Old Oct 14, 2001, 09:44 AM
JamesD is offline
Find More Posts by JamesD
Joined Jul 2001
How do you cut carbon fiber rod?
I am about to cut my first carbon fiber rod.
What is the best way to do it?
James
JamesD is offline Find More Posts by JamesD
Old Oct 14, 2001, 10:01 AM
mopar_man is offline
Find More Posts by mopar_man
Terry Dunn
mopar_man's Avatar
United States, TX, Lubbock
Joined Jan 2001
I wrap the area to be cut with some masking tape. Then using a razor saw, I cut around the circumference using only a pulling motion and light pressure. Once I have cut the entire circumference, i just keep cutting (still only pulling) til I'm all the way through. After it is cut and I remove the tape, I put a drop of CA on the end to help keep it from splitting. Be careful, I find the carbon dust to be pretty irritating on my skin.
mopar_man is offline Find More Posts by mopar_man
Old Oct 14, 2001, 03:32 PM
Bill Glover is offline
Find More Posts by Bill Glover
Bill Glover's Avatar
United Kingdom, Bracknell
Joined Nov 2000
I use a cutting disc in a mini drill (Dremel or whatever). Slices through, completely cleanly, in about a second!
Bill Glover is offline Find More Posts by Bill Glover
Old Oct 14, 2001, 09:57 PM
Gene Bond is offline
Find More Posts by Gene Bond
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
I do both!
I wrap with masking tape, mark and cut with a Dremel cut-off wheel.
Gene Bond is offline Find More Posts by Gene Bond
Old Oct 15, 2001, 11:31 AM
jojo is offline
Find More Posts by jojo
jojo's Avatar
belgium
Joined Oct 2001
as Bill and Genebond i do the same and the result is clean and quick
my dremel is always ready to cut something ...carbon or steel
jojo is offline Find More Posts by jojo
Old Oct 17, 2001, 06:46 AM
RookieOne is offline
Find More Posts by RookieOne
Michele Somaschini, Spain
RookieOne's Avatar
Madrid (Spain)
Joined Sep 2001
Be very carefull with carbon fiber dust and wear breathing protection masks to avoid lung diseases (cancer for instance)!!!
A saw is better as powder particles are greater and can be cleaned easily. Try to cut pieces into water if possible.
Cutting with electric tools is easy and fast but the disks throw smaller particles in the air and then they're everywhere.
RookieOne is offline Find More Posts by RookieOne
Old Oct 17, 2001, 10:15 AM
jojo is offline
jojo's Avatar
belgium
Joined Oct 2001
don t worry
with the age i become allergic to dust
i allways wear a protection
for me it was obvious
we live only once and the time is to short to make all those beautifull birds so spending it in the hospital...is a waste of time
i remenber one night the big pain with my eyes because using a grind machine i get a particle in the eye
i had to go to the emergency at 02.00 .
from there i allways wear protectives lens
it s mandatory in the factory where i work
joe
Discussion How do you use carbon fiber strips to reinforce a wing?! Smokescreen38 Parkflyers 15 Feb 23, 2007 01:51 PM
Discussion How do you install a carbon fiber tail rod? newpatch Electric Heli Talk 4 Feb 22, 2007 05:44 PM
How do you cut Carbon fiber plate? soholingo Composites Fabrication 15 Jun 21, 2005 05:39 PM
how do you cut carbon rods? robw Micro Helis 15 Dec 30, 2002 10:13 AM
