Old Jul 24, 2012, 06:46 PM
Roen is offline
Find More Posts by Roen
United States, VA, Norfolk
Joined Oct 2006
Thanks. I used Testor's spray paint from my local hobby shop. I was originally looking for airbrush paint but the guy at the counter told me it's safe on foam as long as I spray it three feet.
Roen is offline Find More Posts by Roen
Old Jul 24, 2012, 06:49 PM
DonQ8401 is offline
Find More Posts by DonQ8401
Why am I addicted!!!
DonQ8401's Avatar
United States, IL, Columbia
Three feet away? How did you do the waves?
DonQ8401 is offline Find More Posts by DonQ8401
Old Jul 24, 2012, 07:02 PM
Roen is offline
Joined Oct 2006
Yeah, three feet away or it'll eat the foam. I tested the paint on a drop tank that came with the jet to see how it is and found that it was safe to use. The waves were kinda sorta tricky to do but not hard at all...
I just sprayed painted the whole jet with the primary color I wanted which was flat aircraft dark grey. While waiting for the paint to dry, I took two pieces of cardboard paper and cut it up in wavy forms of differing patterns. I only needed four pieces. Then I carefully picked a spot to start the waves...I like starting at the wings and carefully sprayed the wings with the stencil on the wing and worked my way around the jet using each different wave shaped paper.
Old Aug 14, 2012, 11:55 PM
gchrisgo34 is offline
Find More Posts by gchrisgo34
gchrisgo34's Avatar
United States, GA, Jonesboro
Joined Nov 2010
ive been thinking of ordering one of these. how does this model fly?
gchrisgo34 is offline Find More Posts by gchrisgo34
Old Aug 15, 2012, 06:32 PM
Roen is offline
Joined Oct 2006
They fly great as long as you have a decent power setup in it and placing the battery in the right CG location (mostly forward of the canards). I have mines fitted with an RCLander 68mm DPS 4000KV EDF unit powered by an 80A Detrum ESC and Sky Lipo 3300mah 4S battery.
It's pretty fast though not the fastest EDF out there with this setup I have. I haven't clocked the speed of my plane but I say it gets up to a little over 60 mph. I'm able to do loops and some basic aerobatics with mines, but then I have my Rafale modified with functional canards and rudder. AUW is around 1587g.
Old Aug 16, 2012, 07:11 AM
DonQ8401 is offline
DonQ8401's Avatar
Roen,
Do you have pictures of your functional canards? Plus your battery location an overall plane setup.
Cheers
Old Aug 16, 2012, 06:16 PM
Roen is offline
Joined Oct 2006
Originally Posted by DonQ8401 View Post
Roen,
Cheers
Here are my latest pictures of my Rafale. A couple of things has changed from the last pictures I've uploaded to this thread in the last page.
Old Aug 16, 2012, 07:15 PM
DonQ8401 is offline
DonQ8401's Avatar
Roen,
Awesome job... yougot video of the canards?
DonQ
Old Aug 16, 2012, 07:46 PM
Roen is offline
Joined Oct 2006
Roen,
DonQ
Thank you! I can try and make one. I'll post a YouTube video of it.
Old Aug 17, 2012, 05:31 AM
gen3v8 is offline
Find More Posts by gen3v8
gen3v8's Avatar
Australia, NSW, Sydney
Joined Dec 2011
I did not notice this great thread at first. Here is a vid
HK Rafale Maiden (3 min 19 sec)
gen3v8 is offline Find More Posts by gen3v8
Old Aug 18, 2012, 02:35 AM
Junkers Jumo is online now
Find More Posts by Junkers Jumo
Schwalbe
Junkers Jumo's Avatar
Australia, WA, Yokine
Joined Aug 2011
Mark's Rafale
Today another joined this club of what must be the most under appreciated airframe in the history of RC. Mark's has the extreme RC CS10 alloy 4S setup and the original colour scheme as opposed to a paint job, has it about 200g lighter than mine.
Mark's HK Rafale (6 min 45 sec)
As you can see beautiful airframe! (and rather well flown.)
Cheers,
Ingo
Junkers Jumo is online now Find More Posts by Junkers Jumo
Old Aug 18, 2012, 03:03 PM
Roen is offline
Joined Oct 2006
Cool videos! I love how this jet is easy to hand launch.
Anyways, here's a small and quick video of a servo test run in my Rafale.
Hobbyking Rafale Servo testing (1 min 5 sec)
Old Aug 18, 2012, 04:08 PM
gchrisgo34's Avatar
Joined Nov 2010
how do you set up the canards? do you set them up with the elevater? & im guessing you can turn them off during flight? ive never owned a canard plane. i do fly with a dx6i though. thanks
Old Aug 18, 2012, 07:10 PM
Roen is offline
Joined Oct 2006
I also own the DX6i and this plane uses the AR600 six channel receiver. I have the canards set up like elevators and I have the servo connected to the "AUX" slot of the receiver. It can be turned on and off via the "Flap" switch on the DX6i. Programming and mixing of elevator, flaps, and ailerons on the DX6i is required, especially for the canards. I had to use less than 50% expo or servo travel on the canard setup as so it won't hit the airframe and intakes.
Old Aug 18, 2012, 09:46 PM
DonQ8401 is offline
DonQ8401's Avatar
Roen,
Wicked good job. Please zoom in and take a picture with the rod. i am going to steal this design and put it in mine. How does it fly with the canards?
DonQ
Discussion Crashed my 70mm A7 Corsair II need new airframe. redtail Foamy EDFs 18 Apr 19, 2011 12:06 PM
Mini-Review "Rafale" park flayer EDF by HobbyKing eFly.co.il Foamies (Kits) 5 Feb 28, 2011 03:50 AM
Sold 3 New Hobbyking Hercules 2800kv 70mm EDF motors. T-CAT Aircraft - Electric - Power Systems (FS/W) 3 Jan 13, 2011 07:47 PM
Sold 4 New Hobbyking 70mm EDF units with a three wide blade rotor design. T-CAT Aircraft - Electric - Power Systems (FS/W) 7 Jan 13, 2011 06:59 PM
New Product New Twin 70mm composite Rafale lavochkin Electric Ducted Fan Jet Talk 2 Jul 17, 2009 08:41 PM
