Old Mar 10, 2011, 09:44 AM
JayJay76 is offline
Find More Posts by JayJay76
JayJay76's Avatar
United States, IL, Chgo
Build Log
"Salty" Flat bottom and box keel tugs - free plans!
I've been looking at a small simple toylike tug for my second boat scratchbuild, and I like the simplicity of a flat bottom hull but I'm wondering how this shape performs as a model, and will it handle any rough water or would it be strictly for pool cruising? Lets find out!
JayJay76 is offline Find More Posts by JayJay76
Old Mar 10, 2011, 02:41 PM
keith S is online now
Find More Posts by keith S
r/c ships and workboats
bellingham, wa
Joined May 2006
Should be fairly straight forward and not too difficult for a model project. handling will depend on how big/scale you plan on making it. being that the full size is relativily small the model may want o be in a bigger scale to give you the pleasures you are hoping for.
keith S is online now Find More Posts by keith S
Old Mar 10, 2011, 03:41 PM
JayJay76 is offline
JayJay76's Avatar
Thanks Keith, I'll start working on the plans this weekend. I'm thinking about 30" or so in length
Old Mar 10, 2011, 07:59 PM
jerryj98501 is offline
Find More Posts by jerryj98501
Olympia WA
Joined Nov 2004
You might want to look at Phillip Bolger's book BOATS WITH AN OPEN MIND. He has several small flat bottom tugs and yachts with full lines that could be blown up by a copy store and give you all the information you need. I have been looking at a couple of them myself but my bench is full right now. Jerryj98501
jerryj98501 is offline Find More Posts by jerryj98501
Old Mar 12, 2011, 07:45 PM
Greg Knipp is offline
Find More Posts by Greg Knipp
Greg Knipp's Avatar
Manitowoc, Wisconsin
Joined Dec 2003
Take a look at this site. http://www.smalltugs.com/ These are simialar to what you are looking for and they are easy to work from. All you have to do is pay shipping and a set of plans can be had for any of his designs on the site. Keep in mind they are not the full shipyard set of plans with plumbing layouts etc... but enough, including offsets, to make a beautiful model.
Greg
Greg Knipp is offline Find More Posts by Greg Knipp
Old Mar 13, 2011, 06:27 PM
JayJay76 is offline
JayJay76's Avatar
I've ordered "boats with an open mind" but in the meantime I'm reading around about flat bottom boats and I started modeling a basic design. no details yet but here is a peek.
Old Mar 15, 2011, 02:08 PM
der kapitan is offline
Find More Posts by der kapitan
"day ain't over yet-"
der kapitan's Avatar
Western N.Y. winemaking country
Joined Jun 2005
From what I've seen of the expertise of most of the subscribers to these forums, any of you guys could build or develop a decent model from a simple photo---.
der kapitan is offline Find More Posts by der kapitan
Old Mar 16, 2011, 07:05 AM
JayJay76 is offline
JayJay76's Avatar
I've been reading 'Boats with an Open Mind', a great book and I really like the microtrawler, it's right along the lines of what I'm after. I was planning on a completely flat bottom hull design but I'm not completely convinced of its handling so I'm considering the microtrawler's box keel design. This also would make installing an inboard motor easier.
I've also decided my third boat will be the wyoming, another design from this book.
Thanks Jerryj98501 for recommending it.
Old Mar 16, 2011, 04:36 PM
JayJay76 is offline
JayJay76's Avatar
I'm trying to lay out the driveline components and wondering how would one position the propellor and rudder in a flat bottom hull? The plans call for an outboard in a well or just hung on the transom but I prefer an inboard installation. I thought a graupner jet drive would be a natural in this sort of boat but I'm worried about the intake sucking air because the hull will have less than 1/2" draft at the rear, maybe less. anyone have experience with something like this?
p.s. this boat is for leisurely cruising on a river so I don't want or expect high speed. I just finished my springer and she had her maiden voyage last sunday; this is the sort of performance I'm after.
Old Mar 16, 2011, 05:09 PM
GILL RC is offline
Find More Posts by GILL RC
GILL
GILL RC's Avatar
United States, NJ, Hopatcong
Joined Aug 2005
The jet drive will work just fine. You could just angle the shaft through the hull with out any problems.
GILL RC is offline Find More Posts by GILL RC
Old Mar 16, 2011, 05:54 PM
JayJay76 is offline
JayJay76's Avatar
okay here is a stab at housing the driveline in the box keel, this is more complicated than the jet drive but has the added feature of semi scale realism.
Old Mar 16, 2011, 06:17 PM
dekan is offline
Find More Posts by dekan
D'oh.. Dumb Left Thumb
dekan's Avatar
London, UK
Joined Nov 2006
I saw this bulge on the bottom of the hull on several plans... I never figured that was where the motor went... cunning..
I wonder how effective this layout would be...might be worth trying on one of Glenn Guest's simple flat bottom designs
dekan is offline Find More Posts by dekan
Old Mar 17, 2011, 03:30 AM
JayJay76 is offline
JayJay76's Avatar
who is Glenn Guest? are there some flat bottom plans here on rcg?
Old Mar 17, 2011, 12:07 PM
Towing101 is offline
Find More Posts by Towing101
USA, WA, Vancouver
Joined Oct 2010
Kinda slow progress but here is a Glynn Guest flat bottom model I am building (not a tug but same idea)....http://www.rcgroups.com/forums/showthread.php?t=1350753
Towing101 is offline Find More Posts by Towing101
Old Mar 17, 2011, 01:14 PM
Olympia WA
Joined Nov 2004
You might want to install a flex drive like the fast electric drivers use. The motor would mount on the flat bottom and the flex drive would flex down into the box and out the back. That would be an easy fix, talk to a fast electric modeler and they might have some pictures of the assembly. When you get started, be sure and start a build thread as I always wanted to build one and this might get me off the workbench stool. What size are you thinking? Jerryj98501
Discussion Where to find 880mm Flat Bottom blades in the U.S.? philip frank UAV - Unmanned Aerial Vehicles 2 Feb 18, 2011 08:27 PM
Discussion Symmetrical vs Flat Bottom Wing Chophop Electric Plane Talk 1 Oct 24, 2010 09:10 AM
Discussion Looking for plans for a 9" to 12" tug like the salty BOZINATOR Dock Talk 29 Oct 31, 2009 10:20 PM
Sold Flat bottom PE foam blades for 300 class micro FP or CP heli's generalbacardi Aircraft - Electric - Helis (FS/W) 5 Apr 20, 2008 10:17 AM
Question on changing the airfoil on a Micro plane. (Undercambered to flat bottom) WarpdSpazm Modeling Science 10 Jan 29, 2005 10:39 PM
