Old May 25, 2012, 04:13 PM
gpzy is offline
Find More Posts by gpzy
FROM THE MIND OF A MADMAN
gpzy's Avatar
Joined Apr 2007
Are these boats fiberglass over would or just coated with epoxy and painted ?
gpzy is offline Find More Posts by gpzy
Old May 25, 2012, 04:22 PM
blutoh is offline
Find More Posts by blutoh
---o-O-o---
blutoh's Avatar
United States, NJ
Joined Mar 2012
gpzy, I used 1/32nd ply for the bottom and sides as per the plans, so I am putting a layer of cloth and epoxy for a little xtra strength. I suppose you could just go with epoxy and no cloth.
Pete
blutoh is offline Find More Posts by blutoh
larryg is offline
Find More Posts by larryg
Joined Jan 2007
mine is coated and painted
larryg is offline Find More Posts by larryg
Old May 25, 2012, 09:26 PM
ADAGIO is offline
Find More Posts by ADAGIO
Brisbane
Joined Feb 2008
ADAGIO (slow dancin'man)
You can do either. My Murray River paddlesteamer has both; glass and epoxy outer and epoxy inner.
I used the Boatcraft system of the TPRDA/epoxy mix then, as soon as it had gelled, I sanded it over with 80 grit paper, wiped it down to get it clean, another coat of full strength epoxy with a layer of scrim glass cloth (seriously fine mesh), wiped over with gloved hands to smooth it out and left to cure. Human hands are wonderful tools for getting a surface finish fair.
A couple of coffees with choccie bickie later and a good read for a couple of hours, sanded it over with much finer paper and primed it with enamel undercoat and finished it as usual for enamel.
Tough stuff and hard wearing. Easy, just believe what the instructions say, NOT the local self appointed expert on all things.
Inside, I simply coated it with one coat of TPRDA and epoxy mix, and painted it over with enamel undercoat straight over the epoxy. Job done and holding up well.
In full size boatbuilding, epoxy is the best timber primer/sealer by far, followed by 'glass as specificed by the boat designer or the epoxy dealer.
An essential ingredient to doing a good job is the coffee/choccie bickie bit. It's called patience.
ADAGIO is offline Find More Posts by ADAGIO
Old Jun 02, 2012, 12:29 PM
marter1229 is offline
Find More Posts by marter1229
marter1229's Avatar
United States, ID, CDA
Joined Aug 2005
The rudder placement and size concerns me, any ideas?
marter1229 is offline Find More Posts by marter1229
Old Jun 02, 2012, 04:53 PM
JayJay76 is offline
Find More Posts by JayJay76
JayJay76's Avatar
United States, IL, Chgo
Hey marter its looking great! the rudder would probably benefit from adding some area forward of the pivot point, to balance it so your servo isn't fighting the prop thrust so much. Try moving the center of pivot back to 25-33% from the leading edge of the rudder. Other than that its awesome.
JayJay76 is offline Find More Posts by JayJay76
Old Jun 03, 2012, 04:59 PM
blutoh is offline
---o-O-o---
blutoh's Avatar
United States, NJ
Joined Mar 2012
Terry it looks great! Can't comment on the rudder because being a nooby i have no clue but I would follow JayJays advice. I just got back from a weeks vacation, so I have to catch up. I want to get it wet in next 2 weeks or so.
Pete
Old Jun 03, 2012, 05:05 PM
JayJay76 is offline
JayJay76's Avatar
Hey Blutoh welcome back! I can't wait to see who's salty hits the water first, will it be yours? I've been away from RCG the last couple weeks busy with work and the cartoon runabout. I finished the prototype plans and I have the hull framed, sheeted, and the interior reinforced with glass strips and sealed with resin; as soon as my mahogany and obechi planks arrive I'll be posting photos and updates. I'm hoping the wood shows up by wednesday, so I can start planking over the 4 day weekend!
Old Jun 03, 2012, 05:11 PM
blutoh is offline
---o-O-o---
blutoh's Avatar
United States, NJ
Joined Mar 2012
Great JayJay, I can't wait to see it. My running gear showed up while I was away, so I have everything I need to finish now. It shouldn't be long.
Pete
Old Jun 08, 2012, 04:50 PM
marter1229's Avatar
Joined Aug 2005
Electrics installed and working.
I believe it is ready to go.
It was hard to find an ESC for a brushed motor, that I forgot Reverse, so I have to pay attention when I launch. Murphy's law !
Old Jun 08, 2012, 07:43 PM
larryg is offline
Joined Jan 2007
Love your work Marter, looks awesome , you even got a steering wheel in the pilot house, dang now i have to do some improvements on mine ..lol
Old Jun 08, 2012, 07:45 PM
larryg is offline
Joined Jan 2007
Marter , what type paint did you use ?? looks great
Old Jun 08, 2012, 09:17 PM
marter1229's Avatar
Joined Aug 2005
Rustoleum Premier that I bought at Ace hardware. There is a ton of colors, and it sprays pretty good.
Old Jun 08, 2012, 10:11 PM
blutoh is offline
---o-O-o---
blutoh's Avatar
United States, NJ
Joined Mar 2012
Looks great Terry! Take some video's when you launch her. What motor did you use?
Pete
Discussion Where to find 880mm Flat Bottom blades in the U.S.? philip frank UAV - Unmanned Aerial Vehicles 2 Feb 18, 2011 08:27 PM
Discussion Symmetrical vs Flat Bottom Wing Chophop Electric Plane Talk 1 Oct 24, 2010 09:10 AM
Discussion Looking for plans for a 9" to 12" tug like the salty BOZINATOR Dock Talk 29 Oct 31, 2009 10:20 PM
Sold Flat bottom PE foam blades for 300 class micro FP or CP heli's generalbacardi Aircraft - Electric - Helis (FS/W) 5 Apr 20, 2008 10:17 AM
Question on changing the airfoil on a Micro plane. (Undercambered to flat bottom) WarpdSpazm Modeling Science 10 Jan 29, 2005 10:39 PM
