Old Mar 12, 2011, 11:03 PM
eak is offline
eak
Find More Posts by eak
eak
Joined Feb 2011
Originally Posted by wparsons View Post
If you look at the current draw after ~6 minutes of WOT running, you'll see I'm drawing far below 35a.
700mah in 6 minutes is nowhere near 20a, nevermind 35a.
A 19mm jet drive isn't really a ton of load on a 450 outrunner. I could run it without water cooling at all for river bashing, I only have it so if I'm blasting around at WOT it doesn't get too hot.
where you get 0.7ah on something rated 30+A show me the math.
eak is offline Find More Posts by eak
Old Mar 12, 2011, 11:19 PM
eak is offline
eak
eak
Joined Feb 2011
0.7a on a 2.2ah bat you could run for 3hours or something.
Old Mar 12, 2011, 11:35 PM
Firehawk989 is online now
Find More Posts by Firehawk989
Vancouver, BC
Joined Aug 2009
Isn't it .7Ah/.1h = 7A?
Today I got ~15 min runtime on my setup and the charger put 2148mAh back into the pack, so 2.148Ah/.25h = 8.6A
That's average amp draw though because I wasn't at WOT the whole time, but even if you triple that you're still only at 25.8A. Though I'll admit I have no idea what a good WOT estimate would be. Double? Triple? 4x the average draw?
Firehawk989 is online now Find More Posts by Firehawk989
Old Mar 12, 2011, 11:58 PM
Energy is offline
Find More Posts by Energy
Canada
Energy's Avatar
Joined May 2009
regardless of all of this, it seems you've been running the set up with no issues, so you must not be pushing the esc too hard.
Energy is offline Find More Posts by Energy
Old Mar 13, 2011, 01:33 AM
Vancouver, BC
Joined Aug 2009
Agreed.
Old Mar 13, 2011, 03:04 AM
4mods is offline
Find More Posts by 4mods
Canada, BC, Vancouver
Joined May 2006
hahahah, I so like my toss and run method better then the math I think. JK!
4mods is offline Find More Posts by 4mods
Old Mar 13, 2011, 03:07 AM
Vancouver, BC
Joined Aug 2009
Also agreed! lol
Old Mar 13, 2011, 09:55 AM
wparsons is offline
Find More Posts by wparsons
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
No math, I'm telling you what I saw in a test run yesterday with the new impeller.
I ran it for ~6 minutes, WOT up and down the river and only put 680mah back into the pack to fully charge it. It was in the water for closer to 10 minutes, but the first couple minutes were just drifting in the current and testing the steering.
No math, no voodoo, just raw data from a real run.
This is the motor I'm running:
http://www.hobbyking.com/hobbyking/s...dProduct=11173
It doesn't matter how much current the motor is rated for, it'll only draw as much current as it needs based on the load. A 19mm impeller simply doesn't put a huge load on the motor compared to what it can handle so it runs more efficiently.
I've seen many setups with people running this motor (or similar) on 3s with 32mm props without water cooling and ~40a escs without issue as well.
wparsons is offline Find More Posts by wparsons
Old Mar 13, 2011, 10:23 AM
Energy is offline
Canada
Energy's Avatar
Joined May 2009
I was happy with how easy it was to rip everything out of the boat. The servo mount was a bit of a challenge, but over all no real issues excluding the motor. The motor for one was difficult. I wanted to go the route of not removing the jet unit, so i had to work at the motor for a good 30 minutes to get it out. Tried about 50 screw drivers. Found one that worked and now theres a seemingly permanent indent in my thumb.
Will get some pictures up after i do my paint job.
Old Mar 13, 2011, 10:39 AM
wparsons is offline
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
^^ You're braver and more patient than I was, I didn't even bother trying to get the motor off the jet drive with it in the hull!
Old Mar 13, 2011, 10:50 AM
eak is offline
eak
eak
Joined Feb 2011
I'm hungover now. but I figure that is 8.5A or something.
Old Mar 13, 2011, 11:00 AM
Energy is offline
Canada
Energy's Avatar
Joined May 2009
Ya it was a tad frustrating. I will be putting another layer of seal around the jet unit anyway, so not sure why i did it in the first place.
I'm going to craft up a servo mount out of balsa, so i kept the old one to trace the outlines so that i can have it fit the hall nice.
I'm in the middle of brain storming cool paint jobs. Hoping to do something colorful that is easily recognizable.
Old Mar 13, 2011, 04:27 PM
Vancouver, BC
Joined Aug 2009
lol, is it the "That was totally worth it!" type hangover, or the "I'm never drinking Jager Bombs again!" type hangover?
Old Mar 13, 2011, 04:36 PM
Vancouver, BC
Joined Aug 2009
I shaved all the useless bits off the stock servo ramp and then cut a hole in the deepest part to fit my 9g metal gear servo, and drilled a couple holes for screws to secure the servo. There was also enough room left on the ramp to mount my rx with some velcro.
I found the easiest way to get the stock motor out with the drive in place was to use some needle-nose pliers and a bit from one of those multi-bit screwdrivers. For me it was harder getting the new motor in because I had to enlarge the screw holes and shave some material off the drive to clear the hex bolt heads I used to mount the motor.
Old Mar 13, 2011, 04:56 PM
eak is offline
eak
eak
Joined Feb 2011
I will survive.
But 700mah for 6min is a current use of 8.5amps. I cant think of a different way to count it right now. but thats a bit over 2times the unloaded current draw on that motor. sounds ok to me. so you prob be fine with a 35amp esc.
Build Log My NQD "Tear Into" build thread. wparsons Racing Boats - Electric 69 Feb 17, 2016 08:47 PM
Wanted Anyone have a NQD Tear into jet boat kicking around? Energy Boats (FS/W) 3 Mar 22, 2011 07:41 PM
Discussion Brushless NQD torn into jet boat mortonj69 Micro and Sub-Micro Boats 3 Feb 14, 2011 07:02 AM
Discussion Brushless NQD torn into jet boat mortonj69 Racing Boats - Electric 3 Oct 16, 2010 06:40 PM
New Product NQD Tear Into Jet Boats rcnz Dock Talk 1 Jul 14, 2010 06:48 PM
