Old Dec 17, 2012, 06:14 PM
madbugger is offline
Find More Posts by madbugger
madbugger's Avatar
Ayrshire, Scotland
Originally Posted by chidago View Post
Too cold out to help me, but, CERTAINLY not to cold to go shopping..
Well that's what you get for associating with the fairer sex.
madbugger is offline Find More Posts by madbugger
Old Dec 17, 2012, 06:22 PM
madbugger's Avatar
Ayrshire, Scotland
And anyway, from her point of view you are only 'playing with your toys'. Shopping, on the other hand, is a matter of life or death. If you are a woman, that is.
Old Dec 17, 2012, 11:03 PM
chidago is offline
Find More Posts by chidago
United States, IL, Chicago
Joined Dec 2009
Yeah..we pay a lot for that little spot we like...
chidago is offline Find More Posts by chidago
Reply With Quote  (Disabled)
Old Dec 17, 2012, 11:29 PM
Nebey is offline
Find More Posts by Nebey
Joined Sep 2012
About to finally do it
So I was about to order parts for my NQD, and this is what I came up with, let me know if I am on the right track?
Motor
http://www.hobbyking.com/hobbyking/s...or_4800kv.html
esc
http://www.hobbyking.com/hobbyking/s...C_3A_UBEC.html
Cooling jacket
http://www.hobbyking.com/hobbyking/s...ize_motor.html
Servo
http://www.hobbyking.com/hobbyking/s...cro_Servo.html
The Controller and battery will come later, just getting these parts now so I can start the modifications. Water here is frozen till April anyways.
Nebey is offline Find More Posts by Nebey
Old Dec 18, 2012, 01:58 AM
nickatredbox is offline
Find More Posts by nickatredbox
nickatredbox's Avatar
Joined Jun 2012
Scratch built 24" V hull Jet boat
Yellow Boat Hull 3
The hull is 4 inches longer than Yellow Boat 1 the keel is fiberglass and epoxy as are the chines, everywhere else its hot glue. Much cleaner hull then the earlier boats but still a bit ugly.
These hulls are tough as, run them into rocks do what you like they just flex. I suppose they would fail at the seams when they do, that's why I glassed in the keel.
The ride plate is glassed in on the inside so its really stiff, as the pump is all outboard I have recessed the transom to hide it away a bit. Its a big jet unit.
Room for 2 X 11.1V 2200mAh 20C batteries in parallel should deliver up to 80 + Amps. Ran this on test over 2 Kgs of thrust on a 3C @ 54 Amps
Turnigy 450 H2218 Brushless outrunner 2100KV with homebrew water cooling added, big bore pipes just because that the brass I had in stock.
Hobbyking SS Series 90-100A ESC with a water cooling plate added its an overrated ESC so should do the job easy. Will need a BEC I have a 5A in stock also.
The Cooling System
nickatredbox is offline Find More Posts by nickatredbox
Old Dec 18, 2012, 02:28 AM
Joined Jun 2012
Put a prop on it
Put a prop on it
Prototype and general knockabout boat Yellow Boat (hull 1) with a pusher aero prop aero hybrid drive system 365 Grams thrust 9.6 Amps
Floater-Jet Replacement Motor (AXN-2208-2150)
RPM/V: 2150kv
Max Watts: 180w
Max Amps: 20A
Max Volts: 11.1 (3s)
Turns: 16t
Resistance: 0.085Rm
Magnet type: N45SH
Idle Current: 1.52A
Shaft: 3mm
Weight: 44.0g
Suggested Prop: 5x5 / 6x4
P2632 Brushless Outrunner 3800kv
Battery: 2~3 Cell /7.4~11.1V
RPM: 3800kv
Max current: 32A
No load current: 11.1V/3.2A
Internal resistance: 0.036 ohm
Weight: 51g
Diameter of shaft: 2.3mm
Dimensions: 26mmx32mm
The NQD delivers 950 Grrams of thrust with this motor on a 11.1 V Lipo
Pusher only no steering but still planes
Hull still planes with 365 Grams of thrust from the aero prop only. The jet delivers 950 Grams btw.
https://www.youtube.com/watch?featur...&v=H22zy9b6wN0
Old Dec 18, 2012, 03:14 AM
NitroheadNZ is offline
Find More Posts by NitroheadNZ
NitroheadNZ's Avatar
Joined Dec 2012
Originally Posted by Tiernan85 View Post
Can't believe the video cut out right as you were doing the pass by the camera
Boat's looking good though, needs a few bobble heads and a cage though I really like the speed... I can feel a new build coming on myself...
Nitrohead, well done on building your own. I would never even think of taking on a feat like that! Any pics of it?
some pics of my scratch built hull. No, its not straight, yes it is rough. BUT i works and is bloody strong!!!! Bring on the rocks!!!!
These pics aren't the lastest, will get some more up once iv put things together a bit more. Have almost finished the top deck so thought id weigh it just with a 1700mah 2s lipo. 550 grams! But that's total weight without a motor. The motor weighs 153 grams so a total of 700-750 grams aint too bad. Or is it?
NitroheadNZ is offline Find More Posts by NitroheadNZ
Old Dec 18, 2012, 06:47 AM
antslake is offline
Find More Posts by antslake
How high will it go?
antslake's Avatar
Greenwood Lake NY
Joined Oct 2003
LOL T, the camera didnt cut out, my better half did..
Fire, I have flown off snow for years..the best
That's what you get for driving around slow for 2 minutes.......sheesh
antslake is offline Find More Posts by antslake
Latest blog entry: FAA registration
Old Dec 18, 2012, 12:49 PM
Joined Jun 2012
Looks like my pattern
That will be a really seaworthy hull I play with my Coroplast design in the surf and have only capsized once.
Yellow Boat weighs around 750 Grams at launch with a 2200mAh lipo
The weight for your boat should be good should go well. Looks around 20" like Yellow Boat
I measured the thrust from an NQD unit the other day and got 950 Grams of thrust on 11.1V with a P2632 3800kv motor pulling 34 Amps, around 375 Watts
Weight / Watts = 4 Grams per Watt
Thrust / Watts = 2.53 Grams per Watt (which is a bit like and EDF jet in air)
This is what my design is a homage to btw yours is similar
Yellow Boat 3
Old Dec 18, 2012, 12:57 PM
chidago is offline
Joined Dec 2009
This is GREAT !! lotta action today here..
Old Dec 18, 2012, 01:33 PM
7car7 is offline
Find More Posts by 7car7
7car7's Avatar
Washington State
Joined Oct 2007
You scratch builders are living my dream. If I had a bit more time on my hands I'd be building boats from scratch all the time.
I've wanted to build an aluminum hull jet drive RC boat longer than I knew there were RC pumps. Thanks for sharing them.
My ultimate RC goal is to someday build a jetdrive powered hydrofoil.
7car7 is offline Find More Posts by 7car7
Old Dec 18, 2012, 01:39 PM
7car7 is offline
7car7's Avatar
Washington State
Joined Oct 2007
Motor
From what I've gathered from others here, it seems that the best KV is between 2000 and 3200 or so. And run on 3 cell. When you start getting up into the ducted fan motors, like the one you listed, you will be forced to use 2 cell, and it might not have the performance you'd be wanting.
I was not able to find a HK motor I wanted at the time, so I went to Ebay, got a 2100(apprx?). I'm happy with it, but if I was to do it all over again, I'd try to find a 3000 for more speed in the lakes. The 2000 range motor is very adequate for rivers as far as I'm concerned.
Old Dec 18, 2012, 01:51 PM
Joined Jun 2012
I built Yellow Boat 3 in 3 hours yesterday once you have a pattern its simple
I you like I can send you the pattern by email? Or you can see it on my blog and make one from that
Old Dec 18, 2012, 01:55 PM
Joined Jun 2012
I wonder would the hydrofoil need some kind of foil angle control system? like a plane or are they fixed?
I want to build an Ekranoplan half plane half boat
The Russians build such cool things Rostislav Alexeyev
Old Dec 18, 2012, 02:06 PM
Joined Jun 2012
I have tired up to 4200kv on a 3C which was too fast for the NQD In think
My 3800kv runs well on a 3C I think (know) that there is a limit to the amount of water you can force though the nozzel of the NQD
On a bath test the 3800kv moves water well and primes Ok at full speed if you lift the inlet clear and re-immerse it.
Also the power level is good at 375 Watts drawing 34 Amps the 3800kv is the bets motor I have run an the NQD jet pump I think.
I have a larger unit 30mm home made with a 2100kv its a bit of an unknown quantity , initial testing is encouraging with lots of thrust and with the lower RPM there is scope for more batt cells
Build Log My NQD "Tear Into" build thread. wparsons Racing Boats - Electric 69 Feb 17, 2016 08:47 PM
Wanted Anyone have a NQD Tear into jet boat kicking around? Energy Boats (FS/W) 3 Mar 22, 2011 07:41 PM
Discussion Brushless NQD torn into jet boat mortonj69 Micro and Sub-Micro Boats 3 Feb 14, 2011 07:02 AM
Discussion Brushless NQD torn into jet boat mortonj69 Racing Boats - Electric 3 Oct 16, 2010 06:40 PM
New Product NQD Tear Into Jet Boats rcnz Dock Talk 1 Jul 14, 2010 06:48 PM
