Old Jan 30, 2012, 02:48 PM
LukeZ is offline
Find More Posts by LukeZ
LukeZ's Avatar
Joined May 2001
Jay, that sound is so familiar! And it looks very realistic too, great job. Interesting to see how you did yours slightly different. The rubber O-ring is a real good idea, I had always tried to figure out how to put a small piece of rubber on mine to cut down on the noise of the arm slapping the stops.
I presume you will eventually have the speed controlled by the throttle input from your Rx instead of the potentiometer for testing? At full valve speed the flutter is so rapid there isn't much noticeable effect on the smoke output - but you could easily have your programming friend scale the top end so at full throttle the valve cycles at the fastest speed that still looks realistic.
One good thing about the flapper valve is that since you can have it full open or full closed, you could even create some fancy routines in code, for example, a few really big puffs on startup or the like.
Anyway, great job, and I'll be looking forward to seeing this on the water!
Luke
LukeZ is offline Find More Posts by LukeZ
Old Jan 31, 2012, 05:14 AM
JayJay76 is offline
Find More Posts by JayJay76
JayJay76's Avatar
United States, IL, Chgo
Hey Luke,
Thanks for the ideas! My buddy has already made provisions in the code to limit min. and max. throttle speeds, these I can tweak myself once the unit is mounted in a smokestack. It will be tied to throttle position as well as the fan speed, im thinking just 3 fan settings, idle-mid-max, and a cool-down routine. I hadn't thought of a start up routine, I'll ask him about it.
slightly off-topic, I had a prolonged tweak session friday night and made lots of smoke, and found that a wick made of rolled fiberglass cloth produces more smoke than the kevlar yarn does, but doesn't burn up so quickly. I woke up sick on saturday and thought i had an allergic reaction to the glycol fog but it turned out to be the worst head cold i've ever had. The thought of putting some eucalyptus oil in the fog fluid briefly crossed my mind but then I thought that might not be wise..
JayJay76 is offline Find More Posts by JayJay76
Old Feb 01, 2012, 04:09 PM
6789boat is offline
Find More Posts by 6789boat
Model trains, Rc Boats, Rc air
United States, CA, SF
Joined Mar 2009
What program are you using, not google Sketchup
6789boat is offline Find More Posts by 6789boat
Old Feb 02, 2012, 05:49 AM
JayJay76 is offline
JayJay76's Avatar
Its rhino, one of the programs I use at work. this model is getting complicated but the surfacing is all very simple compared to what I'm used to working with.
Old Mar 27, 2012, 04:28 AM
JayJay76 is offline
JayJay76's Avatar
just a quick update, I finished the hull over the weekend and painted it, photos below. I finished building the wheelhouse, now I just need to apply a bit of filler and paint it, she will be on the river this weekend at last!
Old Mar 27, 2012, 06:28 AM
JayJay76 is offline
JayJay76's Avatar
Here are some photos of the wheelhouse
Old Mar 27, 2012, 02:31 PM
GILL RC is offline
Find More Posts by GILL RC
GILL
GILL RC's Avatar
United States, NJ, Hopatcong
Joined Aug 2005
Looking good, I'm looking forward to some in water shots.
GILL RC is offline Find More Posts by GILL RC
Old Mar 27, 2012, 02:59 PM
JayJay76 is offline
JayJay76's Avatar
I'm still waiting to see some video of yours....
Old Mar 28, 2012, 08:04 AM
GILL RC is offline
GILL
GILL RC's Avatar
Joined Aug 2005
Our next meeting is at the pond on April 7, I'll try.
Old Mar 28, 2012, 03:36 PM
JayJay76 is offline
JayJay76's Avatar
Today I sprayed the wheelhouse with two coats of white primer with a thorough sanding in between, it's looking very smooth and the grain is gone so tomorrow I will spray 2 coats of bright red and wet sand the clearcoat on the Hull a bit, then on friday everything gets a coat of 2-part clear as a final seal. I'm planning to have her on the water Sunday morning. More pics tomorrow.
Old Apr 02, 2012, 06:05 AM
larryg is offline
Find More Posts by larryg
Joined Jan 2007
JayJay, your salty looks great, very nice job
larryg is offline Find More Posts by larryg
Old Apr 02, 2012, 08:18 AM
JayJay76 is offline
JayJay76's Avatar
Thanks Larry!
Revised plans will be up later this week. I need to make a few adjustments and prepare 2 versions both with and without the controversial box keel.
Old Apr 02, 2012, 10:50 AM
marter1229 is offline
Find More Posts by marter1229
marter1229's Avatar
United States, ID, CDA
Joined Aug 2005
This is a great tug.
Is Lil Salty the 9" version? It looks larger.
Like the Springers, we need many different versions of Salty, maybe one that resembles the "RED October"
marter1229 is offline Find More Posts by marter1229
Old Apr 02, 2012, 03:20 PM
JayJay76 is offline
JayJay76's Avatar
Hi marter,
No this is the 20.5" version, the 9" is called the saltine. I'll be publishing the plans shortly. I would love to see variations, I think the red October is so cool! the plans will include the wheelhouse I've built but it would be great to see someone else's ideas.
Discussion Where to find 880mm Flat Bottom blades in the U.S.? philip frank UAV - Unmanned Aerial Vehicles 2 Feb 18, 2011 07:27 PM
Discussion Symmetrical vs Flat Bottom Wing Chophop Electric Plane Talk 1 Oct 24, 2010 08:10 AM
Discussion Looking for plans for a 9" to 12" tug like the salty BOZINATOR Dock Talk 29 Oct 31, 2009 09:20 PM
Sold Flat bottom PE foam blades for 300 class micro FP or CP heli's generalbacardi Aircraft - Electric - Helis (FS/W) 5 Apr 20, 2008 09:17 AM
Question on changing the airfoil on a Micro plane. (Undercambered to flat bottom) WarpdSpazm Modeling Science 10 Jan 29, 2005 09:39 PM
