Old May 08, 2012, 08:54 PM
BOZINATOR is offline
Find More Posts by BOZINATOR
In The Sorrano Triangle
BOZINATOR's Avatar
El Dorado Hills, Calif
Joined Mar 2005
bye
BOZINATOR is offline Find More Posts by BOZINATOR
Old May 09, 2012, 09:30 AM
blutoh is offline
Find More Posts by blutoh
---o-O-o---
blutoh's Avatar
United States, NJ
Joined Mar 2012
blutoh is offline Find More Posts by blutoh
Old May 09, 2012, 09:54 AM
steamboatmodel is offline
Find More Posts by steamboatmodel
steamboatmodel's Avatar
Toronto, Canada
Joined Nov 2004
Originally Posted by blutoh View Post
Hi guys,
What about using lauan for the barge? I swung by the big box store today, a 2' x 4' piece is a little over $5.00. It's marked 1/4" thick. I didn't have a tape with me, but it looks closer to 3/8 to my eye. I thought it might be a good inexpensive choice of material for building the barge. The center core seems pretty hard, but I plan to clamp, glue and use glass and resin on it. What do you think? Any good?
Pete
It will work but it does need complete waterproofing. If you miss any spot it will swell and delaminate.
Regards,
Gerald.
steamboatmodel is offline Find More Posts by steamboatmodel
Old May 09, 2012, 02:08 PM
blutoh is offline
---o-O-o---
blutoh's Avatar
United States, NJ
Joined Mar 2012
Thanks, Gerald. That is the plan (waterproof inside and out), wether I use luaun or regular ply I will have to take the same steps. I am planning to coat with finishing resin inside and out to water proof it, and also use fg cloth on the outside to toughen it up, unless there is a better solution.
Pete
Old May 09, 2012, 02:25 PM
JayJay76 is offline
Find More Posts by JayJay76
JayJay76's Avatar
United States, IL, Chgo
Im working on a new design for a scrap hauler, i think ill call it the "Good Riddance"
JayJay76 is offline Find More Posts by JayJay76
Old May 09, 2012, 06:20 PM
marter1229 is offline
Find More Posts by marter1229
marter1229's Avatar
United States, ID, CDA
Joined Aug 2005
The picture of my tug must have turned Stealth!, I don't see it.
Its all fun!
Terry
marter1229 is offline Find More Posts by marter1229
Old May 10, 2012, 06:35 PM
blutoh is offline
---o-O-o---
blutoh's Avatar
United States, NJ
Joined Mar 2012
Finishing resin
What do you use to thin epoxy finshing resin?
Pete
Old May 10, 2012, 11:45 PM
Tugboat Andy is offline
Find More Posts by Tugboat Andy
Joined Apr 2007
Great builds going on here folks. Keep it up. I can't wait to see how this little boat develops.
BTW -Depending on what you're trying to laminate/bond, I would be somewhat leary of thinning epoxy since it could affect the chemical reaction and resulting strength. Here's a link to an article on thinning epoxy.
http://www.seqair.com/skunkworks/Glu.../Thinning.html
Tugboat Andy is offline Find More Posts by Tugboat Andy
Old May 11, 2012, 05:55 AM
larryg is offline
Find More Posts by larryg
Joined Jan 2007
Hay everyone check this out , www.plungercove.com. this man has been making non Rc but beautiful Salty type tugs as cute static models, its worth a look. i am still painting but hope to hit the H20 this weekend ok ,
larryg is offline Find More Posts by larryg
Old May 11, 2012, 06:17 AM
JayJay76 is offline
JayJay76's Avatar
Hey Larry, that is a fantastic link! I have scoured the internet googling for classic style toy tugboats, this is an awesome find! I'm getting ready to build a second salty, this time with a flat bottom hull, and I'll design a new cabin around this guy's work.
Old May 11, 2012, 09:56 AM
blutoh is offline
---o-O-o---
blutoh's Avatar
United States, NJ
Joined Mar 2012
Tugboat Andy,
Good info, thanks for the link! I made a few detail items out of some balsa I had laying around and I want to to toughen them up by getting the resin to penetrate. I think warming the resin is the way to go, unless there is some better way? I'll try it and see how it goes, its not a big deal if it doesn't work, I can make new ones quickly.
Guys - I picked up some lauan last night and hope to start on the barge this weekend. I'll let you know how this works out.
Pete
Old May 11, 2012, 11:02 AM
Henk Goosen is offline
Find More Posts by Henk Goosen
Henk Goosen's Avatar
The Netherlands
Joined Dec 2008
Pete in model airplane building we soak the balsa with thin CA to make is harder.
Henk.
Henk Goosen is offline Find More Posts by Henk Goosen
Old May 11, 2012, 12:41 PM
P_J_Glor is online now
Find More Posts by P_J_Glor
P_J_Glor's Avatar
Valencia, CA
Joined Oct 2002
The 'Tugwillow' looks like it would fit right into this series and ditto for the 'Gikumi.'
Pete G.
P_J_Glor is online now Find More Posts by P_J_Glor
Old May 11, 2012, 01:08 PM
blutoh is offline
---o-O-o---
blutoh's Avatar
United States, NJ
Joined Mar 2012
Larry, bring the camera, can't wait to see pix.
Henk, great idea, thanks! I will try it tonight.
Pete
Old May 12, 2012, 03:37 PM
bgnome is offline
Find More Posts by bgnome
made of fire and pop rocks
bgnome's Avatar
Richmond Virginia
Joined Oct 2009
JayJay. did you ever make up a set of plans for that toyscale runabout down thread?
and great looking plans! I'll be taking the PDFs down to Kinko's next payday
bgnome is offline Find More Posts by bgnome
Discussion Where to find 880mm Flat Bottom blades in the U.S.? philip frank UAV - Unmanned Aerial Vehicles 2 Feb 18, 2011 07:27 PM
Discussion Symmetrical vs Flat Bottom Wing Chophop Electric Plane Talk 1 Oct 24, 2010 08:10 AM
Discussion Looking for plans for a 9" to 12" tug like the salty BOZINATOR Dock Talk 29 Oct 31, 2009 09:20 PM
Sold Flat bottom PE foam blades for 300 class micro FP or CP heli's generalbacardi Aircraft - Electric - Helis (FS/W) 5 Apr 20, 2008 09:17 AM
Question on changing the airfoil on a Micro plane. (Undercambered to flat bottom) WarpdSpazm Modeling Science 10 Jan 29, 2005 09:39 PM
