Old Mar 17, 2011, 12:38 PM
dekan is offline
Find More Posts by dekan
D'oh.. Dumb Left Thumb
dekan's Avatar
London, UK
Joined Nov 2006
http://www.amazon.com/Small-Radio-Co...0383383&sr=8-1
dekan is offline Find More Posts by dekan
Old Mar 17, 2011, 02:35 PM
JayJay76 is offline
Find More Posts by JayJay76
JayJay76's Avatar
United States, IL, Chgo
Originally Posted by dekan View Post
LOL I ordered that this morning before running out the door to work. It's already shipped (no pun intended!) After one hour cruising with my first r/c boat (a springer) i'm hooked but good. I just bought enough 1.5, 3, and 6mm ply for two boats. I'll be sure to log this build and I will publish the plans when its complete.
As this tug is for my wife we will have a design consultation soon to settle some details about the wheelhouse and color scheme.
JayJay76 is offline Find More Posts by JayJay76
Old Mar 17, 2011, 03:45 PM
GILL RC is offline
Find More Posts by GILL RC
GILL
GILL RC's Avatar
United States, NJ, Hopatcong
Joined Aug 2005
It seems to me that you want to make the drive system very complicated.
You can use a straight drive line at an angle. This is the same method that full size use.
I am building a class A hydro plane that has a flat bottom. These are normally powered with an out board. I am using a inboard drive with a dummy outboard.
Nice and simple
GILL RC is offline Find More Posts by GILL RC
Old Mar 17, 2011, 04:03 PM
Tim B. is offline
Find More Posts by Tim B.
Tim B.'s Avatar
United States, CA, Oakland
Joined Aug 2009
Model ?
Aren't those people riding IN THE MODEL right now ?
Tim B. is offline Find More Posts by Tim B.
Old Mar 17, 2011, 05:45 PM
dekan is offline
dekan's Avatar
London, UK
Joined Nov 2006
It's a nice little book.... lots of ideas for small cheap boats..
Old Mar 17, 2011, 06:27 PM
JayJay76 is offline
JayJay76's Avatar
Nice and simple
being an airplane guy I have to ask, whats the effect of the down-thrust? does it even matter to the handling? and is my straight drive really complex? I just think a flat bottom seems too easy to build to really work well.. the box keel seems more of a midway between a real V-type hull and a flat bottom. AND it stands up on the shelf without a cradle.
Old Mar 17, 2011, 06:48 PM
Aerominded is offline
Find More Posts by Aerominded
Monterey Bay California
Joined Feb 2004
Neat looking design! I like your straight drive line approach- I think it would work very well for this boat. Flex-drive, which was suggested has one disadvantage in that it does not like to go in reverse all that well.
Aerominded is offline Find More Posts by Aerominded
Old Mar 17, 2011, 07:07 PM
der kapitan is offline
Find More Posts by der kapitan
"day ain't over yet-"
der kapitan's Avatar
Western N.Y. winemaking country
Joined Jun 2005
Aerominded, it's usually not a good idea to put reverse in a go-fast boat, because the possibility exists that you may screw yourself to the bottom if you apply too much power---.
And yes, flex cables are spiral-wound in one direction, and applying reverse would unravel them and bind up in the shaft tube---.
der kapitan is offline Find More Posts by der kapitan
Old Mar 18, 2011, 07:22 AM
GILL RC is offline
GILL
GILL RC's Avatar
Joined Aug 2005
The down thrust has very little effect. If it did there would be a lot of full size boats in trouble. Almost all boats have a down trust unless they use and outboard, stern drive, or have a very deep hull. Just take a look at all the inboard sport boats.
I went this way in the hydro so I could put a larger and faster motor in. The original 3 point hydro's were set up this way, now most use surface props, but the shaft still has an angle to it.
Kap is right a flex drive dose not work well in a scale boat. In reverse the cable can unwind and can also pump water into the boat.
Of my 105 running boats I think that about 85% have the shafts at an angle.
www.jsgill.net
By the way I also fly only 54 aircraft.
Old Mar 18, 2011, 11:17 AM
Shaun Hendricks is offline
Find More Posts by Shaun Hendricks
3 Blades to the Wind
Shaun Hendricks's Avatar
Atascadero, California, United States
You can do a music wire drive and it can reverse just fine. It won't handle as much flex as a cable wire drive but it does flex some.
Flat bottom would also lend itself to a jet drive very nicely. Many flat bottom boats are jets.
Shaun Hendricks is offline Find More Posts by Shaun Hendricks
Old Mar 18, 2011, 11:57 AM
jerryj98501 is online now
Find More Posts by jerryj98501
Olympia WA
Joined Nov 2004
Here is another option, this is the same company that I used for the Dipper 19 build using their plans. For $1.00 you can download the study plans or go to his website to see what else he has to offer. (http://store.devlinboat.com/godzilla...samerican.aspx ). Jerryj98501
jerryj98501 is online now Find More Posts by jerryj98501
Old Mar 18, 2011, 12:24 PM
Joined Feb 2004
Originally Posted by der kapitan View Post
...flex cables are spiral-wound in one direction, and applying reverse would unravel them and bind up in the shaft tube---.
Exactly!
Music wire idea is a fine one... though I really like the solution shown in jlepinske's drawings.
Old Mar 20, 2011, 07:14 AM
JayJay76 is offline
JayJay76's Avatar
Okay so a few beers later I had the hull design completed, then I set to work on some ideas for the wheelhouse.
Old Mar 20, 2011, 07:39 AM
JayJay76 is offline
JayJay76's Avatar
I came up with three concepts for the wheelhouse, and let my wife choose the shape, smokestack, and color scheme. Since this is the first R/C hobby she has wanted to get into, I'm building this boat for her.
Old Mar 20, 2011, 07:44 AM
JayJay76 is offline
JayJay76's Avatar
And the chosen design..
I'll be adding portholes, but this is the basic idea.
Discussion Where to find 880mm Flat Bottom blades in the U.S.? philip frank UAV - Unmanned Aerial Vehicles 2 Feb 18, 2011 07:27 PM
Discussion Symmetrical vs Flat Bottom Wing Chophop Electric Plane Talk 1 Oct 24, 2010 08:10 AM
Discussion Looking for plans for a 9" to 12" tug like the salty BOZINATOR Dock Talk 29 Oct 31, 2009 09:20 PM
Sold Flat bottom PE foam blades for 300 class micro FP or CP heli's generalbacardi Aircraft - Electric - Helis (FS/W) 5 Apr 20, 2008 09:17 AM
Question on changing the airfoil on a Micro plane. (Undercambered to flat bottom) WarpdSpazm Modeling Science 10 Jan 29, 2005 09:39 PM
