United States, WI, Merrill
Joined Jun 2011
As I looked at that Waterproofing a Keychain cam video, the first thing that popped into my head was how easy it would be to make a front case lens out of a cheap dollar store lens from a Dollar Store reading glasses lens. Most of them are plastic and a simple template taped on the lens and a trip to the grinder or belt sander and you are done with a nice clear lens for the waterproof case. With a little experimentation, you might even make some variety of magnifications with different prescription reading glasses. Think that should be very possible. John |
United Kingdom, Scotland, North Ayrshire
Joined Feb 2010
It was a very thin layer of ice on the loch only about 1mm thick so it didn't even ride up it just went right through it. I was going slow ice breaker style but my friend went full power through it without problems.
We got most of the hull back because when it crashed it pushed most of it into the hull. it happened a couple of feet from us so it didn't get a chance to sink but I think people running more than one boat should think if putting strips of carbon or something along the side on the lower half of the hull it's not even a millimetre thick . a jet boat at full speed will have no problems going right through it because the plastic just cracks rather than deforming. i also had my CEN aqua jet boat out with its 3600W motor on 6S and it destroyed the coupling so i have another ordered . my friends nitro boat ran ok for a while untill the vibration made every screw on the boat undo its self then the exhaust fell off lol |
Vancouver, BC
Joined Aug 2009
I can see evidence of where I've pressed the buttons on the plastic, but so far it doesn't look serious enough to warrant replacement. When it does, it will be a simple matter of eating some Tic-Tacs and popping the slide out of the old box to glue it in the new one.
Vancouver, BC
Joined Aug 2009
Sounds like you might have had a defective hull, mine appears to be a solid 2mm or so thick all around. The cold temperatures may have made the plastic brittle and more prone to breakage as well. I have sent mine full speed at rocks many times to get air and do stunts, and I see no signs of cracking other than the tip of the bow before I glued it up nicely.
Joined Jun 2011
I am all wrapped up trying to figure methods to use the special Ultra-high-molecular-weight_polyethylene "UHMW-PE" that is used on the hulls of some of the best rock-crawler type JetBoats. It needs to be riveted on in thick sheets on the real boats, but I found a version that is sold in rolls of much thinner Tape, with a self adhesive backing. If that would stick to our hulls, I think it would do everything that the Carbon fiber would and more, in that is somewhat soft and flexible compared to the very hard/brittle carbon fiber. And it should have much better slipperiness and abrasion resistence. I am going to order a roll just to test/play with. I already picked up a piece of the same material in a 1 inch/ near 25mm thick slab that I will be trying to machine to create a slicker and stronger intake for the bottom of my jet boat. Just a thought. I am also going to run an Automotive Door Edge Vinyl Trim strip around the seam of my NQD. It will act as a kind of firm, but slightly flexible bumper all around my Coast Guard themed boat. I found it a local AutoZone store, here is the manufactures website description. http://www.cowlesproducts.com/styleguard_door_edge.html John in Merrill |
Btw, today I tried shopping in a different place (Asda, the UK offshoot of the US Walmart) and got some tic-tacs in the more flexible box you describe. No tic-tacs are UK made, so the box plastic must presumably vary a bit depending on where they have been sourced from. Ours come from Ireland, Italy, the Netherlands and various other sources. Mind you, none of them have the bit on the inside of the lid shown here http://foodbeast.com/content/2012/08...ers-all-wrong/ and in other similar youtube vids. But then we don't have the same range of flavours either. You North Americans get everything first!
Geo, Chi, Fire
If I understand geo's post, it was the bow (hardest part is along the seam) which went into the side of his buddy's boat. And it was his buddy's boat that sustained the damage.That's different from ramming things straight on (or getting air going over a rock) and not sustaining any damage to your own boat. The vacforming process means there are differences between boats and different thicknesses on various parts of the hull of any given boat. And this plastic gets very brittle in cold temperatures. And by geo's own admission there was ice on the loch. With model planes we always find the only time there is a mid-air is when there are only two planes aloft. Put more up and it doesn't happen. Seems it's the same with boats
| Thread Tools | |
| Build Log My NQD "Tear Into" build thread. | wparsons | Racing Boats - Electric | 60 | Mar 23, 2011 06:40 PM |
| Wanted Anyone have a NQD Tear into jet boat kicking around? | Energy | Boats (FS/W) | 3 | Mar 22, 2011 07:41 PM |
| Discussion Brushless NQD torn into jet boat | mortonj69 | Micro and Sub-Micro Boats | 3 | Feb 14, 2011 07:02 AM |
| Discussion Brushless NQD torn into jet boat | mortonj69 | Racing Boats - Electric | 3 | Oct 16, 2010 06:40 PM |
| New Product NQD Tear Into Jet Boats | rcnz | Dock Talk | 1 | Jul 14, 2010 06:48 PM |
