Old Mar 29, 2011, 02:10 AM
Graham d is offline
Find More Posts by Graham d
South Africa, GP, Pretoria
Joined Mar 2011
Sorry for the quality of the pics, dont have my camera with me but the Black berry will do for now.
Graham d is offline Find More Posts by Graham d
Old Mar 29, 2011, 02:22 AM
tweeter1 is offline
Find More Posts by tweeter1
Joined Feb 2011
Great photos.
Now I can see the pocket where the ESC should be
and the front, rear ducting.
Thanks for your kindness.
absolutely this jet needs to be glassed.
And I like it. After glassing it is light but very strong, solid .
tweeter1 is offline Find More Posts by tweeter1
Reply With Quote  (Disabled)
Old Mar 29, 2011, 02:42 AM
Graham d is offline
Joined Mar 2011
Very nice jet, but I think a lot more work than what I thought. There is no plans but the build should not be too complecated. I will be going with a grey scheme and try my retracts that I have. I have the 6 blade 70mm fan from HK and the 2839 2800KV hk outrunner with 55A turnigy trust esc. Hope this setup will do for this model. I estimate that the AUW will be about 850-900g.
Old Mar 29, 2011, 03:12 AM
pavcon is offline
Find More Posts by pavcon
Κύπρος, Λευκωσία, Πέρα Χωριό
Joined Jan 2010
Originally Posted by tweeter1 View Post
thanks for sharing but the main different between
high and low timing is HEAT, my two cents
my other two cents.. not just HEAT I know about this factor. but because all my testing I hold the fans in my hand I was able to feel the difference.. it's too obvious to ignore
pavcon is offline Find More Posts by pavcon
Old Mar 29, 2011, 03:22 AM
Graham d is offline
Joined Mar 2011
Pavcon,
Is the difference big enough to risk?
tweeter1 is offline
Joined Feb 2011
Some reliable esc makers like Castle creations recommended
low timing for good efficiency. Yes, with high timing you
gain some power but more heat LOL.
even donrc, the motor maker, recommended the same thing.
should I not trust those experts?
Old Mar 29, 2011, 03:38 AM
tweeter1 is offline
Joined Feb 2011
I like this rafale but I already have two other jets in the queue.
An F-5E and a 70mm Mig-15 with e-retracts.
If I build this rafale I would build it light for performance,
no moving canards and no Landing gears. Hand launch or taking
off from grass.
Old Mar 29, 2011, 06:06 AM
ozgur is offline
Find More Posts by ozgur
ozgur's Avatar
Joined May 2009
Graham,
I also want it to be in grey scheme. What paint and what color code are you planning to use? Tamiya color AS-10 ocean grey for upper fuselage and wings and AS-28 medium grey for the bottom part.
I am not sure that French navy Rafale planes are just in one grey color or they are with two different grey tone?
Ozgur
ozgur is offline Find More Posts by ozgur
Old Mar 29, 2011, 06:37 AM
Graham d is offline
Joined Mar 2011
Ozgur,
I do not have too many options as our foam friendly paint is limited in terms of availability. I cannot give you any codes, but it is a lightish grey and I will be looking for a darker grey for the camouflage. Will take a few pics when I am finished. I have decided to scrap the landing gear and will ge going as lite as possible.
Graham
Old Mar 29, 2011, 07:28 AM
ozgur is offline
ozgur's Avatar
Joined May 2009
Functional canards
Is any of you knows steering arm which has 3mm shaft size?
The ones that I found all has 4mm (5/32). I want to use 3mm carbon or music wire push rods for the canards.
Ozgur
Old Mar 29, 2011, 07:43 AM
ozgur is offline
ozgur's Avatar
Joined May 2009
Originally Posted by anthodenn View Post
Hi ozgur. I've been following this thread closely because this jet is really attracting me to buy it too.
Anthony
Dear anthodenn,
How you fixed the bended piano wire into the hollow carbon tube? Did you epoxy glue it? It seems from the photos that you were applying the movement torque to the carbon tube, correct?
Probably you used 4mm outer diameter of carbon tube, if so what was your inner diameter and the dia of piano wire??
Ozgur
Old Mar 29, 2011, 08:18 AM
takiss is offline
Find More Posts by takiss
Patras, Greece
Joined May 2007
Hi ozgur.
Use plastic, bronze or alu tube, insert the piano wire and use wheel collar with 3mm bolt and on the bolt you can screw and "ear" on which the clevis will be inserted. You are gong to imitate the traditional aileron setup with this approach.
http://www.hobbyking.com/hobbyking/s...idProduct=8401
Or use servo horn, insert a wheel collar and ... see post
http://www.rcgroups.com/forums/showt...1#post17101305
Takis
takiss is offline Find More Posts by takiss
Old Mar 29, 2011, 08:31 AM
pavcon is offline
Joined Jan 2010
Pavcon,
there is no risk with the new DPS. RC Lnader is actually rating this new EDF unit "up to 1000watts"
also after 2-3 seconds of continues power at WOT you feel the whole ducts(metal shroud) to cool down.
Old Mar 29, 2011, 08:32 AM
pavcon is offline
Joined Jan 2010
also answered that at my last.. RC landers coolling ROCK
btw that can be confirmed by TimWan ??? maybe the designer of the EDF unit can also be trusted ???
Old Mar 29, 2011, 09:17 AM
JGuilty13 is offline
Find More Posts by JGuilty13
JGuilty13's Avatar
United States, MI, Rochester Hills
Joined Nov 2005
Graham D, do your fuse halves not sit together snuggly? Mine required a decent amount of sanding for them to sit flat against one another.
JGuilty13 is offline Find More Posts by JGuilty13
Discussion Crashed my 70mm A7 Corsair II need new airframe. redtail Foamy EDFs 18 Apr 19, 2011 12:06 PM
Mini-Review "Rafale" park flayer EDF by HobbyKing eFly.co.il Foamies (Kits) 5 Feb 28, 2011 03:50 AM
Sold 3 New Hobbyking Hercules 2800kv 70mm EDF motors. T-CAT Aircraft - Electric - Power Systems (FS/W) 3 Jan 13, 2011 07:47 PM
Sold 4 New Hobbyking 70mm EDF units with a three wide blade rotor design. T-CAT Aircraft - Electric - Power Systems (FS/W) 7 Jan 13, 2011 06:59 PM
New Product New Twin 70mm composite Rafale lavochkin Electric Ducted Fan Jet Talk 2 Jul 17, 2009 08:41 PM
