Go Back   RC Groups > Aircraft - Sailplanes > Electric Sailplanes
Old Oct 14, 2001, 09:54 AM   #1
stephen.s1's Avatar
Send a message via AIM to stephen.s1
Best rate of climb
I've been wondering about this subject. As applied to LMR contests.
In order to achieve the best <rate> of climb, does the assembled knowlege of this group think reflexing the airfoil would help? I haven't tried it yet.
I have tried drooping the TE surfaces (as in thermaling) The angle of climb, understandably, was more impressive. The rate however was probably off a tad due to increased drag. Following that path, why wouldn't reflex (less drag) help the ROC?
I'll try this when the rain stops... 'Til then, has anyone else wandered down this path?
stephen.s1 is offline Find More Posts by stephen.s1   Reply With Quote
Old Oct 14, 2001, 01:12 PM   #2
Ascended Master
Sparky Paul's Avatar
The only certain way to determine whether reflex or camber will improve the roc is to test. An altimeter recorder.. such as a Casio Watch.. some method of determining the altitude after a set time.. climb under power for a set time, glide back down. With a pure glider it will difficult to establish a set of conditions where the flap position change only can be observed.
Sparky Paul is offline Find More Posts by Sparky Paul   Reply With Quote
Old Oct 14, 2001, 10:02 PM   #3
Re: Best rate of climb
Depends on how the prop behaves with airspeed.
If the prop has the same efficiency at all flyable airspeeds, then you want to climb slowly at the minimum-sink speed, probably with added camber. A huge prop with a 20:1 gearbox might be close to this limiting case.
A more realistic prop will be smaller, with a somewhat lesser gear ratio. Such a prop will see some efficiency improvement at higher airspeeds, so the glider wants to climb faster than the min-sink speed to take advantage of this. Little or no camber might be best here. It depends on the particular glider.
A small direct drive prop will see the largest efficiency improvement with airspeed. The glider then should be flown quite fast to keep the prop happy. Some reflex may be appropriate to minimize airframe drag at the low CL.
- Mark
markdrela is offline Find More Posts by markdrela   Reply With Quote
Discussion What's the best rate to charge lipos at? grampi Batteries and Chargers 21 Feb 16, 2007 11:20 AM
Discussion Rate of Climb Via GPS Software? Steve McBride UAV - Unmanned Aerial Vehicles 4 May 24, 2006 08:32 PM
F5J rate of climb (measured not calculated) eye_rc_soar Electric Sailplanes 40 Mar 02, 2005 07:41 AM
Rate of Climb with a Wing? simonbryant Modeling Science 6 Feb 06, 2005 08:39 AM
Ambient Temps And Rate Of Climb? RCFlybry Electric Sailplanes 1 Aug 19, 2002 01:08 AM
Congratulations SimpleM!
