Old Jul 11, 2009, 06:44 PM
Ron van Sommeren is offline
Find More Posts by Ron van Sommeren
homo ludens modellisticus
Ron van Sommeren's Avatar
Netherlands, GE, Nijmegen
Joined Feb 2001
Added to first post
Brushless controller for Control Line:
http://www.pek.nu/pekproj/proj/el/sc/
Discussion:
http://www.svensktmodellflyg.se/foru...entMainTopic=2
Ron van Sommeren is offline Find More Posts by Ron van Sommeren
Old Oct 14, 2009, 10:14 AM
Joined Feb 2001
Added
OSMC projekt kits:
http://www.robotpower.com/
Discussion group:
www.yahoogroups.com/group/osmc
Old Jan 20, 2010, 12:13 PM
AL3xGR is offline
Find More Posts by AL3xGR
Greece
Joined Nov 2009
If someone made it can he post a pic?
AL3xGR is offline Find More Posts by AL3xGR
Old Jun 15, 2010, 12:12 PM
AL3xGR is offline
Greece
Joined Nov 2009
23 and 24(a) are broken
Old Aug 09, 2010, 10:30 AM
ali1980 is offline
Find More Posts by ali1980
Joined Jun 2010
hi guys I wanna to build 60A ESC for 1700KV brushless motor ..so i need the suitable single side PCB and circuit schematics ...thanks
ali1980 is offline Find More Posts by ali1980
Old Aug 09, 2010, 04:50 PM
jglenn is offline
Find More Posts by jglenn
Ohio
Joined Nov 2003
You will find you need a double sided board.
I am intrigued by you guys making ESC's. For just one, it has to cost 2 or 3 times the cost of just buying one. Getting the parts and pcb, soldering, testing,
learning why they blow up. Brushed ones are easy, brushless are hard.
jglenn is offline Find More Posts by jglenn
Old Aug 10, 2010, 01:12 PM
robe_uk is offline
Find More Posts by robe_uk
Metallica
robe_uk's Avatar
Londonderry UK
Joined Nov 2004
sometimes the journey is more interesting than the destination.
robe_uk is offline Find More Posts by robe_uk
Old Aug 09, 2011, 07:25 AM
Joined Feb 2001
Several schematics of commercial controllers in these threads
http://www.rcgroups.com/forums/showthread.php?t=766589
http://www.rcgroups.com/forums/showthread.php?t=1401408
Open source projects:
http://open-bldc.org/wiki/Open-BLDC
http://forums.openpilot.org/
Vriendelijke groeten Ron
diy motor tips Drive Calculator
diy motor group Cumulus MFC
Old Sep 08, 2011, 10:05 PM
Iceflow is offline
Find More Posts by Iceflow
Joined Aug 2011
Hi. In the sensorless zone the 18 and 19 links are dead
micro motor controller
http://www.rcgroups.com/forums/showthread.php?t=261316
1.57gr brushless controller
http://home.foni.net/~c-schlabitz/Floh/
http://home.versanet.de/%7Eb-konze/blmc_flea/blmc.htm
At least i cant enter it...
Iceflow is offline Find More Posts by Iceflow
Old Sep 09, 2011, 12:01 AM
matttay is offline
Find More Posts by matttay
Joined May 2003
May I suggest you add this design referenced here?
http://www.rcgroups.com/forums/showthread.php?t=1417864
I've converted this into an 80V/200A design and I'll say their SW is very, very good and very well documented (source and schematic for sensored and sensorless). And you can control it in the other room as it has an ethernet controller built in . Or connect it to your car via CAN interface.
In any case, the kit's available from digikey. Get a scope and their free compiler and you'll be spinning motors in no time, tweaking source, etc.
PS. Most interesting about their source is how well protected it is against faults. If anyone has ever taken a CC controller and connected to a wheel of some kind, you'll see very quickly a $100 controller smoke and burn. And do it again to a second controller later that afternoon.
This design is very rugged. It has current sense on all 3 branches, and enough SW settings that you can really dial in what you want. Over current, under current, max current during acceleration, acceleration rate, dead time, etc. Dozens of parameters to tweak.
Extremely educational. I've augmented their SW and can know with certainty the phase currents, bus voltage and duty cycle via ethernet at 50 mS intervals. Too cool.
One interesting learning that goes back to the massive thread on peak versus average current...A 180A phase current happens while a wattsup meter will be reporting just 28A. I have buckets of cool waveforms.
matttay is offline Find More Posts by matttay
Old Sep 09, 2011, 06:00 AM
George Shering is offline
Find More Posts by George Shering
Scotland
Joined May 2005
Interesting, which thread is that? What was the PWM ratio and time on your 180/28 A test?
George Shering is offline Find More Posts by George Shering
Old Sep 09, 2011, 11:44 AM
matttay is offline
Joined May 2003
It was this thread:
http://www.rcgroups.com/forums/showthread.php?t=551079
The peak versus average occurs when you are just starting up an electric bike (220 pounds AUW including rider in this case), for example. In the attached graph, there are the following curves: Green is the max phase currents (all 3 phases recorded) during PWM on. It's a bit noisy, but I've since cleaned up the ADC readings and verified by manually reading across 3 ohm sense resistor. It is indeed around 160A.
But the inline fluke (in this case) is reporting 29A.
However, look at the duty cycle, which is the middle ramp trace. This is duty cycle ranging from about 25% to 40%. The very bottom ramp is RPM. And the blue is bus voltage.
Now, the phase current reported is the MAX during the on time. So it's a bit pessimistic compared to RMS.
But this is another indicator that inline meters at partial throttle are miles away from what is actually happening. In this particular case, I'm learning that a 100A startup current when duty cycle is low can mean 1000A peak inductor current for 10's of uS if you are trying to start quickly.
Old Aug 26, 2012, 10:47 AM
h_e_c is offline
Find More Posts by h_e_c
Joined May 2012
h_e_c is offline Find More Posts by h_e_c
Old Feb 12, 2014, 03:00 AM
Joined Feb 2001
Open Source Firmware for ATmega-based Brushless ESCs. This tree contains Atmel AVR assembly code for ATmega-based 3-phase sensor-less motor electronic speed control (ESC) boards ...
github.com/sim-/tgy
in combination with this active development thread
www.rcgroups.com/forums/showthread.php?t=1513678
Features
  • 16MHz operation on most boards
  • 16-bit output PWM with full clock rate resolution (~18kHz PWM with a POWER_RANGE of 800 steps)
  • 24-bit timing and PWM pulse tracking at full clock rate resolution
  • ICP-based pulse time recording (on supported hardware) for zero PWM input control jitter
  • Immediate PWM input to PWM output for best possible multicopter response (but NOT where soft start or really any significant current limiting is needed!)
  • Accepts any PWM update rate (minimum ~5microseconds PWM low time)
  • Optimized interrupt code (very low minimum PWM and reduced full throttle bump)
  • Configurable board pin assignments by include file
  • Smooth starting in most cases
  • Forward and reverse commutation supported, including RC-car style reverse-neutral-forward PWM ranges, with optional braking
Vriendelijke groet Ron
www.rmvc-cumulus.nl
Old Feb 12, 2014, 11:52 AM
clicky is offline
Find More Posts by clicky
UK
Joined May 2007
Looks impressive. Apologies if it is stupid question - but what about governor (mode)?
For little (and bigger) helicopters that's one of the most desirable function.
clicky is offline Find More Posts by clicky
Diy brushless esc slowflyer90 DIY Electronics 66 Mar 25, 2006 07:56 AM
Best DIY Brushless ESC Kit? gfcermak DIY Electronics 10 Aug 25, 2004 01:23 AM
group order for diy Speedy-BL brushless ESC family Ron van Sommeren Electric Plane Talk 5 Jul 27, 2003 10:56 AM
