Old Mar 09, 2011, 11:40 PM
MikeSSS is offline
Find More Posts by MikeSSS
Joined Feb 2006
Do Fat Shark goggles have diopter lens slots?
I'm farsighted but can get lenses from reading glasses cheaply.
It looks like Fat Shark 5.8 GHz and 2.4 GHz 2010 and Base Edition goggles all have the slots for Fat Sharks optional negative diopter lenses. Is this correct?
The plan is to remove the positive lenses from dollar store glasses and fit them so they slide into the slots on the Fat Shark goggles.
If this works it will be the solution to the goggle problem for me.
What do you think?
MikeSSS is offline Find More Posts by MikeSSS
Old Mar 10, 2011, 12:25 AM
ryanrolds is offline
Find More Posts by ryanrolds
USA, OR, Eugene
Joined Jan 2011
Yes, they have diopter slots. I don't know if "dollar store lens" will work. I can confirm that the optional negative diopter lenses at hobby king work fine.
I know I'm only answering half your questions. Sorry.
ryanrolds is offline Find More Posts by ryanrolds
Old Mar 10, 2011, 01:16 AM
MikeSSS is offline
Joined Feb 2006
That is indeed the answer. All I have to do is make the dollar store lenses the same size and shape as the factory lenses, while preserving the inter pupil distance and it should work.
The only other complication is that factory negative lenses are thicker at the edge than in the middle but the positive lenses are thicker in the middle than at the edges.
Thanks for the help.
Old Mar 10, 2011, 10:51 AM
rcall is offline
Find More Posts by rcall
FPVing for fun...
rcall's Avatar
Joined Jul 2003
yes, you can do your own correction lenses...
http://www.rcgroups.com/forums/showt...9#post17069283
rcall is offline Find More Posts by rcall
Old Mar 10, 2011, 02:58 PM
perfeet is offline
Find More Posts by perfeet
Internal Paradigm Consultant
perfeet's Avatar
Joined Dec 2009
Here are the drawings that I obtained from the Fat Shark:
https://docs.google.com/viewer?a=v&p...VTn4JbOU&hl=no
Exact measures. Enjoy.
perfeet is offline Find More Posts by perfeet
Old Sep 04, 2012, 05:51 PM
gittarpikk is offline
Find More Posts by gittarpikk
gittarpikk's Avatar
United States, TN, Maryville
Joined Jun 2008
deleted
gittarpikk is offline Find More Posts by gittarpikk
Old Sep 04, 2012, 06:02 PM
gittarpikk's Avatar
Joined Jun 2008
I have the Dominators and the optometrist told me I needed +1 diopters in both eyes...when I asked him which I should get.
Fat Shark diopters are all + diopters... will this make the image worse. I can see it fairly well now...and without my glasses , I can see fairly well at a distance... but my glasses clears it up just a bit.
Old Jan 13, 2013, 11:16 PM
Wmacky is offline
Find More Posts by Wmacky
Joined Dec 2006
Are these docs still available?
Wmacky is offline Find More Posts by Wmacky
Old Jan 14, 2013, 09:20 AM
gittarpikk's Avatar
Joined Jun 2008
I feel certain they are... however if you are careful to measure the exact size and transfer it to the dollar store glasses with masking tape on front and back....leaving the tape on until all is done and all minor size adjustments are finished ..then peel it off for a super clear lens.
You'll want to use something like a little bench jigsaw to make the rough cuts...then a bench grinder to smooth and adjust the final shape/size..
The dollar store glasses are perfect...just get the larger ones. I had my optomotrist tell me what diopter I would need after I explained to him the Fat Shark goggles and what they offered.
If the thickness is a bit tight, you can camfer the edges rather than grind the whole surface flat... works just fine and they slid in perfect.
Best 45 minutes to one hour of labor I had ever spent on goggles.
good luck...be sure to use the masking tape to protect the lens...
Old Mar 29, 2015, 03:46 PM
488 is offline
488
Find More Posts by 488
488
488's Avatar
Canada, AB, Kingman
Joined Apr 2010
Fatshark Dominator HD Diopters
When I got the Dominator HDs, I was hoping that the image would look perfect for my rare eye condition. As I was afraid of, I'm one of the rare ones that needs some kind of correction for these which are not available. So I made some + diopters from a set of reading glasses. Only took a few hours to make and I'm quite happy with the results now.
Bear
488 is offline Find More Posts by 488
Old Mar 29, 2015, 04:52 PM
Ira NZ is offline
Find More Posts by Ira NZ
Bombs away! Err...landing
Ira NZ's Avatar
Upper Hutt, New Zealand
Joined Apr 2006
I'm nearsighted, so in theory I could use the fat shark lenses...Unfortunately they're too weak. So I've done some hacking and layered a -6 and -4, works ok, but not perfect, not quite strong enough. A lot of distortion. So I'm thinking of hacking up some old glasses to fit.
Ira NZ is offline Find More Posts by Ira NZ
New Product Fat shark 2.4ghz goggles for sale stevessub27 FPV Talk 1 Feb 05, 2011 01:35 AM
Link Fat Shark Goggles For Sale fritzdecat FPV Talk 0 Sep 11, 2010 07:16 AM
Discussion Headplay goggles or Fat Shark RCV922 Aviator Edition G-unit FPV Talk 34 Jul 25, 2010 11:24 AM
Discussion AV in om my Fat Shark RCV922 goggles doesn't work. Lynxman FPV Talk 6 Feb 21, 2009 08:10 AM
Question Fat Shark goggles & computers flyer_2 FPV Talk 3 Jun 23, 2008 01:30 PM
