Old Apr 08, 2011, 07:57 AM
GILL RC is offline
Find More Posts by GILL RC
GILL
GILL RC's Avatar
United States, NJ, Hopatcong
Joined Aug 2005
It dose not take much! Going for # 106
Bottom, the 4 ribs, the hull sides are all cut out. I did change the design slightly and made a separate motor mount. Ribs are mounted on the bottom and the stern tube and shaft is fitted. The motor mount is done.
I’ll get some pictures this week end as I hope to have the hull finished along with most of the cabin.
I'm thnking engine sound, horn, and running lights.
GILL RC is offline Find More Posts by GILL RC
Old Apr 08, 2011, 03:56 PM
JayJay76 is offline
Find More Posts by JayJay76
JayJay76's Avatar
United States, IL, Chgo
Finally! My Proxxon DS230 arrived! what a gem! this little baby makes quick work of 3mm ribs and 1,5mm planking. I will post videos and photos soon so you can all see what this little workhorse can do. And quiet as a church mouse!
JayJay76 is offline Find More Posts by JayJay76
Old Apr 10, 2011, 02:43 AM
Ford_63 is offline
Find More Posts by Ford_63
Call me Mad Hatter
Ford_63's Avatar
Joined Jun 2007
Ford_63 is offline Find More Posts by Ford_63
Old Apr 11, 2011, 02:39 PM
JayJay76 is offline
JayJay76's Avatar
Originally Posted by GILL RC View Post
jlepinske I hope that you get your saw soon. Can't wait to see your flat bottom.
Did a bit of work on mine this week end. I did change the design a little. I am hinging the front window. The seats are done, drive mounted as is the rudder. Sunday morning I started painting.
By the way mine was cut out with just a box cutter knif.
lookin real nice! I got my saw last friday just been busy with work. Mine's not a flat bottom, it still has a box keel. I was out yesterday on the neckar for 2 hours with my springer, managed to push in some plastic bottles floating by and watched a mother duck with 4 ducklings playing around the kayak launch dock. Heres a few renderings I did when it was too late to make noise with the saw.
Old Apr 11, 2011, 02:52 PM
GILL RC is offline
GILL
GILL RC's Avatar
Joined Aug 2005
I like it. Should look real good when finnished.
I hope to have mine finnished for next Sunday. Club meeting at the pond.
Old Apr 11, 2011, 03:54 PM
JayJay76 is offline
JayJay76's Avatar
I'm taking my time with this one, I have the next 50 years or so to perfect it. And to me thats what the design is all about, perfection. And design is how I make my living.
hey gill I like how you built a wood motor mount then secure it in the hull with screws, I was trying to figure a way to do something like that with my 45cm flat bottom fishing hull, and ended up with a plywood plate that the motor is screwed to, then slotted into a pair of grooves in the adjacent longitudinal frame members. Needs a screw or a dab of glue to secure it, not as serviceable as your design.
Old Apr 12, 2011, 10:41 AM
GILL RC is offline
GILL
GILL RC's Avatar
Joined Aug 2005
I use a variation of this mount in a number of models.
1/8 lite ply (aircraft) I change the angle to match the drive shaft angle.
I place at lest 2 layers of ply in the bottom of the boat, for the mounting screws. The screws I use are #4-6 3/8 - 1/2 inch long.
I have all so used this for 7-800 and 900 motors. Just make it bigger.
I have mounted this on risers in deep hulls.
Old Apr 14, 2011, 04:56 AM
JayJay76 is offline
JayJay76's Avatar
Hey Gill, I've looked all over for 555 electric motors, where do you get them? are there some advantages over a 500 or 600? and do you use lead acid batteries or always nicads?
Old Apr 14, 2011, 09:32 AM
GILL RC is offline
GILL
GILL RC's Avatar
Joined Aug 2005
The 555 motors are from trains. I run gel. 6&12v, nicad, hydrid, and lipo.
The 555 motor is a 5 pole runs much smoother then the 3 pole motors. It also has much more torque and in most cases draws less current.
I can push a 45 mm 4 blade prop and only draw about 1-3 amps, no heat.
Old Apr 14, 2011, 02:28 PM
JayJay76 is offline
JayJay76's Avatar
Tell me where I can find them! i suppose they're a bit harder to get over here than in the USA. Who makes em?
Old Apr 14, 2011, 02:47 PM
GILL RC is offline
GILL
GILL RC's Avatar
Joined Aug 2005
I get the motors from hobby shops that handle trains. They are replacement motors for G and O gauge trains. I have even purchased used motors that were not the best for the train but work fine in a boat.
Old Apr 15, 2011, 12:45 AM
JayJay76 is offline
JayJay76's Avatar
I think I found them, does this look right? http://cgi.ebay.ch/2-Stueck-Mabuchi-...-/270593483633
Old Apr 15, 2011, 05:06 AM
nick_75au is online now
Find More Posts by nick_75au
NeverAgainVolunteerYourse lf
nick_75au's Avatar
Australia, QLD, Regents Park
Joined Mar 2007
Hi,
they look really good, nice low RPM that will drive the prop suggested,
I don't agree that they have more torque than a 3 pole motor, only that they have enough torque to drive that prop at that RPM
Cheers
Nick
nick_75au is online now Find More Posts by nick_75au
Old Apr 15, 2011, 06:41 AM
Capt.Crash is offline
Find More Posts by Capt.Crash
**NOT GUILTY**
Capt.Crash's Avatar
Millbrook, Alabama
Joined Jun 2004
Don't take this wrong because I love the tug....but with that big ole keel added...it's no longer a "flat bottom" tug...
Never mind...I see now that its jlepinske's tug....nice tug dude!
Capt.Crash is offline Find More Posts by Capt.Crash
Discussion Where to find 880mm Flat Bottom blades in the U.S.? philip frank UAV - Unmanned Aerial Vehicles 2 Feb 18, 2011 07:27 PM
Discussion Symmetrical vs Flat Bottom Wing Chophop Electric Plane Talk 1 Oct 24, 2010 08:10 AM
Discussion Looking for plans for a 9" to 12" tug like the salty BOZINATOR Dock Talk 29 Oct 31, 2009 09:20 PM
Sold Flat bottom PE foam blades for 300 class micro FP or CP heli's generalbacardi Aircraft - Electric - Helis (FS/W) 5 Apr 20, 2008 09:17 AM
Question on changing the airfoil on a Micro plane. (Undercambered to flat bottom) WarpdSpazm Modeling Science 10 Jan 29, 2005 09:39 PM
