This thread is privately moderated by iflytailies, who may elect to delete unwanted replies.
Old Mar 10, 2011, 08:23 PM
iflytailies is offline
Find More Posts by iflytailies
Trader Rating: 94
aka Schleppmeister
PA
Joined Feb 2006
Trader Rating: 94
Sold
Control Stick & Pilot Harness & Seat Belt
For sale are the following new scale items, also available at:
http://www.iflytailies.com/
1/2.5 to 1/2.7 Scale Control Stick
Made from plastic. This cockpit stick is mounted on a rubber mount and will move. This provides a very realistic appearance and an unproblematic handling while upgrading or maintaining the cockpit area.
Height: 150mm/5.9in.
Weight: 8g/0.28oz.
Made in Germany by Gromotec
$15 shipped
1/3 Scale Control Stick
Made from plastic. By drilling a whole on the bottom, this cockpit stick may easily be fitted in any position using a short screw or wood dowel.
Height: 140mm/5.5in.
Weight: 5g/0.18oz.
$15 shipped
1/3.5 to 1/4 Scale Control Stick
Made from plastic. Stock condition is 1/3.5 scale. By drilling a whole on the bottom, this cockpit stick may easily be fitted in any position using a short screw or wood dowel.
Height: 120mm/4.7in. - can be shortened easily for 1/4 scale
Color: gray
Weight: 4g/0.14oz.
$14 shipped
1/2.5 to 1/3 Scale Harness in either: Gray or Blue
Scale harness kit in scale 1/2.5 to 1/3. Color choices: gray or blue. The pictures show the assembled harness and the harness in kit form. Assembly time: ca. 30 minutes. Tools needed: hot glue; marker to indicate seams. Sewing not required.
This is very simple but effective for enhancing cockpit appearance. Whether with or without pilot - this harness belongs in any model (suited for sailplanes and motorized planes).
Made in Germany
This offer is for the harness kit only. Pilot not included
$26 shipped per item
1/3.5 to 1/4 Scale Harness in either: Black, Blue, or Red
Scale harness kit in scale 1/3.5 to 1/4. Color choices: black, blue, or red. Pictures show the assembled harness and the harness in kit form (harness will be black, not gray for 1/3.5-1/4 scale). Assembly time: ca. 30 minutes. Tools needed: hot glue; marker to indicate seams. Sewing not required.
Made in Germany
$22 shipped per item
Paypal, check, MO. If you order multiple items, I can reduce shipping cost. Please send PM if interested
iflytailies is offline Find More Posts by iflytailies
Sold ........ iflytailies Aircraft - Sailplanes (FS/W) 0 Mar 08, 2011 05:46 PM
Sold Control Stick & Pilot Harness for Cockpit iflytailies Aircraft - Sailplanes (FS/W) 0 Feb 25, 2011 08:18 PM
Sold Control Stick & Harness iflytailies Aircraft - Sailplanes (FS/W) 0 Feb 16, 2011 11:09 PM
Velco battery seat belt at Home Depot mikeb33 Electric Plane Talk 14 Feb 04, 2004 10:23 PM
Why you should use shrink wrap and a seat belt! bosley Parkflyers 6 Jan 24, 2003 06:04 PM
