Old Jan 10, 2013, 03:46 PM
Zeta30 is offline
Find More Posts by Zeta30
Team Mulikow
Zeta30's Avatar
Joined May 2007
Originally Posted by St.Eve View Post
Thanks for the tip. So you're doing this with the battery removed from the battery holder and not in the holder?
You can do it either way, which ever you prefer. I do it with the battery still in the holder as that's easier for me I had the battery out in this case just to take the picture.
Zeta30 is offline Find More Posts by Zeta30
Old Jan 10, 2013, 03:56 PM
St.Eve is offline
Find More Posts by St.Eve
Joined Mar 2012
I tried doing it with the battery in the holder but I found that my fingers bend the rear portion of the landing skids when trying to squeeze them in between the skids. I'll try removing the battery completely since it works.
St.Eve is offline Find More Posts by St.Eve
Old Jan 11, 2013, 07:02 PM
EJ1208 is offline
Find More Posts by EJ1208
Joined Sep 2011
i didnt no where to post this but i just finished my full brushless mod with blheli firmwareName: ImageUploadedByTapatalk1357952417.203838.jpg
Description: Name: ImageUploadedByTapatalk1357952516.939198.jpg
Description: Name: ImageUploadedByTapatalk1357952523.573864.jpg
Description: Name: ImageUploadedByTapatalk1357952530.388502.jpg
Description:
EJ1208 is offline Find More Posts by EJ1208
Old Jan 11, 2013, 08:29 PM
ahicks is offline
Find More Posts by ahicks
United States, MI, Waterford Charter Township
Joined Aug 2008
MCPX noobie question here? Just getting back into heli's after a loooong absence. Haven't flown a collective heli since 60 sixed Xcel's and 32 sized Shuttle Zx's were popular (15 years)?
Anyway, decided to pick up an MCPX to play with while I'm putting a clone 450 together. Here's my question, in a hover, well out of ground effect (4ft.?) I have to hold a lot of forward cyclic and a little left rudder to keep the thing stationary. Normal, or not? Using the 4 ch. that came with it. Will be moving to a 7ch as soon as it gets here and I get that figured out....
Thanks, -Al
ahicks is offline Find More Posts by ahicks
Old Jan 11, 2013, 09:01 PM
EJ1208 is offline
Joined Sep 2011
check ure trims and rebind the transmitter, but when u bind it dont move the heli let the gyros inisialize
Old Jan 11, 2013, 09:21 PM
EJ1208 is offline
Joined Sep 2011
i have a question, im not getting alot of negative pitch in idle up, does anyone no a good lenght for the pushrods. i have a caliper i could use to check the lenghts. i tried adjusting them but in not getting any luck
Old Jan 12, 2013, 06:21 AM
jrjr is offline
Find More Posts by jrjr
Gravity impaired
jrjr's Avatar
United States, NY, Wolcott
Joined Nov 2004
You should adjust them so that the swash is as close to centered you can get and level at mid stick and have 0 pitch. Then set pitch travel up in your transmitter.
jrjr is offline Find More Posts by jrjr
Old Jan 12, 2013, 06:24 AM
jrjr is offline
Gravity impaired
jrjr's Avatar
Joined Nov 2004
I have about 10 flights on my mcpx. So far I have only been able to flip it once. All other tries have resulted in tbo. Just extended the tail boom to 6 1/4" so we will see how that works. Also just received some 300mah Nano batteries. They should help too. Been practicing on Phoenix to use the least amount of collective possible.... next step is brushless I guess. I know collective management is needed on this bird from what I have read so we will see. It flies great in normal flying though!
Old Jan 12, 2013, 08:22 AM
Zeta30 is offline
Team Mulikow
Zeta30's Avatar
Joined May 2007
Thanks, -Al
That is not normal. You should be able to hover with minimal stick input. There could be a number of causes from wrong TX settings to bad mechanical set up. As others have said go through the TX and make sure there is no trim anywhere. Make sure the swash is level too. It's also possible that a push rod or two may be uneven.
You didn't mention if you bought the heli new or used. If you bought it used, the tail issue could be from the motor wearing out. If you bought it new, again check that there is no trim for the rudder on the TX. It could also be a bad motor if the heli is new.
Old Jan 12, 2013, 11:47 AM
Tom_1971 is offline
Find More Posts by Tom_1971
Tom_1971's Avatar
Italy
Joined Jun 2008
Yesterday, while hovering at eyes' level, I noticed that main blades are slightly out of track. However, the blade links have fixed length. Did the same happen to someone else? Is there any way to adjust the tracking? Thanks.
Tom_1971 is offline Find More Posts by Tom_1971
Old Jan 12, 2013, 12:03 PM
pmackenzie is offline
Find More Posts by pmackenzie
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
You could try swapping the links, or putting on another pair.
Blade grips or swash might be damaged.
pmackenzie is offline Find More Posts by pmackenzie
Old Jan 12, 2013, 12:22 PM
Zeta30 is offline
Team Mulikow
Zeta30's Avatar
Joined May 2007
Check the feathering spindle. If that gets bent your blades will not track well. The easy way to check this is to remove one of the blades, then take a screw driver and spin the screw that is holding the blade grip on the shaft. Watch the other blade, if the blade is moving up and down or side to side then you know the shaft is bent.
The feathering spindle is a little weird on the mCPX where one side has a Phillips screw and the other side uses a straight slot screw driver.
Old Jan 12, 2013, 12:55 PM
pmackenzie's Avatar
Joined Dec 2002
^^ +1
Should have known that, mine did it
Old Jan 12, 2013, 04:19 PM
habitforming is offline
Find More Posts by habitforming
ΜΟΛΩΝ ΛΑΒΕ
habitforming's Avatar
USA, KY, Hebron
Joined Dec 2005
how much difference would be considered "out of track?"
mine has never been perfectly equal. without flying now and looking again, i remember it to be in the 2-3mm range. how does this compare to others?
habitforming is offline Find More Posts by habitforming
ahicks is offline
Joined Aug 2008
Many thanks for the replies! It is a new one.
So as a senior, I am officially calling it a DUH!!! moment....
The trims were not centered, and I knew that. A lesson has been learned.....
I thought I had read where the trims were not effective because of the gyro's, but apparently I didn't understand what I was reading properly, as it's now pretty apparent they are for sure!
Heli is now flying pretty well as expected. Thanks guys...
Discussion Blade mCP X BNF Heli... ChuckTseeker Micro Helis 15686 Sep 07, 2016 02:54 AM
Discussion Blade mCP X Discuss anything thread A Rdnek Micro Helis 457 Jul 26, 2011 11:34 PM
Discussion The New BLADE mCP X Has Arrived... ChuckTseeker Electric Heli Talk 38 Mar 27, 2011 07:35 PM
Discussion new blade mcp X anyone know anything new. epoweredrc Atlanta Area RC 6 Mar 16, 2011 08:14 PM
Discussion Blade mCP x - strictly on topic Q and A thread jdog83 Micro Helis 58 Feb 07, 2011 02:28 PM
