Old Jan 28, 2013, 02:24 PM
Zeta30 is offline
Find More Posts by Zeta30
Team Mulikow
Zeta30's Avatar
Joined May 2007
Originally Posted by georgeintexas View Post
I'm having a yaw problem. As soon as I start to advance the throttle the tail rotor begins turning. This is normal except that the heli then begins turning to the right, even before the main rotor begins to turn. It slows a bit as the main spins up but lifting off results in wild spinning. I visually inspected the FET but there's no obvious failure there. Is there something else I should look for? The radio is a dx4e.
George
Did this issue just appear out of nowhere or did it happen after a crash? It almost sounds like you got the gyro reversed in your TX. Check the settings in your Transmitter compared to the manual and make sure the gyro isn't reversed.
Zeta30 is offline Find More Posts by Zeta30
Old Jan 28, 2013, 04:39 PM
M3ATpl0w is offline
Find More Posts by M3ATpl0w
Progress with the process...
M3ATpl0w's Avatar
NE Alabama
Joined Feb 2011
Hey guys. I got the mCPx2 a couple of months ago, and really been enjoying it. I have been flying in normal mode, just trying to get the hang of it. Well, got brave this weekend and flipped into IU, and she fell out of the air like a rock. I went over and picked her up, and the little blue led on the main board was flashing. Not real fast like when you are binding, but like blink-blink-blink-pause, blink-blink-blink-pause. Now, even in normal mode, I can take off and hover for 10 to 30 seconds, and she drops like a rock, with the same flashing led. Tried rebinding...no help. Tx is a DX7, programmed per manual. Anyone have any ideas? TIA
M3ATpl0w is offline Find More Posts by M3ATpl0w
Old Jan 28, 2013, 04:48 PM
stevebarrow is offline
Find More Posts by stevebarrow
Heli Mad
stevebarrow's Avatar
Australia, VIC, Elsternwick
Joined Feb 2002
Looks like it might be in non computer mode as the slow blink is normally seen with using a non programmable transmitter. Double check you are binding into computer mode - from memory might need right rudder on binding. If not this check your curves for idle up in the Tx
stevebarrow is offline Find More Posts by stevebarrow
Old Jan 28, 2013, 05:02 PM
Zeta30 is offline
Team Mulikow
Zeta30's Avatar
Joined May 2007
Are you using the stock batteries by chance? A flashing LED could mean a couple of things:
1. The most common reason is low voltage. (the stock batteries are horrible and don't maintain their voltage well in stunt mode). One of my OEM batteries wouldn't even hold a charge well enough to hover the heli when it was right out of the box.
2. Binding issue. I know that you have re-bound the TX but when you did this process did you move the throttle to the far right? If not then the heli may think it is bound to a non-computerized radio which will cause issues.
Old Jan 28, 2013, 05:22 PM
M3ATpl0w is offline
M3ATpl0w's Avatar
NE Alabama
Joined Feb 2011
Thanks for the help guys. Will try and report back.
Old Jan 28, 2013, 05:53 PM
Kilo60 is offline
Find More Posts by Kilo60
Plane Crazy!!!
Ft. Lauderdale, FL
Joined Sep 2006
What is the advantage to metal/aluminium swash on this bird?
I was at my LHS and saw they had a large stock of meatl/aluminum swash plates and bearings?
IS it just for durability or does it help this one fly better?
THANKS!
Kilo60 is offline Find More Posts by Kilo60
Old Jan 28, 2013, 06:07 PM
Zeta30 is offline
Team Mulikow
Zeta30's Avatar
Joined May 2007
THANKS!
The stock plastic swash doesn't last very long. After about 100 flights mine developed a lot of slop. The Micro Heli swash will hold up better and not develop the slop, (not as fast as the plastic one anyway, they all wear out some time though).
Old Jan 28, 2013, 06:23 PM
J_skaggs is offline
Find More Posts by J_skaggs
United States, CA
Joined Jan 2012
THANKS!
Go for it. It is one of two must haves for this heli. It takes the play out of the rotor assembly. The other is a solid cf extended tail boom.
J_skaggs is offline Find More Posts by J_skaggs
Old Jan 28, 2013, 09:06 PM
georgeintexas is offline
Find More Posts by georgeintexas
United States, TX, St Paul
Joined Dec 2012
I'm embarassed to report what the problem was. Evidently I bumped the rudder trim as it was pushed all the way against the stop to the right. Putting it back in the middle where it belonged brought everything back to normal. I practiced hovering in the living room tonight for 8 batteries worth. Wow, the mcpx is a pretty big step up from the v911! Only hit one piece of furniture so it was a good session.
Thanks for the help.
George
georgeintexas is offline Find More Posts by georgeintexas
Old Jan 28, 2013, 09:57 PM
Zeta30 is offline
Team Mulikow
Zeta30's Avatar
Joined May 2007
We've all had those moments, glad you got it figured out.
Old Jan 29, 2013, 12:58 AM
lebaez is offline
Find More Posts by lebaez
Noobster
lebaez's Avatar
United States, TX, Spring
Joined Mar 2012
George
One piece of furniture is not bad at all, I think I've tagged all mine at one point (good thing the wife wasn't watching).
I stepped up from a 120SR, but perhaps I wasn't ready for that. Still fun though.
lebaez is offline Find More Posts by lebaez
Old Jan 29, 2013, 07:35 PM
CPMBOY is offline
Find More Posts by CPMBOY
CPMBOY's Avatar
Malaysia, Sabah, Kuala Penyu
Joined Aug 2011
scale fuselage for mcpx
any of you guys did this to your mcpx and where to get one?......
CPMBOY is offline Find More Posts by CPMBOY
Old Jan 29, 2013, 08:48 PM
J_skaggs is offline
United States, CA
Joined Jan 2012
They have them at my LHS . I have no interest. I suspect it would put quite a load on the stock motor which would really slow it down but, I would think that anyone wanting it would be into scale flying.
Old Jan 29, 2013, 09:25 PM
Joined Dec 2012
After another good flying session today at lunchtime I moved out one of my v911s and moved the Mcpx into the heli case.
Life is good.
George
Old Jan 30, 2013, 02:43 AM
CPMBOY is offline
CPMBOY's Avatar
Joined Aug 2011
Life is good.
George
nice...a complete learning package for beginners......
Discussion Blade mCP X BNF Heli... ChuckTseeker Micro Helis 15686 Sep 07, 2016 02:54 AM
Discussion Blade mCP X Discuss anything thread A Rdnek Micro Helis 457 Jul 26, 2011 11:34 PM
Discussion The New BLADE mCP X Has Arrived... ChuckTseeker Electric Heli Talk 38 Mar 27, 2011 07:35 PM
Discussion new blade mcp X anyone know anything new. epoweredrc Atlanta Area RC 6 Mar 16, 2011 08:14 PM
Discussion Blade mCP x - strictly on topic Q and A thread jdog83 Micro Helis 58 Feb 07, 2011 02:28 PM
