Joined Sep 2009
2.4GHz Rc range test
Hi,
Yesterday i tested my FPV setup of 1280MHz Video link and 2.4GHz RC that ended with an uncontrollable plane hitting the ground. I have read in this forum that the above is a safe choice but it seems it isn`t. I am using the FOX-800 systems in pair with http://www.hobbyking.com/hobbyking/s...idProduct=9042 of a friend that was flying in the same field. His easystar lost its nose and i lost my confidence to fly with it again. Anybody has a clue what went wrong and how to fix it (w/o Low pass filters) I must add that my servos never jittered and VTx had a separation of about 20cm from the RC Rx. Thank you. Teo |
Latest blog entry: My 2012 FPV year in Review
Reno, NV
Joined Nov 2009
Personally I ground test (With the video on, and with a heatsink attached or a fan blowing on it) out to the range I want to fly. I've ground-tested out to 2KM with my setup, so that's as far as I'm willing to fly in THAT environment. Is the hobbyking 2.4Ghz system a FHSS system?
frequencies they shouldn't, closer to 1Ghz than 1.2Ghz with that Tx, and they're using something other than the very cheapest 2.4Ghz systems available (cheap 2.4ghz Rx's have inferior input filtering). That said, the only truly safe, reliable, proven option is to add the low pass or notch filter. It's not expensive at all when compared to the possibility of losing the whole plane. ian |
Joined Sep 2009
You ground test at 2Km . Is that LOS? |
Reno, NV
Joined Nov 2009
And yes, I set the plane on a plastic surface about 3ft off the ground, hopped in my Jeep and drove to a LOS point 2km away as indicated by Google and operated both video and RC control within the jeep with it running. So in a non-optimal condition (inside a vehicle, with my cell phone, with the vehicle and it's alternator running and generating whatever amount of rf noise that is generating) I was able to control my model and see video while rotating both my RC TX and my video RX antennas. But I'm using a low pass filter, and a 1W boosted 2.4Ghz FrSky FHSS system. |
Joined Sep 2009
Yes the Video Tx was running.
But the truth is that i did the range test after the crash. My friend was holding the plane and i was standing next to the video Rx where i was when flying and he walked until the crash point and past that wit no RC loss or what so ever. I will try your way (Car drive away) next time. Teo |
Reno, NV
Joined Nov 2009
Also, not sure how well that RC system will work for FPV. No diversity, unknown TX power (could be 10mw for all you know, since I believe some countries limit it to 10mw), might not be spread spectrum... Might want to fly non-fpv for awhile and make sure that RC system even works at 200 meters without fpv gear on it... Pretty much everyone advises that you should fly the model non-FPV to make sure there's no issues before attempting FPV flight with it. Also, test, test, test, and re-test after that. An ounce of prevention saves 2 ounces of glue! I found that out when I re-launched my plane after landing without checking everything over. Ended up the elevator joint had failed and I crashed shortly after. |
I have almost the exact same setup. 1280 Mhz 800w Vtx Fox. Futaba 2.4 Ghz Full range receiver (two antennas at the right angles)
Problems with freezing controls even 150-200 meters away sometimes. Never been more than 350 meters away, because I am scared of loosing control of the plane. Video quality is great though. No jittering of servos. I have flown the plane to a tiny dot i size without the video turned on. It is basically nervewrecking like this ![]() I have grounded my plane till the DragonLink comes (takes a long time to get it )I will not get the 45$ low pass filter since I ordered the DL. Will have to be satisfied with my EDF Jet and a normal SkySurfer in the mean time. |
Joined Sep 2009
I am also waiting for my DL to be used with my long range Easyglider that will be using 2.4GHz for video. I only bought the FOX unit so that i can fly FPV at the same field chasing my budies. No luck so far. Teo |
Reno, NV
Joined Nov 2009
You never know... could have even been the BEC in the ESC might have sagged low enough to cause the RC TX to fail during your launch (assuming you crashed during launch).
A low pass filter would definitely be wise, however, even if you're going to use a DL system, since your vid TX may interfere with GPS as well (if you're using an OSD that is). |
| Thread Tools | |
| Discussion 35Mhz RC Range with 2.4Ghz Video Downlink | a9amg | Aerial Photography | 10 | Feb 05, 2010 04:51 AM |
| Discussion 2.4Ghz 500mW Pen Booster Range test | sirocco | Video Piloting (FPV/RPV) | 12 | Oct 02, 2009 05:26 AM |
| Discussion Spektrum 2.4Ghz range test issues!!!!! :eek: | speedy_1 | Australia | 7 | Oct 09, 2008 06:48 AM |
| Discussion Range Test failed with Graupner IFS 2,4Ghz. Why? | Kleiner Pilot | Xtreme Power Systems | 32 | Nov 19, 2007 11:09 PM |
