thrust and is only available at speed, with low throttle or stopped there is no flow and this I thought would cause over heating when stopping after a long high power burst.
Old Dec 22, 2012, 09:16 AM
Mikedown is offline
Find More Posts by Mikedown
Closed Account
Joined Jul 2006
Sic improvements
Mikedown is offline Find More Posts by Mikedown
Old Dec 22, 2012, 11:37 AM
madbugger's Avatar
Ayrshire, Scotland
Originally Posted by Mikedown View Post
Sic improvements
Not quite sure where you are going with this.
With the Sic flex shaft and indeed most proprietary flex shafts there is a small section of solid shaft from before the prop mounting, and which (in the case of things like the Sic shaft) extends into the stator bearing behind the prop. The union between flex and solid shaft is normally by industrial cyano, tig welding, or other bomb-proof means of coupling. And on top of that, assuming your flex cable is wound the right way, the drag of the prop will tend to keep the flex shaft from unfurling.
If this were not the case every hydro, FSRV, competition mono, or other flex-shaft boat (of which there are many hundreds of thousands throughout the world) would be in trouble. That said, I am not a GURU as you put it. And being as I am (in the words of Winnie the Pooh) "a bear of very little brain" I may have completely misunderstood your problem. In which case, state it more clearly and perhaps the GURUS will wade in to help.
As far as the greasing is concerned, use a good marine grease which will last. If you have to strip the nozzle every so often to re-grease the shaft, it means you're getting a lot of water-time and therefore it's a small price to pay. Will still only take a few minutes. But then, one man's PITA is another man's 'routine maintenance'.
Old Dec 22, 2012, 12:29 PM
Mikedown is offline
Closed Account
Joined Jul 2006
jet mod
Old Dec 22, 2012, 01:12 PM
chidago is offline
Joined Dec 2009
Mad is completely correct, in fact, flex is the only thing that can be used RELIABLY in high output configs..solid shafts of any length require way to much support for high torque applications..
On the gas boats, we use either 6.35mm, or,7.93mm cable, but, if you notice the gap between my prop dog and the drive unit, which is about 7mm, is for the rap up of the cable under acceleration, I am putting 9 hp to it, it will tighten itself enough without the gap to blow the prop and dog off, or, break the cable..
But, knowing to do that, you have a trouble free running gear..I have shafts 10-12 years old still running fine..
Old Dec 22, 2012, 01:47 PM
madbugger's Avatar
Ayrshire, Scotland
Originally Posted by chidago View Post
Mad is completely correct.
Well, there has to be one time in everyone's life. To be completely correct, I mean.
But more to the point, thank you Chi for ramming my point home. You are more of a marine specialist than I could ever become. If you say it, it must be true. And you provided photo evidence Mikedown, take notice.
Old Dec 22, 2012, 02:08 PM
madbugger's Avatar
Ayrshire, Scotland
or not
Old Dec 22, 2012, 03:23 PM
Mikedown is offline
Closed Account
Joined Jul 2006
Jet boat
merry x-mas and a happy new year.
Build Log My NQD "Tear Into" build thread. wparsons Racing Boats - Electric 69 Feb 17, 2016 08:47 PM
Wanted Anyone have a NQD Tear into jet boat kicking around? Energy Boats (FS/W) 3 Mar 22, 2011 07:41 PM
Discussion Brushless NQD torn into jet boat mortonj69 Micro and Sub-Micro Boats 3 Feb 14, 2011 07:02 AM
Discussion Brushless NQD torn into jet boat mortonj69 Racing Boats - Electric 3 Oct 16, 2010 06:40 PM
New Product NQD Tear Into Jet Boats rcnz Dock Talk 1 Jul 14, 2010 06:48 PM
