Old Apr 25, 2012, 04:26 PM
blutoh is offline
Find More Posts by blutoh
---o-O-o---
blutoh's Avatar
United States, NJ
Joined Mar 2012
Larry, Terry (marter), you, me, and Boz probably has 5 done by now. And maybe a couple of lurkers.
blutoh is offline Find More Posts by blutoh
Old Apr 25, 2012, 05:27 PM
BOZINATOR is offline
Find More Posts by BOZINATOR
In The Sorrano Triangle
BOZINATOR's Avatar
El Dorado Hills, Calif
Joined Mar 2005
bye
BOZINATOR is offline Find More Posts by BOZINATOR
Old Apr 25, 2012, 05:59 PM
larryg is offline
Find More Posts by larryg
Joined Jan 2007
That sportster has beautiful lines, wish i was in it in a nice clean Canadian lake..
larryg is offline Find More Posts by larryg
Old Apr 25, 2012, 06:08 PM
blutoh is offline
---o-O-o---
blutoh's Avatar
United States, NJ
Joined Mar 2012
Sweet! Especially with that planked deck!
Old Apr 26, 2012, 06:24 AM
JayJay76 is offline
Find More Posts by JayJay76
JayJay76's Avatar
United States, IL, Chgo
Originally Posted by BOZINATOR View Post
http://www.greybarnboatworks.com/Con...cht_tender.htm
convert same hull (jasons) to runabout
jim
It looks to me like the forward deck is totally flat and gently arched toward the transom, I think that would make my runabout plans much simpler. Right now I'm trying to think of a way to achieve an arched deck on a flat top frame that can be assembled upside down on the bench to provide good alignment.
JayJay76 is offline Find More Posts by JayJay76
Old Apr 26, 2012, 07:18 AM
GILL RC is offline
Find More Posts by GILL RC
GILL
GILL RC's Avatar
United States, NJ, Hopatcong
Joined Aug 2005
Just add legs to the frames. Finnish the hull, cut the legs and sand to the top of the frames. They can be glued down to mantain alinment and keep the hull straight.
GILL RC is offline Find More Posts by GILL RC
Old Apr 26, 2012, 11:53 AM
blutoh is offline
---o-O-o---
blutoh's Avatar
United States, NJ
Joined Mar 2012
Barge
OK, first attempt at this sort of thing, no laughing!
Does it need some kind of fixed rudder at the rear? I noticed some photos have something like that.
Pete
Attachments deleted. SEE POST #360 below for corrected drawings.
Old Apr 26, 2012, 12:03 PM
BOZINATOR's Avatar
Joined Mar 2005
bye
Old Apr 26, 2012, 01:46 PM
capntroy is offline
Find More Posts by capntroy
Keep a Steady Strain....
capntroy's Avatar
Orange County, CA
Joined Nov 2007
Pete - those fixed rudders at the back are called "skegs" and help keep the barge tracking straight, especially if you're towing the barge on the string. You'll need one on each side near the edge and they should have a slight (maybe 10-15 degree) camber pointed towards the outside of the barge.
Also, you'll want to add two tow points (cleats, bitts, eyebolts, whatever) at the very-most forward corners to tow from. This way you can attach ends of your tow bridle to each corner and help tame the wander while towing...
capntroy is offline Find More Posts by capntroy
Old Apr 26, 2012, 02:08 PM
JayJay76 is offline
JayJay76's Avatar
Awesome! I'll build one this weekend! Looks like I need to spin up some more rope!
Old Apr 26, 2012, 02:43 PM
blutoh is offline
---o-O-o---
blutoh's Avatar
United States, NJ
Joined Mar 2012
capntroy,
Thanks much for your help (and education). I added skegs at the rear, not sure if I have the camber correct or reversed, please let me know. Also added cleats and bitt for towing.
Jim,
I am posting new images, let me know if you see them, One is a .png file, the other a .pdf file.
Pete
Old Apr 26, 2012, 02:45 PM
blutoh is offline
---o-O-o---
blutoh's Avatar
United States, NJ
Joined Mar 2012
JayJay,
Did you make a rope bumper for the bow? If so, what did you use?
Pete
Old Apr 26, 2012, 02:52 PM
capntroy is offline
capntroy's Avatar
Orange County, CA
Joined Nov 2007
Pete - the skegs actually need to angle outboard the other way and you can put a bit more angle on them since they're going to be so small, try 30 degrees.
Also, it might help with storing and stacking the barge if you cut the skeg so it's flush with the barge keel.
Old Apr 26, 2012, 03:01 PM
JayJay76 is offline
JayJay76's Avatar
JayJay,
Pete
No rope bumper yet, just what you see in the photos. I'd like to figure out how to make one though.
Old Apr 26, 2012, 07:20 PM
blutoh is offline
---o-O-o---
blutoh's Avatar
United States, NJ
Joined Mar 2012
Barge Rev: 3
Thanks capntroy,
I corrected the skegs and made them flush with the keel.
Pete
Discussion Where to find 880mm Flat Bottom blades in the U.S.? philip frank UAV - Unmanned Aerial Vehicles 2 Feb 18, 2011 07:27 PM
Discussion Symmetrical vs Flat Bottom Wing Chophop Electric Plane Talk 1 Oct 24, 2010 08:10 AM
Discussion Looking for plans for a 9" to 12" tug like the salty BOZINATOR Dock Talk 29 Oct 31, 2009 09:20 PM
Sold Flat bottom PE foam blades for 300 class micro FP or CP heli's generalbacardi Aircraft - Electric - Helis (FS/W) 5 Apr 20, 2008 09:17 AM
Question on changing the airfoil on a Micro plane. (Undercambered to flat bottom) WarpdSpazm Modeling Science 10 Jan 29, 2005 09:39 PM
