Old Mar 11, 2011, 12:01 AM
CADGURU is offline
Find More Posts by CADGURU
CADGURU's Avatar
United States, TX, Arlington
Joined Feb 2011
Mini-HowTo
Build a Fuselage Jig
Lacking any sort of jig or a magnetic building board, I decide I needed to make one. I don't have a fancy wood shop and am some what limited on tools.
After seeing some jigs online, I decided a "Slot jig" would be the easiest to fabricate with the tools I have.
After a quick trip to the hardware store, I obtained the following Items:
1) 12 x 48 Malamine board
2) Fourteen 4" Right angle brackets, All checked in store for squareness
3) Fourteen 1/4 - 20 x 1" Carriage bolts.
4) A box of 1/4 - 20 wing nuts - Cheaper by the dozen
Tools Required:
A) Router
B) 1/4" Down-spiral straight cutter / slot cutter bit
C) 3/4" Straight cutter bit
D) 16" Clamp guide fence
E) Triangle Square
F) Sliding Square
G) Pencil
H) Razor Knife
I) Clamps
J) Scrap support blocks
K) 36" T Square - not required but helpful.
Steps:
First mark a center-line in the exact center of the board. The sliding-square is helpful for this. First with pencil and then using a T-square and a Razor knife, razor the line in - not to deep, This make a permanent accurate center line.
Then mark perpendicular lines for each slot 3" on center.
The mark the beginning and ending point of each slot.
Near the edge - not so close the board will break, near the middle close enough so that the brackets can close all the way together. use the sliding square to mark each start of each slot, then adjust it to mark the end of each slot.
Put the board on blocks and clamp it down so its not likely to move or shift
Using the 16" clamp guide fence Route each slot in two passes; 1/2 the depth on each pass.
Flip the board over and clamp it down again.
Route each recess for the bot heads. I used the slot cutter in the slot to locate where to put the clamp fence and switched to the 3/4" cutter, and re-calibrated the router depth for each recess EACH TIME However the ensured perfect alignment with the slot and the recess. Depth I used for the recess 5/32"
Clean all the label goo off the angle brackets
Then assemble your jig! and enjoy building straight fuselages!
You may need to use some wood shims and clamps to get everything perfectly straight / plumb
Check out my build log for aircraft I using this jig on.
http://www.rcgroups.com/forums/showt...6#post17612911
You can build fuselages up to: 47" inches long and 8" wide max on this jig.
You could also attach larger hard wood uprights to the angle brackets.
I would love to have an Adjust o Jig; however they seem to rarely come up on eBay anymore. Some day I'll build a magnet board.
Please use all normal safety precautions when using power tools
CADGURU is offline Find More Posts by CADGURU
Old Mar 11, 2011, 09:46 PM
Rusty-Gunn is offline
Find More Posts by Rusty-Gunn
My plans are in my blog
Rusty-Gunn's Avatar
Kotzebue, Alaska
Joined May 2006
Sweet, baby, sweeeeet! I might have to do something like this.
Rusty-Gunn is offline Find More Posts by Rusty-Gunn
Old Mar 12, 2011, 11:58 AM
paullie is offline
Find More Posts by paullie
Are we having fun yet?
paullie's Avatar
USA, NY, Clarence
Joined Jan 2010
This is great! Thanks for sharing. Just in time for my next build.
paullie is offline Find More Posts by paullie
Old Mar 12, 2011, 12:31 PM
Rodney is offline
Find More Posts by Rodney
Florida
Joined Aug 2004
Great job, I did the identical thing about 20 years ago except instead of brackets, I made wooden verticals but fastened in the same manner you did with carriage bolts through the slots. Still using it. Yours looks better than mine does.
Rodney is offline Find More Posts by Rodney
Old Mar 12, 2011, 01:22 PM
bullseye000 is offline
Find More Posts by bullseye000
bullseye000's Avatar
Aurora Municipal, Illinois, United States
Joined Jul 2002
I made a similar one a few years back. Originally used the corner brackets but I bought cheap and discovered some of them were 3 degrees out of square. Wound going with wood instead. I sandwiched 1/4" oak strips between 1/4" sheets of poplar. I then sawed off 4" chunks and trued the sides on a disc sander. The black strips are pieces of rubber weather strips and make up for any the occasional odd shaped piece as well as padding. The main fixture is a 4' shelf from Menards.
bullseye000 is offline Find More Posts by bullseye000
Old Mar 12, 2011, 03:46 PM
CADGURU is offline
CADGURU's Avatar
Joined Feb 2011
Thanks all! Yep it's jigs like you guys have built that inspired me.
Some day soon I will get in a wood shop to make some wooden
Fixtures.
Old Mar 12, 2011, 06:01 PM
jonquinn is offline
Find More Posts by jonquinn
USA, PA, Westmoreland Co.
Joined Aug 2008
very nice work and design
thanks for sharing the idea
jonquinn is offline Find More Posts by jonquinn
Old Dec 19, 2011, 08:00 PM
jbswear is offline
Find More Posts by jbswear
Plane crasher
jbswear's Avatar
United States, MD, Bowie
Joined Nov 2011
So, to bring up an older thread:
I'm thinking about building something like this... How do you "pin" the wood down while you're building? Or does this come into play AFTER you've built your fuse sides? Do I use my balsa building board to construct the sides and then move to this to assemble the two sides together?
jbswear is offline Find More Posts by jbswear
Old Dec 20, 2011, 07:48 AM
TomCrump is online now
Find More Posts by TomCrump
ARFs Are Me
TomCrump's Avatar
Traverse City, Michigan
Joined Dec 2005
I build the sides, and then use the jig when I join them.
TomCrump is online now Find More Posts by TomCrump
Old Dec 21, 2011, 10:12 AM
Rubbernecker is offline
Find More Posts by Rubbernecker
United States, VA, Forest
Joined Nov 2009
I have a set of the jigs (rectangular boxes) that I would let go pretty cheap since I use a magnetic building board now. Send me a pm if you are interested.
John
Rubbernecker is offline Find More Posts by Rubbernecker
Old Dec 21, 2011, 10:37 PM
Mooney_Driver is offline
Find More Posts by Mooney_Driver
Mooney_Driver's Avatar
United States, WA, Benton City
Joined Mar 2004
I see adjusto-jigs come up on here often. The price is usally not cheap though but the ones that show up on ebay seem to be gold plated judging from some of the prices! You did a great job on your fuselage jig. It is interesting to see all of the variations and jig designs show up. I have seen several ads in old magazines (that I never noticed at that time) which no one ever seems to have heard of and must not have been around long but jigs like yours and its variations have stayed the test of time.
I have been watching Brotherhood of the rings as G-Man has some interesting jigs. He has not posted his fuselage jig build yet but here is his wing jig:
http://www.brotherhoodofthering.info...sts=83&start=1
and it is quite a variation but he did an excellent job.
Thank you.
Mooney_Driver is offline Find More Posts by Mooney_Driver
Wanted A-Justo jig "fuselage jig" lla Aircraft - General - Miscellaneous (FS/W) 1 Feb 26, 2011 02:58 PM
Wanted Wanted - AdjustoJig wing and fuselage jig Mooney_Driver Aircraft - General - Miscellaneous (FS/W) 1 Feb 22, 2011 02:14 PM
Sold Adjusto-Jig Wing and Fuselage jig, nice. 90.00 puplover Aircraft - Fuel - Airplanes (FS/W) 5 Feb 12, 2011 06:32 AM
Adjusto Jig Fuselage Add On Dave Willis Aircraft - Electric - Airplanes (FS/W) 3 Aug 16, 2004 01:58 PM
