Espritmodel.com Heli Air
Old Mar 09, 2011, 11:14 PM
Joined Feb 2011
s107 with 6020 tail boom and air hogs tail rotor blade
my brother installed the 6020 tail boom on his s107. it works perfectly with the stock tail blade. for some reason it doesn't work properly when he installs the air hogs tail blade. it barely moves forward.
does anyone know why this is happening?
jojo83 is offline Find More Posts by jojo83
Old Mar 10, 2011, 03:20 AM
Want heli used electonics
United States, WA, Pasco
Joined Mar 2011
I think the S107 moves forward using the tail rotor to tip the thing forward.
Several things could be causing your situation. The replacement rotor could be just heavy enough to make it imbalanced toward the back. You might try putting a counterbalance weight toward the front. Maybe tape a paperclip or coin onto the front, see if it helps.
Or it could be that for some reason the tail rotor is not getting the thrust it should. Is it placed upside down or bent?
Is the tail rotor spinning as it just hovers? Does it move backward but just not forward?
If all else fails just use the one that works.
Good luck
michaelstoops is offline Find More Posts by michaelstoops
Old Mar 10, 2011, 05:26 AM
Newcastle Area UK
Joined Jul 2010
could be the rotor slipping on the shaft see this thread http://www.rcgroups.com/forums/showthread.php?t=1347821
Rodeown is offline Find More Posts by Rodeown
Old Mar 10, 2011, 10:12 AM
scorp's Avatar
Cupertino, CA
Joined Nov 2010
thats part of the reason, the other is that an air hogs prop will not give you increased forward speed on the 6020 motor over a 6020 prop, stick with the rounded prop that was designed for that motor
scorp is offline Find More Posts by scorp
Old Mar 11, 2011, 07:41 AM
Joined Feb 2011
really weird. looks like this guy got his to work. i don't think that its a weight issue. the stock prop works perfectly fine and the air hogz prop wouldn't add that much wait for it to barely move forward.
Speed demonstration of 6020 tail on s107 with Air Hogs tail prop. (0 min 17 sec)
New Product Air Hogs Helix 360 4ch Single rotor IR Heli Radio Shack Version! modfly Micro Helis 338 Apr 30, 2013 02:09 AM
Discussion Anyone using an Air Hogs Reflex charger with a Syma S107? Jids Electric Heli Talk 0 Feb 28, 2011 07:18 AM
Rave Air Hogs 4 ch IR Helix 360 Single rotor Heli modfly Micro RTF 29 Jan 15, 2011 11:55 PM
Discussion 6020-1 Tail Prop on S107 GTP1 Coaxial Helicopters 5 Dec 09, 2010 12:09 PM
