Espritmodel.com Heli Air
Old Mar 09, 2011, 07:33 PM
Manila, Philippines
Joined Jul 2004
Converting a PPM 9 channel to PPM 8 channel.......
Guys, I want to convert my Aurora 9 PPM 9 channel to PPM 8 channel so that I could use a Futaba DSM2 Modules on my Aurora 9........I was hoping someone already done this.
The possible solution....
1. use a microcontroller, read a ppm signal and masked of the 9th channel.....which is doable.
2. use a Hardware circuits, use a mono-stable circuit to MASKED-OFF the 9th channel.....
I like the hardware solution, the Circuit is just like a MISSING PULSE DETECTOR, after detecting the Missing Pluse (This is actually a Synchonization pulse)..... the circuit will just produce a Short pulse that is Long enough to MASKED-OFF the 9th channel.......its just a simple 555 Timer circuit and a Gate, the Gate Could be a AND Gate or the OR Gate depending on the signal produce by the Aurora 9.
lazy-b is offline Find More Posts by lazy-b
Old Mar 09, 2011, 09:28 PM
Stoats's Avatar
USA, TX, College Station
Joined Sep 2008
Probably the quickest and most reliable would be to use a small PIC or AVR to read the trainer port and output the appropriate pulse train for a module. You could make it autodetect positive/negative shift so it can be generic. Power the module with its own battery so you don't have to ever swap modules (just make a little box to hang off of the handle). I mainly forget what the pulse train looks like coming out of the Futaba that the Spektrum is expecting (do the pulses go low to high or vice-versa).
I've got an idea for an analog/IC solution but it would take longer to make it and test than programming a PIC. You could use NOTs and an AND to make the rising edge pulse which feeds a counter. Set a latch at 8 which cuts off the output AND circuit. At count=9 and the pulse train goes low, then reset counter/latch. Lots of IC's. I'm not a 555 guru so there's probably some interesting ways to do something similar.
If I hadn't loaned out my 9C + Spek module, I could probably knock it out in a couple hours (most of the time spent relearning PIC and getting the uC running).
Stoats is offline Find More Posts by Stoats
Old Mar 10, 2011, 04:07 AM
Manila, Philippines
Joined Jul 2004
Been Thinking it was a Constant Frame Rate, it would be easier to just Simple Masked-off the Last Pulses, but it was a Variable pulse so you need a counter to keep track of the channel.........Ok, its complicated using a Hardware Solution.
using a microcontroller, we need to MASHED-OFF just the Last 9th channel pulse......we need to the INPUT PPM signal should be directly Connected to the OUTPUT PPM Signal that connected to a Single Gate.......the Gate could be a AND or an OR Gate depending if its a Normal High or Normal Low signal..........a Control Bit call MASK-OFF is connected directly to the microcontroller, the Mask-off the last 9th channel.
You could use a DIODE instead of a Gate.
The Main Program will first look for the Channel 1, by looking for a long delay (Sync Pulse)......then start counting from the Edge, until you reach the 8 channel , wait until you able to let the 8th channel finished, then you Activate the Mash-off bit for until the 9th channel have finished.
Old Mar 10, 2011, 07:32 AM
USA, NY, Syracuse
Joined May 2005
use a 4017 decade counter and recombine only 8 outputs
beer-man is offline Find More Posts by beer-man
Old Mar 10, 2011, 09:07 AM
Manila, Philippines
Joined Jul 2004
look like the 4017 is Good Idea, its what most FM Receiver decode PPM signal to Individual servo pulses.......Look like I could use The 8th channel Pulses to Produce another Pulses to Mask-out the 9th Pulses.
Anyway, will try to Record The Actual PPM signalof Aurora 9........will try to post it here.
a 4017 and 555 and a DIODE will just do the JOB.
Thanks for all suggestion.
Old Mar 10, 2011, 11:22 AM
Joined Dec 2006
This is a very interesting topic! I hope you guys succeed!
Spacemarine is offline Find More Posts by Spacemarine
Wanted Futaba 72mhz PCM 8-9 channel Receiver barbarroja Aircraft - General - Radio Equipment (FS/W) 4 Jan 09, 2011 12:13 PM
Sold Futaba 8FGA 8-Channel 2.4GHz Air Transmitter and R6008HS 8-Channel Receiver $350.00 mike(ocrc) Aircraft - General - Radio Equipment (FS/W) 7 Oct 13, 2010 10:30 PM
Wanted Futaba 8 or 9 channel 72Mhz transmitter runamuk Aircraft - General - Radio Equipment (FS/W) 0 Sep 23, 2010 08:39 AM
Discussion Futaba 8 and 9 channel PPM output to RF mdoule? bigandy DIY Electronics 9 Mar 02, 2008 12:23 PM
Discussion XPS Futaba 9 CAP-8 channel combo for sale + and additonal 8 channel receiver!!! Al Czervik Aircraft - General - Radio Equipment (FS/W) 3 Feb 12, 2008 03:38 PM
