Old Mar 09, 2011, 02:40 PM
Scott_S. is offline
Find More Posts by Scott_S.
Joined Feb 2007
How to wire 4S lipo to Hitec Optima Rx (Aurora 9)?
Guys, have any of you done this yet? I want to wire the Optima Rx SPC port to read the 4S 14.8 volt lipo on the Aurora 9 screen and set up the min voltage alarms.
I have the typical lead coming from the ESC to power the servo buss but is'nt that going to be about 5 volts?
It's on a E-Flite PNP Carbon Z Yak. I can't try it yet, the lipos are in the mail.
Thanks for any help.
Scott_S. is offline Find More Posts by Scott_S.
Old Mar 09, 2011, 04:40 PM
A.T. is offline
Find More Posts by A.T.
Joined Aug 2002
Optima Transceiver (RX) - SPC - SPC connection & Lead Detailed plus Optima Current Draw/Amps
ex Hitec USA Support Forum Sticky:
Aurora 9, Spectra Modules & Optima Transceivers - FAQ & Undocumented Features
- Mixes, Setups, Tips. {Individual Links often updated}
Optima Transceiver (RX) - Low Battery Warning settings for both Aurora & Spectra 2.4Ghz module.
Adjustable LBW Voltage Alerts V1.07 up (not available V1.04<06).
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
(quick search = Ctrl+F)
A.T. is offline Find More Posts by A.T.
Old Mar 10, 2011, 09:49 AM
Scott_S. is offline
Joined Feb 2007
Thank you Alan.
It looks complicated. I'll just set the timer to 5 to 7 minutes and monitor recharge capacity.
I bookmarked your excellent page!
Old Mar 10, 2011, 12:44 PM
MikeMayberry is offline
Find More Posts by MikeMayberry
Hitec/Multiplex USA
MikeMayberry's Avatar
Poway, California, United States
Joined Sep 2000
No it's not complicated... if you can solder on a connector to your speed control wire you can add this connector which is all that is needed. Not only will it provide voltage telemetry but it will prevent you from ever having a brownout due to the BEC in the ESC so it is highly recommended that you use this feature.
Mike.
MikeMayberry is offline Find More Posts by MikeMayberry
Old Mar 10, 2011, 02:42 PM
Scott_S. is offline
Joined Feb 2007
Mike.
Hi Mike, thanks for the reply. I know you're a busy man.
I bought the A9 after sitting in on your A9 programming seminar at Toledo in
April 2010.
I found the hand drawn schematic on Alan's link, well done A.T.
I'm going to use an old servo lead for it. It's gonna be nice to have a min volt alarm come in.
Sold Hitec Aurora 9 with 9 channel Optima and 6 channel Optima reciever stangman67 Aircraft - General - Radio Equipment (FS/W) 1 Feb 22, 2011 03:19 PM
Sold Hitec Aurora 9 + (2) Optima 9 + (3) Optima 7 + HP-22 Programmer $450 speedys4 Aircraft - General - Radio Equipment (FS/W) 8 Oct 01, 2010 09:28 PM
For Sale Hitec Aurora 9 + (2) Optima 9 + (3) Optima 7 + HP-22 Programmer $450 speedys4 Aircraft - General - Radio Equipment (FS/W) 3 Sep 26, 2010 08:00 PM
Sold Hitec Aurora 9 2.4GHz Tx & Optima 7-Channel Rx Hollywood_07 Aircraft - General - Radio Equipment (FS/W) 6 Sep 21, 2010 07:22 PM
Sold Hitec Aurora 9 w/ 7ch Optima RX .... $299 shipped n3nmechanic Aircraft - General - Radio Equipment (FS/W) 0 Sep 20, 2010 01:09 PM
