Old Mar 10, 2011, 09:57 PM
rawUAV is offline
Find More Posts by rawUAV
rawUAV's Avatar
Joined Mar 2011
Build Log
SIG Kadet Mark II-Electric_reconfigure aileron w/flaps
Hello all. Fist post, some pics (to follow). Taking suggestions.
rawUAV is offline Find More Posts by rawUAV
Old Mar 10, 2011, 10:14 PM
corsair nut is offline
Find More Posts by corsair nut
fly like an EAGLE ;)
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
i loved mine coverted. my mkII was about 20 years old when i crashed it due to a dead rx pack. but, i was using a 900KV 35-42 motor on a 12x6E with a 4s 5000. right about the same power as a decent .40, and my longest flight was 26min!!!!!! touch and goes all day long. this was the plane that my dad built to teach me how to fly. i was 6 when he built it, and 28 when i crashed it. who knows how many hundreds of flights it had.
good luck, and ill try to help any way i can.
corsair nut is offline Find More Posts by corsair nut
Old Mar 12, 2011, 08:51 PM
rawUAV is offline
rawUAV's Avatar
Joined Mar 2011
Thanks for the interest. I am building this for/with my brother (doc993). This will initially run a Monster Power 32 Outrunner. My bro will set up the guts.
I built a Kadet Jr. in 1988. doc993 converted it to electric recently and has been flying it with his video cam.
Link to his post: http://www.rcgroups.com/forums/showp...85&postcount=7
I have extended the D-box one rib. I upgraded the vertical sheet on this to 3/16" from 1/8". the extension is 1/8". I am considering more extension, but am concerned about weight due to the trailing parts (more later).
Old Mar 12, 2011, 08:55 PM
paullie is offline
Find More Posts by paullie
Are we having fun yet?
paullie's Avatar
USA, NY, Clarence
Joined Jan 2010
Looking good! I'm getting ready to start my Kadet Senior kitbash. flaps/ailerons with twins all on floats.
It'll be fun to watch your build come together.
paullie is offline Find More Posts by paullie
Old Mar 12, 2011, 09:28 PM
rawUAV is offline
rawUAV's Avatar
Joined Mar 2011
Trailing edge photos
I decided to use 1 1/2"trailing edge to both replace the 1 1/8" stock provided for ailerons and to fill in under the trailing sheet replacing the stock back edge. I hope this wing doesn't get too heavy! You can see in the pics, I am planning to cut out some material. I'm not sure if this will help much with the weight, however the wood selected for the fill is very stiff balsa and I will be able to bend it this way. (Left side has a slight warp.)
Old Mar 12, 2011, 09:33 PM
rawUAV is offline
rawUAV's Avatar
Joined Mar 2011
one more that wouldn't post...
preparing cut-outs
note: D-box sheet thickness,
Old Mar 13, 2011, 09:08 AM
doc993 is offline
Find More Posts by doc993
doc993's Avatar
United States, WI, Stoddard
Joined Dec 2009
Wow that looks great, I doubt you will add enough weight to affect the performance.But continue to do what you do best .
These brush less motors are very power full, wow flaps very cool slow flight.
doc993 is offline Find More Posts by doc993
Old Mar 13, 2011, 08:14 PM
rawUAV is offline
rawUAV's Avatar
Joined Mar 2011
Thanks! I decided to center the flaps to the two respective ribs.
Old Mar 29, 2011, 08:06 AM
etotheo is offline
Find More Posts by etotheo
etotheo's Avatar
Saskatoon, SK.
Joined Oct 2009
I have an old MkII that's still on glow that I've been considering conversion to EP...
Nice mod raw. Looking forward to the finished product.
etotheo is offline Find More Posts by etotheo
Old Apr 13, 2011, 08:50 AM
doc993 is offline
doc993's Avatar
Joined Dec 2009
Yo Raw, look's great!This also means your computer is now assembled.
Don't get to crazy weighing every thing, it will drive you nuts.Keep building,we probably wont have it flying till next year,. but it's going to be awesome.Later.
Old Apr 13, 2011, 08:51 AM
doc993 is offline
doc993's Avatar
Joined Dec 2009
Paullie Got pic's?
Old Apr 14, 2011, 09:52 PM
paullie is offline
paullie's Avatar
USA, NY, Clarence
Joined Jan 2010
Originally Posted by doc993 View Post
Paullie Got pic's?
Paullie has been overwhelmed with real life and has a sad looking empty build bench. I can only watch while this beauty gets done. Soon enough though, soon enough. I finally recevied all the electrics for the twin motor setup last week. That did help light the fire a bit.
Old Apr 15, 2011, 11:59 AM
doc993 is offline
doc993's Avatar
Joined Dec 2009
Twin motor set up? Now I'm interested, I'm putting a contra rotating set up in my Bugatti.
Old Apr 15, 2011, 06:54 PM
paullie is offline
paullie's Avatar
USA, NY, Clarence
Joined Jan 2010
I thought about messing around with contra rotating and but research done here on rcg led me to believe that it wasn't really necessary, so I won't.
That being said, Now I'm interested in yours. Link for build log of your Bugatti?
For Sale Sig Kadet Mk II - Minnesota SnoJetter Aircraft - Fuel - Airplanes (FS/W) 1 Oct 09, 2010 03:08 PM
Build Log Sig Kadet Mark II =) gsumano Fuel Plane Talk 3 Jul 09, 2010 12:00 AM
Discussion Fixing a Sig Kadet Mark II - anyone with one have pictures? Raverix The Builders Workshop 1 Jul 07, 2010 08:09 PM
For Sale SIG Kadet Mark II NIB flybaby55 Aircraft - Fuel - Airplanes (FS/W) 4 Apr 25, 2009 06:24 PM
Alert NIB SIG Kadet Mark II Kit Gene Chernosky Aircraft - Fuel - Airplanes (FS/W) 0 Feb 21, 2004 08:38 AM
