Old Oct 25, 2012, 11:36 PM
kuvera is offline
Find More Posts by kuvera
kuvera's Avatar
Joined Oct 2003
Hello Mike
The topic with the roll can have 2 cases.
A delta-wing-plane can fly incredibly slow with high alpha. If you make a roll during very slow speed with the nose up (even only 5°), the roll will not be smooth. This is normal.
The other case is being tail-heavy.
Try in flight - if the roll comes smooth with maybe 1/2 speed, then it must not be the tail-heavy-topic.
Severin
kuvera is offline Find More Posts by kuvera
Old Oct 27, 2012, 07:36 AM
Cirodi is offline
Find More Posts by Cirodi
Italy, Lombardy, Milan
Joined Apr 2012
HK RAFALE-70 building instructions
Hello,
mine is just arrived.
No instructions!
Can you help me in putting it together?
Really appreciated.
Thanks.
Best,
Sergio
Cirodi is offline Find More Posts by Cirodi
Old Oct 27, 2012, 08:11 AM
Tartago is online now
Find More Posts by Tartago
Plane crazy
Tartago's Avatar
Joined Apr 2006
Originally Posted by Cirodi View Post
Hello,
No instructions!
Really appreciated.
Thanks.
Best,
Sergio
I hate to say this, but you have to read the thread from the beginning .
Tartago is online now Find More Posts by Tartago
Old Oct 27, 2012, 11:11 AM
Cirodi is offline
Joined Apr 2012
Hello,
I went through the topic, but I found a lot of discussions on wrong parts, new retractable, CG place, paint scheme, etc.
I'm looking to just a page with the steps (e.g. where to glue, what reinforce to add, what glue, where to place servos, etc.) and some pictures will help me a lot.
I will really appreciate who is willing to help (me).
Thank you very much in advance.
Best,
Sergio
Old Oct 27, 2012, 11:28 AM
Roen is offline
Find More Posts by Roen
United States, VA, Norfolk
Joined Oct 2006
Hello,
Best,
Sergio
Have you ever built a plane kit before? Sounds like this may be your first kit. Everything is pretty self explanatory even without instructions.
Roen is offline Find More Posts by Roen
Old Oct 27, 2012, 08:03 PM
flynwing_mike is offline
Find More Posts by flynwing_mike
flynwing_mike's Avatar
Northern Cal
Joined Nov 2010
Hello,
No instructions!
Really appreciated.
Thanks.
Best,
Sergio
Set the top half of the fuselage on your workbench, canopy side down. Set the main wings also next to the fuse. Study the shapes and you will see there are molded in recesses for all the main components. Even channels for the wiring. The rectangular recess in front of the motor is for your speed control. That's about it.
flynwing_mike is offline Find More Posts by flynwing_mike
Old Oct 27, 2012, 09:34 PM
Jet Junky is offline
Find More Posts by Jet Junky
Jet Junky's Avatar
United States, NY
Joined Oct 2012
Latest project, Rafale 70mm
Bought two of these kits from US warehouse with no duplicated parts. Thought I would share on this kit as I build, my first issue was with the drag causing razed details on wings and elevators see photos. I sanded them out after looking at photos of the real thing, if you have any thoughts on this let me know! Also after reading other posts I agree that a cheater is needed, so included one in the mods
CORRECTION !
Cheater in the pics below did on work out well, ( too close to EDF ), the EDF did not like sucking air from one side. Recomend two large air inlets at rear gear bays, they could also double as hand launch holds.
Jet Junky is offline Find More Posts by Jet Junky
Old Oct 28, 2012, 08:02 AM
a10flyer is offline
Find More Posts by a10flyer
Joined Apr 2011
RAFALE 70mm.
I just bought my rafale 70mm. I wonder if somebody know the loss of effect due to one engine and two nozzles?
About the engine Im thinking at wemotec 1w-30=1.9 kg thrust 4s or 2w-20=1.7 kg thrust 6s.
a10flyer is offline Find More Posts by a10flyer
Old Oct 28, 2012, 03:35 PM
Cirodi is offline
Joined Apr 2012
Hi Mike,
thank you for helping.
What about the wooden reinforce?
What glue do you suggest?
Best,
Sergio
Old Oct 30, 2012, 11:25 PM
Jet Junky's Avatar
United States, NY
Joined Oct 2012
A10flyer, two outlets can be as efficient as one provided they are large enough, checked the Rafal outlets diameter with my Exceed F-18 and they are about 1/16” smaller so will attempt to make them larger.
Old Nov 01, 2012, 07:24 PM
a10flyer is offline
Joined Apr 2011
Old Nov 05, 2012, 06:32 PM
out of stock is offline
Find More Posts by out of stock
Speed only
out of stock's Avatar
United States, FL, Lehigh Acres
Joined Jan 2012
im ordering one. hope i dont get duplicated
out of stock is offline Find More Posts by out of stock
Old Nov 13, 2012, 07:18 PM
Jet Junky's Avatar
United States, NY
Joined Oct 2012
Build Update 2
Here is an update to the Rafale build, this is my approach to canards & rudder. I sand smooth and apply clear Polymer on intake & exhaust tubes, also use over acrylic paint or mix with for a matt finish, it is great stuff! & protects foam, I get it from rcfoam.com .
Old Nov 13, 2012, 07:41 PM
huntingfield is online now
Find More Posts by huntingfield
Clean up! The missus is home
huntingfield's Avatar
United States, MD, Salisbury
Joined Dec 2007
Originally Posted by Jet Junky View Post
Here is an update to the Rafal build, this is my approach to canards & rudder. I sand smooth and apply clear Polymer on intake & exhaust tubes, also use over acrylic paint or mix with for a matt finish, it is great stuff! & protects foam, I get it from rcfoam.com .
Looking good! I built mine with the non functioning canards. I am sure the canards will really help when coupled with the elevators. I may convert mine at a later date. Please keep us posted!
huntingfield is online now Find More Posts by huntingfield
Old Nov 14, 2012, 11:25 AM
Jet Junky's Avatar
United States, NY
Joined Oct 2012
I couldn’t get enough up travel on the canards so had to cut notches into the top of the
Intakes & sand to shape.
Discussion Crashed my 70mm A7 Corsair II need new airframe. redtail Foamy EDFs 18 Apr 19, 2011 12:06 PM
Mini-Review "Rafale" park flayer EDF by HobbyKing eFly.co.il Foamies (Kits) 5 Feb 28, 2011 03:50 AM
Sold 3 New Hobbyking Hercules 2800kv 70mm EDF motors. T-CAT Aircraft - Electric - Power Systems (FS/W) 3 Jan 13, 2011 07:47 PM
Sold 4 New Hobbyking 70mm EDF units with a three wide blade rotor design. T-CAT Aircraft - Electric - Power Systems (FS/W) 7 Jan 13, 2011 06:59 PM
New Product New Twin 70mm composite Rafale lavochkin Electric Ducted Fan Jet Talk 2 Jul 17, 2009 08:41 PM
