Old Apr 15, 2011, 08:44 AM
GILL RC is offline
Find More Posts by GILL RC
GILL
GILL RC's Avatar
United States, NJ, Hopatcong
Joined Aug 2005
Those will work, they run well at 5 volts all the way up to 14 volts. My flat bottom will be running 7.2 or 8.4v.
Hoghappy in researching the flat bottoms I found some that have a shallow step keel in them.
nick_75au so you know where I am coming from I work for Polk/Aristo-craft, I handle the LMP division.(commercial) we are the US reps. for Mabuchi, Nichibo, San-ye, and several other fractional HP motor manufactures.
On average the 5 pole motors have about 5-20% more torque the a 3 pole motor. Motors used in the trains, including ours, Aristo-Craft (G) & RMT (O) are wound for a lower speed and higher torque. These motors are also 0 timed and will run equally will in both directions.
GILL RC is offline Find More Posts by GILL RC
Old Apr 15, 2011, 02:27 PM
JayJay76 is offline
Find More Posts by JayJay76
JayJay76's Avatar
United States, IL, Chgo
Hey Gill if you work for Polk, mayhaps you could tell me how to get my hands on a few 00100 speed controllers on this side of the pond...
JayJay76 is offline Find More Posts by JayJay76
Old Apr 15, 2011, 04:06 PM
GILL RC is offline
GILL
GILL RC's Avatar
Joined Aug 2005
No problem we ship world wide.
Just go to the web site and order the PLK00100.
The more I look at my design, I start to think maybe I should build a full size.
9 ft long. It would fit in my trailer that is 12 ft long. I think that it would make a great recovery boat for the club. Electric trolling motor for power.
I would make the cabin removable.
Old Apr 15, 2011, 06:55 PM
nick_75au is online now
Find More Posts by nick_75au
NeverAgainVolunteerYourse lf
nick_75au's Avatar
Australia, QLD, Regents Park
Joined Mar 2007
No matter what you say low current is low torque, the whole low Kv high torque is a myth.
The fact is that spinning a prop at low RPM requires less torque that's why Low Kv motors are brilliant for direct drive applications
http://www.mabuchi-motor.co.jp/cgi-b...ch/e_model.cgi
both 550 3 pole motors have more torque
Nick
nick_75au is online now Find More Posts by nick_75au
Old Apr 15, 2011, 07:06 PM
der kapitan is offline
Find More Posts by der kapitan
"day ain't over yet-"
der kapitan's Avatar
Western N.Y. winemaking country
Joined Jun 2005
Most of the little tugs shown in this thread look a lot like the 14' mini-tug, the plans for which are advertised in Wooden Boat magazine. Kinda cute---.
der kapitan is offline Find More Posts by der kapitan
Old Apr 18, 2011, 03:52 AM
JayJay76 is offline
JayJay76's Avatar
I'm trying to choose a prop now to match to the speed 600, its a 7.2V motor direct drive, and I have room for up to 45mm of prop. Can someone suggest to me a Raboesch brass prop size/blade count that would give moderate speed on 6V from two 4.5Ah sealed lead acid batteries, without burning out my motor? It is water cooled with an aluminum tube coil from graupner.
Thanks in advance..
Old Apr 18, 2011, 04:25 AM
nick_75au's Avatar
Joined Mar 2007
Which speed 600 the 7.2v ECO or the 7.2v standard
The standard has a KV of 2530, the ECO 1530 so 15180 rpm vs 9180 RPM at 6 volts
The best one is the speed 600 BB Turbo 14.4 with a KV of 1000 for 6000 RPM at 6 volts and 40-45 mm prop, I would put a 25-30 mm prop on the ECO and the smallest I could find on the 7.2 std.
As for blades, whatever takes your fancy, 3 blade D type Raboecsh is what I use for my springers, 3 or 4 blade is not going to have a great deal of difference.
Cheers
Nick
Old Apr 18, 2011, 06:18 AM
JayJay76 is offline
JayJay76's Avatar
well crap. I have the 7,2V standard and that doesn't seem like it was a good choice. Looks like I'll be ordering the 600 BB Turbo, its 12V but I think thats the one you mentioned.
http://www.conrad.de/ce/de/product/2...30010&ref=list
Old Apr 18, 2011, 06:33 AM
JayJay76 is offline
JayJay76's Avatar
Hey nick,
This isn't a speedboat by the way and the model is 54cm long, isn't that 600BB Turbo for speedboats turning high pitch props? Either way it looks like my 600 standard has too high KV for turning a big prop it would probably drain the battery and overheat pretty quick. Should I go ahead and order this motor?
Old Apr 18, 2011, 06:39 AM
nick_75au's Avatar
Joined Mar 2007
12v 600 BB turbo is 1450 KV so 8700 RPM at 6 volt only slightly better, maybe they have Speed 500 E 12V same Kv as 14.4 600, with a 35-40 mm prop
This one is much closer to the sweet spot
and the Speed motor
Old Apr 18, 2011, 06:47 AM
nick_75au's Avatar
Joined Mar 2007
Will turn a 45 mm prop only on 6 volts might be a little slow,
though it wont be pushing the 4 Kg of a Springer either so might actually be OK
600 BB turbo is really good for speedboats but needs to have more than its rated voltage for good speed, at lower than rated voltage becomes a nice slow motor with enough torque to drive a largish prop.
Nick
Old Apr 18, 2011, 08:46 AM
JayJay76 is offline
JayJay76's Avatar
I think I'm going to order this one http://www.conrad.de/ce/de/product/2...30010&ref=list
Old Apr 19, 2011, 11:52 AM
GILL RC is offline
GILL
GILL RC's Avatar
Joined Aug 2005
I ran mine on Sunday. 7.2v 1500ma nicad. At full speed with a 30mm 3 blade Raboesch brass prop. Speed is a bit faster then I can walk, duration was 1 1/2 hours +. That's running full for about 70% of the time. Handles very well and will turn on a dime.
Now I just have to finnish painting and detailing her.
Old Apr 19, 2011, 09:53 PM
jerryj98501 is offline
Find More Posts by jerryj98501
Olympia WA
Joined Nov 2004
Gill RC I'm waiting with baited breath to see some video of how the tug handled on the water. I have been eying these for a few years but have always had to put them on the back burner, maybe this will get me off my duff and build one for the grandson. Jerryj98501
jerryj98501 is offline Find More Posts by jerryj98501
Old Apr 20, 2011, 06:20 AM
JayJay76 is offline
JayJay76's Avatar
seems like it took ages but finally I managed to get all the parts cut out and started assembling last night, its looking good but I will really reduce the parts count in my next iteration. It was a chore cutting them all out.
Discussion Where to find 880mm Flat Bottom blades in the U.S.? philip frank UAV - Unmanned Aerial Vehicles 2 Feb 18, 2011 07:27 PM
Discussion Symmetrical vs Flat Bottom Wing Chophop Electric Plane Talk 1 Oct 24, 2010 08:10 AM
Discussion Looking for plans for a 9" to 12" tug like the salty BOZINATOR Dock Talk 29 Oct 31, 2009 09:20 PM
Sold Flat bottom PE foam blades for 300 class micro FP or CP heli's generalbacardi Aircraft - Electric - Helis (FS/W) 5 Apr 20, 2008 09:17 AM
Question on changing the airfoil on a Micro plane. (Undercambered to flat bottom) WarpdSpazm Modeling Science 10 Jan 29, 2005 09:39 PM
