Old Apr 20, 2011, 08:18 AM
GILL RC is offline
Find More Posts by GILL RC
GILL
GILL RC's Avatar
United States, NJ, Hopatcong
Joined Aug 2005
The boat turns in it's own length. I used 1/8 lite ply for the bottom & 3 ribs. 1/16 ply for the sides, transom, cabin, roof, and deck. Took about 6 hours to cut all the parts with a box knif.
It will take longer to paint it then build it. All assembled with thick CA. total build time was about 8.5 hours.
I can have these laser cut. about $ 50 with motor.
GILL RC is offline Find More Posts by GILL RC
Old Apr 20, 2011, 09:41 AM
JayJay76 is offline
Find More Posts by JayJay76
JayJay76's Avatar
United States, IL, Chgo
Then start your own thread FFS.
JayJay76 is offline Find More Posts by JayJay76
Old Apr 20, 2011, 01:21 PM
der kapitan is online now
Find More Posts by der kapitan
"day ain't over yet-"
der kapitan's Avatar
Western N.Y. winemaking country
Joined Jun 2005
I agree with Lepinske, maybe you SHOULD start your own thread, instead of pirating his---.
der kapitan is online now Find More Posts by der kapitan
Old Apr 20, 2011, 03:32 PM
JayJay76 is offline
JayJay76's Avatar
Actually at $50 including motor thats a hell of a deal, i'll take 2! do I get a discount for inspiring the design?
Old Apr 20, 2011, 04:01 PM
Joined Jun 2005
Jason, Gill wouldn't give his own mother a discount---.
Old Apr 20, 2011, 04:53 PM
GILL RC is offline
GILL
GILL RC's Avatar
Joined Aug 2005
Sorry just got carried away.
If you want them I can do something, don't listen to Kap
Old Apr 20, 2011, 08:35 PM
Joined Jun 2005
Hee hee---.
Old Apr 21, 2011, 07:30 AM
JayJay76 is offline
JayJay76's Avatar
I have a nearly unbreakable rule against buying model kits in any form, but thanks though.
Old Apr 21, 2011, 10:39 AM
GILL RC is offline
GILL
GILL RC's Avatar
Joined Aug 2005
Still can't wait to see your flat when it's finished.
Old Apr 22, 2011, 05:27 PM
idocdave01 is offline
Find More Posts by idocdave01
Joined Mar 2010
Does anyone have any kind of drawings of a micro 9 they could send me, going to try to make a micro micro 9 around 9" in length.
Dave
idocdave01 is offline Find More Posts by idocdave01
Old Apr 23, 2011, 04:08 AM
JayJay76 is offline
JayJay76's Avatar
Hi Dave,
I took the basic shape and scaled it to 9", simplified the construction and adjusted it to suit 1/64" and 1/32" ply or balsa. Part patterns will be ready later today or tomorrow. you'll have to work out your own motor mount depending on what you will power it with, and you might want to fiddle with the third bulkhead's position to accommodate whichever battery you choose.
Old Apr 23, 2011, 06:10 AM
JayJay76 is offline
JayJay76's Avatar
9" Lil' Salty plans
**Plans Updated** Now that I know how to make a 1:1 PDF these will print correctly on 8.5x11 paper without scaling.
I left out part patterns for the cabin since thats up to you how you want to design it, the one I have shown in the orthographic views is how I build mine.
Since it only takes 2 small sheets of plywood I'm definitely going to build one in this size very soon.
Let me know your motor and battery choices.
Old Apr 23, 2011, 10:13 AM
Joined Mar 2010
Thanks a lot it's what I was looking for. I'm going to try "Plastruct" sheet styrene for my build.
Dave
Old Apr 23, 2011, 07:30 PM
JayJay76 is offline
JayJay76's Avatar
The 52cm 'Big Salty' build is coming along, photos tomorrow of the progress so far.
I'm trying to decide whether to stay with 2x 4,5Ah 6V SLA batteries, which I'm not so impressed with in my springer regarding usable capacity, or build a massive 2S15P pack built with some surplus 1,3Ah lithium ion cells I got a deal on. Upside would be 19,5Ah useful capacity, downside would be the 9+ hour charge cycle at 2.5A. You can see in the image the red+ and black- taps, with a center tap in orange for balancing. If I'm not mistaken, several cells with slight imbalances charged in parallel would balance each other out as only the low voltage cells would draw current, is this right?
The cells normally are built into 10S2P power tool packs that have no balancing taps whatsoever. Based on that fact I would dare to guess that a 2S pack with any number of parallel cells would not need regular balancing, just the occasional cell checkup with a volt meter and individually topping up each tier.
Anyone have any thoughts on this?
Old Apr 24, 2011, 06:02 PM
JayJay76 is offline
JayJay76's Avatar
nobody has anything to say about this battery configuration? I need guidance from someone with more experience.
Discussion Where to find 880mm Flat Bottom blades in the U.S.? philip frank UAV - Unmanned Aerial Vehicles 2 Feb 18, 2011 08:27 PM
Discussion Symmetrical vs Flat Bottom Wing Chophop Electric Plane Talk 1 Oct 24, 2010 09:10 AM
Discussion Looking for plans for a 9" to 12" tug like the salty BOZINATOR Dock Talk 29 Oct 31, 2009 10:20 PM
Sold Flat bottom PE foam blades for 300 class micro FP or CP heli's generalbacardi Aircraft - Electric - Helis (FS/W) 5 Apr 20, 2008 10:17 AM
Question on changing the airfoil on a Micro plane. (Undercambered to flat bottom) WarpdSpazm Modeling Science 10 Jan 29, 2005 10:39 PM
