Thanks for the tips
I have a flat pad for my single jet and the pump is fully immersed at rest, no problems with drive at low speed in that it primes fine. I have a scratch built mono form V hull 20" long, with a 25° V handles great at speed and in rough water. One thing I added 2 turning fins which can be seen on you tube in the surf video
Not only did they help with handling but the reduced the cavitation problem. I like doing FPV in some of the local wetlands at slow speed and the fins fix the low speed handling issues well. Some one else told me that a bigger jet would perform much better, as I'm cash poor most of the time I would have to build one but I need some basic ratios, like nozzel to impeller which is very important I'm told. |
Nice
impeller looks like a nice fit, the stock impellers I have got seem to have lots of mould flashings that need trimmingI have seen modified units with flex shafts on Ebay This is a fully modified Jet Unit ot suit the NQD Tear Into Jetboat and SicRC Jet Sprint 410 Jetboat. The unit comes with your choice of motor couplers to suit 2.3mm, 3mm or 3.17mm motor shafts, simply specify the coupler size you require when you order. Tunnel Diameter is 20mm. Mods include: Brass shaft sleeve. Flex shaft. Stainless intake grille. Water pickup. http://www.ebay.com/itm/Modified-Jet...item27cca8aaf1 |
Vancouver, BC
Joined Aug 2009
I put a ride plate on mine before it first saw water, having learnt about them elsewhere. Have never regretted it, particularly given where these boats get used.
Well, I'm gonna try making a little rudder on a spring, sorta like a outboard motor can kick up when it hits a log..could all be too small to work with, dunno.
When I can, I am going to try and find some brass tubing stock to see if any stock sizes work for a wear ring, but, if one can be found, its gonna load the motor more, but, will no question, help thrust. What are you guys finding when you do a ride plate?? just jet protection? is it affecting handling? trim? Mine needs to do double duty well, rock climbing, and lake. ![]()
I am not really in a position to comment on the pros and cons, since I fitted one from scratch.
My main objective was jet, and therefore servo, protection in creek running but from various videos of boats with and without I get the impression it helps with stability. In the sense that the boat is less likely to get the bow coming so high out of the water when hitting waves or submerging as much if you spin out. In other words, it reduces porpoising. This in turn may be helping with keeping the drive 'lit' although in extremes it still cavitates with high-G turns as everyone else has found. Reason it works, IMO, is that it effectively lengthens the hull on the centreline, where it matters most for fore-and-aft trim. For that reason you may need to experiment with the longitudinal angle of the ride plate, in the region from a couple of degrees below level with the hull bottom to a couple of degrees up from level to get the maximum benefit. Mine is level with the flat area at the back of the hull (from front to back) with a couple of mm at each side (looking across the boat) bent up to follow the upwards slant of the V bottom. That said I have never experimented with changing the thrust angle of the jet or adding trim tabs each side, both of which you've done. Perhaps these mods have the same effect, although my ride plate goes back further than your trim tabs. What is needed is comment from people who have run the boat with and without a rideplate. |
I fitted 2 fixed fins fully aft each side of the jet intake on a single 20 mm jet 20" deep V hull, helps with fast turns and when its running slow in the wetland creeks I FPV in, doesn't noticeably effect performance. Back in the day we had a 20 ft stern drive boat on the the river in the UK which handled like a pig at low speed after fitting home brew trim tabs which had max 30° of down angle, straightened her up 4 knots with the tabs fully down and she was a breeze no constant steering corrections like before.
| Thread Tools | |
| Build Log My NQD "Tear Into" build thread. | wparsons | Racing Boats - Electric | 60 | Mar 23, 2011 06:40 PM |
| Wanted Anyone have a NQD Tear into jet boat kicking around? | Energy | Boats (FS/W) | 3 | Mar 22, 2011 07:41 PM |
| Discussion Brushless NQD torn into jet boat | mortonj69 | Micro and Sub-Micro Boats | 3 | Feb 14, 2011 07:02 AM |
| Discussion Brushless NQD torn into jet boat | mortonj69 | Racing Boats - Electric | 3 | Oct 16, 2010 06:40 PM |
| New Product NQD Tear Into Jet Boats | rcnz | Dock Talk | 1 | Jul 14, 2010 06:48 PM |
