Old Dec 02, 2011, 07:51 AM
Tartago is offline
Find More Posts by Tartago
Plane crazy
Tartago's Avatar
Joined Apr 2006
Originally Posted by tweeter1 View Post
I have been patiently waiting to get these struts for my jets
Nice jewels!
Where did you got them?
Tartago is offline Find More Posts by Tartago
Old Dec 02, 2011, 09:49 AM
takiss is offline
Find More Posts by takiss
Patras, Greece
Joined May 2007
Hi.
I want to fly his plane as EDF with retracts.
What is the verdict?
Does it fly and perform or not?
Is it worth the time and cost to build this one?
Thanks for helping
Takis
takiss is offline Find More Posts by takiss
Old Dec 08, 2011, 01:12 AM
Tartago is offline
Plane crazy
Tartago's Avatar
Joined Apr 2006
Originally Posted by takiss View Post
Hi.
Thanks for helping
Takis
I think the scary part is if you receive 2 left wings or 2 right intakes. Happened ver often.
I have my finger on the trigger.
Old Dec 08, 2011, 01:40 AM
takiss is offline
Patras, Greece
Joined May 2007
Hi.
I have a fine kit, but the feeling I have is that it doesn't fly well.
Ozgur confirmed that, so I ask you all if it is worth building this one.
Best
Takis
Old Dec 08, 2011, 08:25 AM
ozgur is offline
Find More Posts by ozgur
ozgur's Avatar
Joined May 2009
Dear Takiss,
My power system is HET fan and 2W-20, these are totally 68+93grams... Also I am using Turnigy plush 60A ESC. Unfortunately I am not happy with its flying characteristic and performance.
Maybe this is because of that I also add fully functional canards, not because of its functions but because of that it occupy some space in the battery area. That's why I am flying a bit nose heavy. In my opinion this plane must be as light as possible, like 900grams maximum, but mine AUW is 1300grams and that is too much.
I don't get the same pleasure while I am flying with my T-45, ok some people would say they have different flying characteristics but what I don't understand is the huge performance difference even T-45 is 64mm.
Lander Rafale might be a good choice but this one is just waste of time unless if you go with pusher prop or keep it around 800-900grams.
Ozgur
ozgur is offline Find More Posts by ozgur
Old Dec 08, 2011, 08:34 AM
takiss is offline
Patras, Greece
Joined May 2007
Thanks one more time ozgur.
Takis
Old Dec 15, 2011, 05:28 PM
ozfella is offline
Find More Posts by ozfella
Nasir Khan
Australia, NSW, Fairfield
Joined Feb 2009
Originally Posted by colinski View Post
Hopes were high indeed!
But the pusher setup I flew it with drew a lot of power!
830W at 63A.
That was with a 2836 3200kv HK motor, 5x5 prop, 60A esc and a 25-50c rated nano tech 2200 4sp1.
You guessed it flying time was short!
But it was alot faster and louder than the EDF version!
Did have some trouble with getting it level in flight. But sorted it out after a minute or so.
On the second flight moved cg further to the front, it did not take off right, tried to abort but it did a small hop over someting on the beach and it took off the nose. No more flying that day.
So I guess I should take it back to the drawing board and figure out a new power plant.
A quick question, how did you do the afterburner mod for 4S?
ozfella is offline Find More Posts by ozfella
Old Dec 16, 2011, 09:36 AM
Tartago is offline
Plane crazy
Tartago's Avatar
Joined Apr 2006
Shot.
I will check it. If she flies half as good as the mirage 4000, is worth her price.
Old Dec 19, 2011, 01:44 AM
XSTORM is offline
Find More Posts by XSTORM
France, RA, Saint-Cyprien
Joined Nov 2011
Hi.
Best
Takis
This plane has several important problems
N1
The entry and the air outlet is not good
It is necessary to modify it to have an acceptable return
N2
The quality of the material is really very bad
XSTORM is offline Find More Posts by XSTORM
Old Dec 19, 2011, 06:47 AM
Tartago is offline
Plane crazy
Tartago's Avatar
Joined Apr 2006
I received mine today. I held my breath when opening the bOx.
Orait!! No repeated parts!
Quality looks good.
A bit worried about the comments here.
Old Dec 19, 2011, 06:52 AM
GGRN is offline
Find More Posts by GGRN
One eyed Corsair
GGRN's Avatar
PARIS
Joined Jul 2005
Don't worry about comments. I've received mine too... Held my breath too... And... No repeated parts, nothing broken.
I'm working on new internal aerodynamics able to make this thing a true jetfighter. I'll open a new thread as soon as i'll start working on it. It'll be a real big work !
GGRN is offline Find More Posts by GGRN
Old Dec 19, 2011, 06:41 PM
ozgur is offline
ozgur's Avatar
Joined May 2009
Ok, please post your flying performance with a video... I really would like to read and watch them after your big effort and time on this plane...
Old Jan 17, 2012, 09:25 AM
Psycho Synapse is offline
Find More Posts by Psycho Synapse
Gravity Fighter
Psycho Synapse's Avatar
Springdale, AR
Joined May 2008
Anybody turned one of these into a pusher? Was curious if you would have enough room up front to balance with a 3S 2200 mah battery and motor/prop on tail end. Don't want to have to add weight in the nose. Hand launch/belly lander. No landing gear.
Psycho Synapse is offline Find More Posts by Psycho Synapse
Old Feb 19, 2012, 05:49 AM
GGRN is offline
One eyed Corsair
GGRN's Avatar
PARIS
Joined Jul 2005
Started the work on my HK Rafale... After some verifications, i'm not surprised it's so slow. The Intakes/exhausts ratio is inapropriate and the internal aerodynamics has to be redone.
So, i enlarged the room inside the airframe to install the new fiberglass inlets.
I'll use a true WM 400 70mm EDF with a Jetsceamer 1400. There'll be a single exhaust hidden between the scaled exhausts of the model.
Of course, that's a big work, but i think it's the price to pay to make this kit a true jet !
Old Feb 19, 2012, 06:04 AM
GGRN is offline
One eyed Corsair
GGRN's Avatar
PARIS
Joined Jul 2005
The HK model is a good base to work on. It just needs some esthetic surgery to be more scaled (pointed nose, filling in panels lines that look like trenches, etc.), and some modifications to be more efficient (active canards, powerfull set-up, etc.). Of course, the airframe will be entirely glassed to get a nice smooth finish. I'll also have to do a new nice canopy. The one from the box is crappy and crumbly.
Here are few pics of the airframe. The Mirage 2000 is powered with the same setup and is a great fast flyer.
Discussion Crashed my 70mm A7 Corsair II need new airframe. redtail Foamy EDFs 18 Apr 19, 2011 12:06 PM
Mini-Review "Rafale" park flayer EDF by HobbyKing eFly.co.il Foamies (Kits) 5 Feb 28, 2011 03:50 AM
Sold 3 New Hobbyking Hercules 2800kv 70mm EDF motors. T-CAT Aircraft - Electric - Power Systems (FS/W) 3 Jan 13, 2011 07:47 PM
Sold 4 New Hobbyking 70mm EDF units with a three wide blade rotor design. T-CAT Aircraft - Electric - Power Systems (FS/W) 7 Jan 13, 2011 06:59 PM
New Product New Twin 70mm composite Rafale lavochkin Electric Ducted Fan Jet Talk 2 Jul 17, 2009 08:41 PM
