Old Sep 12, 2004, 10:03 AM
Takao Shimizu is online now
Find More Posts by Takao Shimizu
Tokyo, Japan
Joined Nov 2002
Step by step BL-ESC programming technique
I have tons of question e-mails for BL-ESC control technique description.
The attached file shows the step by step programming of my BL-ESC design.
Also, C8051F330 mixed signal processor function block diagram of BL-ESC control is attached.
Basically, I use a comparator with software select input multiplexer with 100nS responce for BL-ESC control.
; Copyright (C) 2004 by Takao
; All rights reserved.
; FILE NAME : BL_ESC_01.ASM
; DESCRIPTION : Simple MOS FET driver test program for motor run as a stepping motor
; NOTES: This test program does NOT have current limitter function.
; : Use the current limitter to protect the motor coil.
; : Do not run over 5 sec. to avoid the over heat.
; FILE NAME : BL_ESC_02.ASM
; NOTES: This program has current limitter function. The On/Off duty is 1:6(16%), frame = 150uS.
; : But, use the hardware current limitter to protect the motor coil for single step debug.
; : Do not run over 15 sec. to avoid the over heat.
; : Check the round direction while running and correct the motor wire connection.
; FILE NAME : BL_ESC_03.ASM
; DESCRIPTION : Simple MOS FET driver program for BL motor start run as a stepping motor
; NOTES: Improve the start stepping sequence by sweep frame timing control at starting
; FILE NAME : BL_ESC_04.ASM
; DESCRIPTION : BL motor start run + Sampling comparator data drive.
; NOTES: Get comparator data from motor leads while 3-ST timing and drives motor with corresponding drive pattern.
; FILE NAME : BL_ESC_05.ASM
; DO NOT USE this for latest precision zero cross detector circuit schematic.
; DESCRIPTION : BL motor start run + Sampling comparator data drive + Zero Cross switching drive.
; NOTES: Improve BEMF pattern detector by noise check routine.
; Stepping start + BEMF run + Zero Cross switching drive
Takao
Originally Posted by Ron van Sommeren
Takao Shimizu's design, source code and schematic:
http://www.rcgroups.com/forums/showp...&postcount=153
Takao Shimizu is online now Find More Posts by Takao Shimizu
Old Sep 12, 2004, 10:52 PM
CLEMENT is offline
Find More Posts by CLEMENT
Joined Sep 2004
thx
CLEMENT is offline Find More Posts by CLEMENT
Old Sep 28, 2004, 07:37 AM
rtrujillo is offline
Find More Posts by rtrujillo
Joined Apr 2004
Originally Posted by Mr DIY
Ron ... these additions are commercially driven controllers. No circuits available without paying for them. They are of little value to somebody that wants a schematic to learn how the system works. I will admit my frustration in following a link from here only to find the information I am hoping to find is not available. Just my 2c.
Mr. DIY,
How about posting schematics or board layouts of some of your developments?
Best,
R. Trujillo
rtrujillo is offline Find More Posts by rtrujillo
Old Sep 28, 2004, 07:51 AM
Mr DIY is offline
Find More Posts by Mr DIY
Mr DIY's Avatar
South Africa
Joined Aug 2003
Mr. DIY,
It is my intention to do so. I am trying to create some documentation at present to go along with the design that will explain everything in more detail than what we normally see here. Most people refer to the AN857 app note. I would like to create an alternative document that is more applicable to us.
But .. the main reason I have not posted it yet is because very few people here would be able to duplicate it. I am using a CPLD device that requires special hardware and SW to program it. The CPLD device could be replaced with another micro though, but then a new PCB layout would be required. Hopefully it will not be too long now before something is seen here.
Brian
Mr DIY is offline Find More Posts by Mr DIY
Old Oct 09, 2004, 09:34 PM
Tokyo, Japan
Joined Nov 2002
MY BL-ESC development tools
This is my BL-ESC software development tools.
I have designed the BAD Li-Po simulator power supply as almost 4C 700mAh Li-Po.
Old Oct 09, 2004, 09:36 PM
Tokyo, Japan
Joined Nov 2002
BL-ESC Drive wave form
This is the ACW CD-ROM BL-ESC full power drive wave form.
Old Oct 11, 2004, 04:10 AM
Ron van Sommeren is offline
Find More Posts by Ron van Sommeren
homo ludens modellisticus
Ron van Sommeren's Avatar
Netherlands, GE, Nijmegen
Joined Feb 2001
Added:
TVE
http://www.hanfordsite.com/
Ron van Sommeren is offline Find More Posts by Ron van Sommeren
Old Oct 14, 2004, 05:44 AM
Joined Feb 2001
Added a micro ESC;
http://www.rcgroups.com/forums/showthread.php?t=261316
Old Nov 25, 2004, 02:34 PM
funflyRI is offline
Find More Posts by funflyRI
Joined Nov 2004
MR DIY
phone me and ill try to anser ur questions Kevin 0723789349 only in the RSA
funflyRI is offline Find More Posts by funflyRI
Old Apr 02, 2005, 09:45 AM
Joined Feb 2001
An online course on magnetism/flux, motors and ESC's:
http://www.consult-g2.com/course.html
Old May 25, 2005, 10:33 AM
Joined Feb 2001
Added more motor and controller theory:
http://www.innovatia.com/
http://www.innovatia.com/Design_Cent...lectronics.htm
Vriendelijke groeten Ron van Sommeren
e-motor building tips & tricks
diy outrunner discussion group
int. E fly-in & diy outrunner meet, September, Nijmegen, the Netherlands
Old May 30, 2005, 04:43 PM
Joined Feb 2001
Added this 'Quax' controller link:
http://people.freenet.de/khruehlow/
Old Jun 14, 2005, 07:19 PM
PaulPounds is offline
Find More Posts by PaulPounds
Joined Mar 2005
Lipoly step current
Hi,
I'm in the midst of completing a brushless speed controller board for a research project. I've found that when I send my motor step commands (ie. go from one set value to another, non-contiguous value) the motor instantaneously demands a large current.
Of course, Li+poly batteries don't like being run down like that. Does anyone know how to stop the cells doing this elegantly, or how commercial units do it?
cheers,
-Paul
PaulPounds is offline Find More Posts by PaulPounds
Old Jun 15, 2005, 07:24 AM
Joined Feb 2001
Beter give it a separate thread Paul, more people will see it. And I intended this thread to be a compilation thread only.
Old Jul 07, 2005, 10:32 AM
Joined Feb 2001
Added:
http://frederic.brame.free.fr/variat...0brushless.htm
Diy brushless esc slowflyer90 DIY Electronics 66 Mar 25, 2006 07:56 AM
Best DIY Brushless ESC Kit? gfcermak DIY Electronics 10 Aug 25, 2004 01:23 AM
group order for diy Speedy-BL brushless ESC family Ron van Sommeren Electric Plane Talk 5 Jul 27, 2003 10:56 AM
