Old Mar 11, 2011, 08:53 AM
JGuilty13 is offline
Find More Posts by JGuilty13
JGuilty13's Avatar
United States, MI, Rochester Hills
Joined Nov 2005
New Product
New HobbyKing 70mm Rafale airframe!!!
Finally, a single 70mm Rafale airframe only kit. Had to order one!!
https://www.hobbyking.com/hobbyking/...dProduct=14791
JGuilty13 is offline Find More Posts by JGuilty13
Old Mar 11, 2011, 08:58 AM
ciscovet is offline
Find More Posts by ciscovet
Joined Jan 2009
Could you do 5s in that model?
ciscovet is offline Find More Posts by ciscovet
Old Mar 11, 2011, 09:09 AM
JGuilty13's Avatar
Joined Nov 2005
Im sure you could, the description states that there is plenty of battery room.
Old Mar 11, 2011, 10:00 AM
Vapor Trails is offline
Find More Posts by Vapor Trails
DFC~ We Do Flyin' Right
Vapor Trails's Avatar
USA, GA, Atlanta
Joined Nov 2008
functioning canards?
Vapor Trails is offline Find More Posts by Vapor Trails
Latest blog entry: New Drone Movie :D
Old Mar 11, 2011, 10:14 AM
JGuilty13's Avatar
Joined Nov 2005
No, canards are not functioning. Here is the description:
The Hobbyking Rafale EDF is an excellent, high detail EPS kit of the unique Delta Wing French fighter, which includes features such as, highly detailed, moulded panel lines and scale ordenance, fixed under-carriage if required (also suitable for hand launching or electric retracts - not included), high speed 70mm 4 blade fan unit and a removable fan cover. The battery compartment has plenty of room for a wide choice of Lipoly batteries and a flat canopy underside that does not restrict the depth of the compartment.
This jet is a nice size, big enough to have presence in the air, small enough to be easily transported.
Specification:
Wingspan: 750mm
Length: 1045mm
Height: 305mm
EDF: 70mm
Includes:
Optional Fixed Undercarriage
Hardware pack
70mm Fan Unit
Decal Sheet
Required:
Your own Tx & Rx (elevon mixing required)
2200mah~3000mAh 11.1v 3s~14.8v 4s Lipoly
28mm EDF motor to suit 3.17mm shaft
40A~60A ESC
2~3 9g Servos
1 x 30cm Ext Lead
2 x 45cm Ext Lead
* Please note, the canards are fixed for ease of set up and flying.
Old Mar 11, 2011, 10:21 AM
tweeter1 is offline
Find More Posts by tweeter1
Joined Feb 2011
This is a great airframe that could handle high load so there is no
issue with adding the eflight e-retracts :-)
that would be awesome.
And wow I love the light EPS foam :-)
tweeter1 is offline Find More Posts by tweeter1
Reply With Quote  (Disabled)
Old Mar 11, 2011, 11:17 AM
JGuilty13's Avatar
Joined Nov 2005
What retracts are these from and where can they be purchased? Thanks.
Old Mar 11, 2011, 12:37 PM
Dark Angel is offline
Find More Posts by Dark Angel
skunkworks
Dark Angel's Avatar
United States, CA, Clovis
Joined Apr 2008
Pretty cool looking man!
Dark Angel is offline Find More Posts by Dark Angel
Old Mar 11, 2011, 01:18 PM
tweeter1 is offline
Joined Feb 2011
that is the 70mm Mig-15 retracts but I think
It is perfect for this 70mm rafale. Here it is
http://rc-castle.com/shop/product_in...oducts_id=1735
Old Mar 11, 2011, 01:57 PM
smasher41 is offline
Find More Posts by smasher41
United States, GA, Snellville
Joined Nov 2005
almost pulled the trigger on that one...... must resist.....
I really dont have anywhere to put it right now anyways, got a stack of planes to build already.
smasher41 is offline Find More Posts by smasher41
Old Mar 11, 2011, 06:41 PM
ApexAero is offline
Find More Posts by ApexAero
Aka: Tom Jenkins
ApexAero's Avatar
United States, FL, West Palm Beach
Joined Aug 2008
Take care in the front area where the nose meets the intakes, this is where it snaps off at almost the drop of a hat, if you're going to use retracts it'll fly ok I believe as the wing will carry pretty much what you put on it with a bit of reinforcement but I'd recommend some stringers embedded through the front fuse to lock it all in. I've rebuilt one a few times fro a friend, now it sports a f-35 nose melded to the main wing part thats left. EDF removed and pusher added? He's happy and it works for him now...
ApexAero is offline Find More Posts by ApexAero
Old Mar 12, 2011, 10:50 PM
Joined Nov 2005
Apex, thanks for the insite, any idea who is the real manufacturer of this airframe?
also, HK states the use of optional electric retracts, yet none of the pictures even show where ANY of the landing gears mount. Is there even enough room to carve out foam for the Etracts?
Im very interested in this one but would like more info before i buy it.
Old Mar 12, 2011, 11:28 PM
pavcon is offline
Find More Posts by pavcon
Κύπρος, Λευκωσία, Πέρα Χωριό
Joined Jan 2010
Yes I'm also interested in retracts..
any DSR- that are compatible with this jet?
pavcon is offline Find More Posts by pavcon
Old Mar 13, 2011, 01:01 PM
tweeter1 is offline
Joined Feb 2011
the delta wing with canards jet, like this rafale, gripen, typhoon, j-10 or even
the mirage, is perfect for e-retracts and small field.
1/ airframe has great lift but draggy though.
2/ no issue carry extra load of retracts
3/ can take off and land with shorter field with high alpha.
3/ look great in the air doing low speed, high alpha pass
Old Mar 13, 2011, 02:45 PM
pavcon is offline
Joined Jan 2010
still .. any DSR-? compatibles from Hobbyking?
are there ready molded slots or do we need maor mods to install them?
Discussion Crashed my 70mm A7 Corsair II need new airframe. redtail Foamy EDFs 18 Apr 19, 2011 12:06 PM
Mini-Review "Rafale" park flayer EDF by HobbyKing eFly.co.il Foamies (Kits) 5 Feb 28, 2011 03:50 AM
Sold 3 New Hobbyking Hercules 2800kv 70mm EDF motors. T-CAT Aircraft - Electric - Power Systems (FS/W) 3 Jan 13, 2011 07:47 PM
Sold 4 New Hobbyking 70mm EDF units with a three wide blade rotor design. T-CAT Aircraft - Electric - Power Systems (FS/W) 7 Jan 13, 2011 06:59 PM
New Product New Twin 70mm composite Rafale lavochkin Electric Ducted Fan Jet Talk 2 Jul 17, 2009 08:41 PM
