Old Apr 24, 2012, 06:01 PM
BOZINATOR is offline
Find More Posts by BOZINATOR
In The Sorrano Triangle
BOZINATOR's Avatar
El Dorado Hills, Calif
Joined Mar 2005
bye
BOZINATOR is offline Find More Posts by BOZINATOR
Old Apr 24, 2012, 07:37 PM
hoffboy is offline
Find More Posts by hoffboy
Matt Haugh
hoffboy's Avatar
Olympia, WA
Joined Feb 2008
I'm now off Googling the following;
-non-wax sanding sealer (never heard of it..THAT'S how ignorant I am! )
-high build primer (ditto above)
--carnuba wax (ditto ditto)
Thanks once again for the great tips everyone. I WILL figure this out!
-Matt
hoffboy is offline Find More Posts by hoffboy
Old Apr 24, 2012, 08:55 PM
BOZINATOR's Avatar
Joined Mar 2005
bye
Old Apr 25, 2012, 05:17 AM
JayJay76 is offline
Find More Posts by JayJay76
JayJay76's Avatar
United States, IL, Chgo
Did you say after primer to use wax, THEN rustoleum? that doesn't sound right at all. And regular primer is okay if you cant find high build, you will just need more coats to fill the grain and get a smooth finish. Your finish can be very low-tech and low-cost and still come out looking good. I don't think I'll be spraying any future projects, it was a lot of hassle mixing paint and hardener, and cleaning the gun out after every coat was a pain.
JayJay76 is offline Find More Posts by JayJay76
Old Apr 25, 2012, 07:59 AM
GILL RC is offline
Find More Posts by GILL RC
GILL
GILL RC's Avatar
United States, NJ, Hopatcong
Joined Aug 2005
I use water base in the air brush for touch up and small jobs. Mostly aircraft.
All most every thing else is done with rattle cans. Rust-o-lum or Krylon.
They both have a form of dull coat and clear coat. So for bttom clors I shoot the color I want then a coat of clear dull. the rest of the model gets clear gloss. Unless military then the whole model gets a coat of dull.
GILL RC is offline Find More Posts by GILL RC
Old Apr 25, 2012, 03:31 PM
capntroy is offline
Find More Posts by capntroy
Keep a Steady Strain....
capntroy's Avatar
Orange County, CA
Joined Nov 2007
You guys are doing some great work, I'm really enjoying this thread...
capntroy is offline Find More Posts by capntroy
Old Apr 25, 2012, 03:37 PM
blutoh is offline
Find More Posts by blutoh
---o-O-o---
blutoh's Avatar
United States, NJ
Joined Mar 2012
Barge
OK Guys,
since nobody bit on my barge hint I guess its up to me I am thinking like one of these ropanach made: http://www.rcgroups.com/forums/showthread.php?t=532884
But what would be an appropriate size for Salty? I don't want to overload it. Is 24" long a good size?
Pete
blutoh is offline Find More Posts by blutoh
Old Apr 25, 2012, 03:41 PM
JayJay76 is offline
JayJay76's Avatar
I think a barge is a great idea, now I need to figure out how to make a tow bollard!
Old Apr 25, 2012, 03:44 PM
blutoh is offline
---o-O-o---
blutoh's Avatar
United States, NJ
Joined Mar 2012
JayJay
A towed barge, or one with a notch for pushing? Which do you prefer?
Pete
Old Apr 25, 2012, 03:51 PM
JayJay76 is offline
JayJay76's Avatar
I'd prefer to tow, my Springer handles the push jobs.
Old Apr 25, 2012, 04:03 PM
blutoh is offline
---o-O-o---
blutoh's Avatar
United States, NJ
Joined Mar 2012
So we should add an "H" bitt on the rear deck for towing, right?
Old Apr 25, 2012, 04:10 PM
larryg is online now
Find More Posts by larryg
Joined Jan 2007
a little more progress, My Z poxy just came in the mail
larryg is online now Find More Posts by larryg
Old Apr 25, 2012, 04:11 PM
JayJay76 is offline
JayJay76's Avatar
I think I'm going to mount the H bit on the servo access hatch, when I figure out how to make one!
Old Apr 25, 2012, 04:15 PM
JayJay76 is offline
JayJay76's Avatar
Wow that looks great Larry! I wish I hadn't skipped the hawsers that are shown on the plan, they look great on yours. It's those little authentic details that add up to give her that salty charm.
So how many people are building right now? I'm looking forward to seeing the first one completed.
Old Apr 25, 2012, 04:23 PM
blutoh is offline
---o-O-o---
blutoh's Avatar
United States, NJ
Joined Mar 2012
Larry, looking good!
JayJay, I think maybe just ahead of the hatch, so we can go through the deck and tie it into the frame station (cross member) for strength? Notice my expert use of nautical terms To cut my hatch, I made repeated scores into the deck using a razor utility knife until there was enough length to get the tip of the Zona saw in there and cut the lines. Once I cut out the hatch, I glued in some supports under the deck to keep it even with the deck. I haven't figured out how to hinge and secure it yet.
Pete
Discussion Where to find 880mm Flat Bottom blades in the U.S.? philip frank UAV - Unmanned Aerial Vehicles 2 Feb 18, 2011 07:27 PM
Discussion Symmetrical vs Flat Bottom Wing Chophop Electric Plane Talk 1 Oct 24, 2010 08:10 AM
Discussion Looking for plans for a 9" to 12" tug like the salty BOZINATOR Dock Talk 29 Oct 31, 2009 09:20 PM
Sold Flat bottom PE foam blades for 300 class micro FP or CP heli's generalbacardi Aircraft - Electric - Helis (FS/W) 5 Apr 20, 2008 09:17 AM
Question on changing the airfoil on a Micro plane. (Undercambered to flat bottom) WarpdSpazm Modeling Science 10 Jan 29, 2005 09:39 PM
