Old May 08, 2012, 07:17 AM
wparsons is offline
Find More Posts by wparsons
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
A higher kv will work, but you just end up with more noise and more heat.
wparsons is offline Find More Posts by wparsons
Old May 08, 2012, 10:14 AM
Dongskie is offline
Find More Posts by Dongskie
Dongskie
Dongskie's Avatar
Philippines, NCR, Mandaluyong City
Joined Jul 2007
Exactly, I'm going down on Kv and will switch to inrunner motor.
Dongskie is offline Find More Posts by Dongskie
Old May 19, 2012, 04:07 PM
kitaro is offline
Find More Posts by kitaro
kitaro's Avatar
Italy, Tuscany
Joined Apr 2006
today i finish my job on Jet Boat.....
electronics protect under plexiglas and gasket
only the cooling rods wasn't but ready to try for a few time (to not become hot)
see last photos in my album
http://imgur.com/a/oUyTu/embed#0
i try on river for 1 minute max.... but not run so fast like i hope....
u used 2s 3000mah and after 1 minute the esc and lipo was ok but motor....aiaiai smoke and HOTTTTTT
i must change motor i think...it run again...but i think to much KV....
keep in touch next test!!!
kitaro is offline Find More Posts by kitaro
Old May 20, 2012, 04:58 AM
Dongskie is offline
Dongskie
Dongskie's Avatar
Joined Jul 2007
Possible mod for the impeller:
Old May 20, 2012, 07:37 AM
wparsons is offline
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
There was a seller on ebay selling replacement impellers.
Old May 20, 2012, 09:59 AM
kitaro is offline
kitaro's Avatar
Italy, Tuscany
Joined Apr 2006
links please !!
and
i need to buy a coupler for standard shaft (2,3mm) to other motor shaft (3/3.17mm)
where can i buy???
help me!!
Old May 20, 2012, 04:01 PM
wparsons is offline
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
Four complete jet drives for $70:
http://www.ebay.com/itm/4PCS-20mm-Je...item257005bab7
Spare impellers:
http://www.ebay.ca/itm/ws/eBayISAPI....E:L:OC:CA:1123
Spare impeller shafts:
http://cgi.ebay.com/ws/eBayISAPI.dll...m=110880906168
Old May 20, 2012, 09:04 PM
wavekatcher is offline
Find More Posts by wavekatcher
FAA is Sofa King We Todd Did
wavekatcher's Avatar
Svalbard and Jan Mayen, Svalbard
Joined Mar 2011
Finished mine today. Ran her in the kiddie pool for leak testing and the pump leaks like a sieve near the transom. I didn't pull the pump completely out when I built her up. I'll try to use some CA 1st, then shoe goo the heck out of it if that doesn't work.
I'm glad I'm using the hole for the antenna for my drain plug
wavekatcher is offline Find More Posts by wavekatcher
Old May 20, 2012, 10:28 PM
stgdz is offline
Find More Posts by stgdz
Volts>amps
stgdz's Avatar
United States, MN, Buffalo
Joined Jul 2011
What places still sell these?
thinking this motor on 2s with the 35amp seaking, not sure on mAH for the battery though.
stgdz is offline Find More Posts by stgdz
Old May 20, 2012, 10:37 PM
Joined Mar 2011
Got mine @ xenonproject.com
I'm using the 2040 4800kv motor and 35 amp seaking esc from Hobbypartz. I also bought the same setup from Hobbyking, but who knows when or if it will ever show up.
I bought some turnigy (USA warehouse HobbyKing) 2S 2650mah 30C. Good size and weight for this lil boat. If you can afford it, get the highest C rating you can.
Old May 22, 2012, 09:52 AM
kitaro is offline
kitaro's Avatar
Italy, Tuscany
Joined Apr 2006
motor like mine
http://www.rcgroups.com/forums/showp...&postcount=255
but non work well....not fast with 2s 3000mah 20c
why???
your run fast??
Old May 22, 2012, 12:22 PM
wparsons is offline
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
What do you define as fast? It'll never go much above ~25mph, the jet drive is just too small to get going any faster.
If it's going much slower, there's something wrong in how it's setup. Your motor on 2s should be plenty quick as far as these boats go. Are you getting the full throttle range (esc calibrated to your transmitter?)?
Old May 22, 2012, 04:39 PM
stgdz is offline
Volts>amps
stgdz's Avatar
Joined Jul 2011
Since I have a bunch of zippy 2100 35c and some 2700 30c turnigys I am going this route
-Tacon 2848-380L 2300kV motor
water jacket
-SeaKing 35A water cooled ESC
Outside of getting some tubing, not sure on size. Is there any additional parts I need? I have a hxt900 servo.
Old May 22, 2012, 10:24 PM
Joined Mar 2011
Originally Posted by kitaro View Post
motor like mine
why???
your run fast??
Make sure to set your throttle range with your transmitter and esc. Could be the problem?
Old May 22, 2012, 10:28 PM
Joined Mar 2011
water jacket
I used aquarium airline tubing, it has a larger inner diameter for lots of water flow. Also get yourself some Grim racer speed grease to grease the impeller shaft. you'll want some grease behind the rubber bushing to try and keep water from coming in. Maybe a waterproof rx box too? I'm using the traxxas e-revo/slash rx box.
Build Log My NQD "Tear Into" build thread. wparsons Racing Boats - Electric 69 Feb 17, 2016 08:47 PM
Wanted Anyone have a NQD Tear into jet boat kicking around? Energy Boats (FS/W) 3 Mar 22, 2011 07:41 PM
Discussion Brushless NQD torn into jet boat mortonj69 Micro and Sub-Micro Boats 3 Feb 14, 2011 07:02 AM
Discussion Brushless NQD torn into jet boat mortonj69 Racing Boats - Electric 3 Oct 16, 2010 06:40 PM
New Product NQD Tear Into Jet Boats rcnz Dock Talk 1 Jul 14, 2010 06:48 PM
