Old Apr 26, 2012, 07:54 PM
capntroy's Avatar
Orange County, CA
Joined Nov 2007
Originally Posted by blutoh View Post
Thanks capntroy,
I corrected the skegs and made them flush with the keel.
Pete
Beauty, she should track nice and straight now.
Also, as a rule of thumb, the bridle legs that are attached to the forward corners of the barge should be approx. 2/3rds as long as the beam of the barge, i.e., if the barge is 12" wide, the bridle legs should be approx. 8" long. The ends of the legs will attach to each other and this is where the end of the towline will connect.
capntroy is offline Find More Posts by capntroy
Old Apr 27, 2012, 02:05 AM
JayJay76's Avatar
Stuttgart, Germany
Thanks for the additional info Capntroy, I wouldn't know where to start with rigging up the towlines. I'm starting my barge this weekend and already I'm dreaming up what sort of cargo to carry.
JayJay76 is offline Find More Posts by JayJay76
Old Apr 27, 2012, 02:22 AM
JayJay76's Avatar
Stuttgart, Germany
I'm thinking of building my barge with an exchangeable cargo floor, a regular one for dry loads and a second with round openings and wire cages to allow bottles of beer to hang down in the water, adding drag to the tow and keeping them chilled....
Old Apr 27, 2012, 05:29 AM
Joined Jan 2007
ill drink to that idea, lol
larryg is offline Find More Posts by larryg
Old Apr 27, 2012, 07:13 AM
GILL
GILL RC's Avatar
United States, NJ, Hopatcong
Joined Aug 2005
For a rope bumper, find someone that crotches. Have them do a strip the length you need and about 2in wide with a 6-8 in string on each end.
Die it he color you want, roll with a running stick where the edge meets the roll.
GILL RC is offline Find More Posts by GILL RC
Old Apr 27, 2012, 07:17 AM
JayJay76's Avatar
Stuttgart, Germany
like the corks, i'm looking for something that is recognizable as something else.
Old Apr 27, 2012, 10:04 AM
In The Sorrano Triangle
BOZINATOR's Avatar
El Dorado Hills, Calif
Joined Mar 2005
bye
BOZINATOR is offline Find More Posts by BOZINATOR
Old Apr 27, 2012, 10:18 AM
---o-O-o---
blutoh's Avatar
United States, NJ, Livingston
Joined Mar 2012
capntroy,
Thanks for the info about the bridle legs. I am going to the hardware store this weekend to find some twine that looks like scaled down rope.
JayJay,
Yes, I was thinking the the same thing, interchangeable loads. I think I am going to try cutting a block of foam to fit the cargo area, but slightly lower in height. Then glue gravel or coal to the exposed top to simulate the cargo load. Then I can make different loads to swap in or out. I have used this technique on my model railroad cars to save weight. It works great. Eventually I want to build a larger tug with a carfloat loaded with railroad cars, but have to creep before I crawl (and also a yacht, mahogany runabout, springer, commuter, etc etc etc ). This project is a great learnng experience.
Gill,
Great idea about the crochet bumper. My SIL crochet's, I will have to give my dimensions and put ther to work.
Jim,
Are you able to see the barge attachments I posted (#360)? Let me know, If not I will try to figure out what's going wrong with my attachments,
Pete
blutoh is offline Find More Posts by blutoh
Old Apr 27, 2012, 11:05 AM
marter1229's Avatar
North idaho
Joined Aug 2005
Back with more Salty progress.
marter1229 is offline Find More Posts by marter1229
Old Apr 27, 2012, 11:19 AM
marter1229's Avatar
North idaho
Joined Aug 2005
Side view.
The hull has a layer of 2oz glass.
Old Apr 27, 2012, 12:35 PM
Joined Jan 2007
Looking real good Marter
Old Apr 27, 2012, 03:05 PM
JayJay76's Avatar
Stuttgart, Germany
Yeah that looks great! sorry to hear about the putty and primer incompatibility, that's the first time I've seen something like that. The stack look good, I can't wait to see your paint scheme.
Old Apr 27, 2012, 03:12 PM
JayJay76's Avatar
Stuttgart, Germany
Hey Gill, do you think it's possible to crochet with twine or scale rope? I might the my hand at it if it's not a dumb idea.
Old Apr 27, 2012, 04:46 PM
Joined Jan 2007
little bit more done, this weekend i hope to get it sealed and primered up
Old Apr 27, 2012, 07:19 PM
marter1229's Avatar
North idaho
Joined Aug 2005
looking good larryg.
Discussion Where to find 880mm Flat Bottom blades in the U.S.? philip frank UAV - Unmanned Aerial Vehicles 2 Feb 18, 2011 07:27 PM
Discussion Symmetrical vs Flat Bottom Wing Chophop Electric Plane Talk 1 Oct 24, 2010 08:10 AM
Discussion Looking for plans for a 9" to 12" tug like the salty BOZINATOR Dock Talk 29 Oct 31, 2009 09:20 PM
Sold Flat bottom PE foam blades for 300 class micro FP or CP heli's generalbacardi Aircraft - Electric - Helis (FS/W) 5 Apr 20, 2008 09:17 AM
Question on changing the airfoil on a Micro plane. (Undercambered to flat bottom) WarpdSpazm Modeling Science 10 Jan 29, 2005 09:39 PM
