Old Mar 25, 2011, 04:36 AM
pavcon is offline
Find More Posts by pavcon
Κύπρος, Λευκωσία, Πέρα Χωριό
Joined Jan 2010
Originally Posted by tweeter1 View Post
the price of 2w-20 is about few dollars more expensive than MB-1 but
it is more efficient as an inrunner, also lighter. So I would
go for the 2w-20 and het fan.
very good choice.
you won't regret it.. and you will probably cruise around at half throttle
I also tested this fan at 91.000+rpm and it survived just fine... only my first impreller flew off on testing because I didn' tscrew it on well so be carefull
pavcon is offline Find More Posts by pavcon
Old Mar 25, 2011, 05:33 AM
ozgur is offline
Find More Posts by ozgur
ozgur's Avatar
Joined May 2009
Guys,
Thank you very much to both of you for the valuable informations. I just placed the order from http://www.highendrc.com for 2W-20 + HET 6904. All my batteries are 4S, that will be a good setup to use them indeed.
Now one another issue I have to clarify. Takiss already told the front strut something like 13cm. But that 13cm is from the bottom of the fuselage till to wheel axle or up to ground? That is important. Front strut must be with 2 wheel setup.
Ozgur
ozgur is offline Find More Posts by ozgur
Old Mar 25, 2011, 12:21 PM
tweeter1 is offline
Find More Posts by tweeter1
Joined Feb 2011
Originally Posted by pavcon View Post
very good choice.
91.000+rpm? never know that.
very interesting.
Mind to share details? motor? esc? fan? amps? wattage?
Good to know
thx.
tweeter1 is offline Find More Posts by tweeter1
Reply With Quote  (Disabled)
Old Mar 25, 2011, 01:38 PM
JGuilty13 is offline
Find More Posts by JGuilty13
JGuilty13's Avatar
United States, MI, Rochester Hills
Joined Nov 2005
Just came in the mail, here are a few pics. The other jet on the pool table is the Starmax F5 for size comparisons. Absolutely no instructions for anything.
JGuilty13 is offline Find More Posts by JGuilty13
Old Mar 25, 2011, 02:13 PM
smasher41 is offline
Find More Posts by smasher41
United States, GA, Snellville
Joined Nov 2005
thanks for the PICS!!!
looks very nice, sucks they gave you no decals or manual for CG though?
I do like the retract wells for the mains, guess the rotating retracts like the arc f-18 would work ( disable the rotation and lock them), but it appears they didnt make the foam for the front retract bay/ mount huh.
doesnt look like a 4 blade fan to me, just one of the overstock of 3 blade pusher fans LOL.
smasher41 is offline Find More Posts by smasher41
Old Mar 25, 2011, 02:32 PM
tweeter1 is offline
Joined Feb 2011
wow, thanks for the photos.
Very nice ducting, I like it.
The stock fan looks like a copy of Velocity-RC WM400MK2, not a bad fan
see video
Velocity-RC WM400MK2 and WM300 EDF Testing (1 min 18 sec)
also, you may try this CG calculator for delta wing jet with canards, hope
that helps. http://adamone.rchomepage.com/cg_canard.htm
Look like EPS foam to me, I love EPS foam much more than EPO.
Yeah. I might get one for me, $42 airframe + $36 shipping to US is not bad at all
Old Mar 25, 2011, 02:44 PM
pavcon is offline
Joined Jan 2010
very interesting.
Good to know
thx.
motor.. hoffman magnetics THE BEAST 4130kv
ESC Turnigy Kforce 100amp 150amp burst at highest timing (there are 6 timiing settings/even at the 5th it gets out of sync)
137amps
2330watts
battery 4000mah 5S 45c-90c nano tech
or zippy flightmax 5S 40C-50C 4000mah..
Old Mar 25, 2011, 02:46 PM
pavcon is offline
Joined Jan 2010
NICE PICS REtract ready stuff
I just loved the airframe even more
Old Mar 25, 2011, 02:48 PM
tweeter1 is offline
Joined Feb 2011
I think they do make the foam blocks for retract bays, see photo.
It is nice, just use those blocks to seal the bays and hand launch.
Old Mar 25, 2011, 02:53 PM
tweeter1 is offline
Joined Feb 2011
very interesting.
Good to know
thx.
137amps
2330watts
your set up is max around 55,000-57,000 rpm, not 91,000rpm like you said.
No way, impossible. Unless it is a miracle of yours. Not physics
Old Mar 25, 2011, 03:04 PM
pavcon is offline
Joined Jan 2010
very interesting.
Good to know
thx.
I will try to measure again.. unless my tachometer is wrong.
Old Mar 25, 2011, 03:12 PM
tweeter1 is offline
Joined Feb 2011
I just look at those photos again. WOW.
It is a very VERY NICE and complete kit, even has wood base
mounts for retracts.
And I visit HK site, they offer me the airframe for ~$40 + $36 shipping
Shall I ???
Old Mar 25, 2011, 03:43 PM
pavcon is offline
Joined Jan 2010
you shall.. already too late now that Ive seen the ready moulded places for retracts i think I'm gonna order another one let's hope it balances well with the CG and a good 2650 and 3000mah battery pack.
Old Mar 25, 2011, 03:47 PM
Joined Nov 2005
whoops, i mean there is no precut out for the front retract, looks like the nose gear will be a total DIY mod ( no wheel well for the gear to go in when retracted or mount to), yet the rears have the plugs to close of retract wells.
think one thing, type another... it happens
Old Mar 25, 2011, 03:50 PM
ozgur is offline
ozgur's Avatar
Joined May 2009
Of course don't even think twice...
Thanks for the photos Jguilty13, they are amazing especially the retract bays perfect... So retract mod will be not so much hard... Its absolutely sure that I am going to use the ARC F-18 struts with lander e-retracts... Only I am stuck to painting the fuselage to navy grey or not... This plane must be in grey color.
Ozgur
Discussion Crashed my 70mm A7 Corsair II need new airframe. redtail Foamy EDFs 18 Apr 19, 2011 12:06 PM
Mini-Review "Rafale" park flayer EDF by HobbyKing eFly.co.il Foamies (Kits) 5 Feb 28, 2011 03:50 AM
Sold 3 New Hobbyking Hercules 2800kv 70mm EDF motors. T-CAT Aircraft - Electric - Power Systems (FS/W) 3 Jan 13, 2011 07:47 PM
Sold 4 New Hobbyking 70mm EDF units with a three wide blade rotor design. T-CAT Aircraft - Electric - Power Systems (FS/W) 7 Jan 13, 2011 06:59 PM
New Product New Twin 70mm composite Rafale lavochkin Electric Ducted Fan Jet Talk 2 Jul 17, 2009 08:41 PM
