Old Dec 04, 2012, 08:35 PM
stuball56 is offline
Find More Posts by stuball56
Which way is up?
stuball56's Avatar
Michigan, USA
Joined Mar 2008
I bought a used one and then a brand new one. The used one had a full metal head and shaft upgrade. I put the shaft and head into the new one after flying it stock. For me it did actualy "fly" better. It seemed more stable and less touchy. I am not an experienced pilot though. So my "review" is based strictly on feel, not anything technical, as I have alot to learn about setting up a heli. But, the aluminum upgrades feel very smooth and even. With both setups I leveled the swash as best I could and set it up the same.
stuball56 is offline Find More Posts by stuball56
Old Dec 04, 2012, 08:50 PM
HyperHelis is offline
Find More Posts by HyperHelis
Pilot Dragonfly
HyperHelis's Avatar
Slidell, La
Joined Oct 2006
Cool, thanks guys!
HyperHelis is offline Find More Posts by HyperHelis
Old Dec 04, 2012, 09:01 PM
Jboy90277 is offline
Find More Posts by Jboy90277
United States, CA, Palos Verdes Peninsula
Joined Dec 2011
Originally Posted by pilot_dragonfly View Post
Hey guys one more quick question. Is it worth buying the metal rotor head(just the head) ? If so, is the xtreme worth it or should I just buy the microheli version?
The biggest benefit of my metal rotor head is it retains the linkage should you crash (has a closed slot vs the open one on the stock plastic head). With the stock one, I was losing a lot of linkages.
Jboy90277 is offline Find More Posts by Jboy90277
Old Dec 05, 2012, 04:49 AM
PLMS is offline
Find More Posts by PLMS
Martin - AKA mr.sneezy
PLMS's Avatar
Joined May 2004
'Hard' start issue ?
I have two MCP X's.
One I got given recently by a flyer who had too many issues with it to want to keep going.
I solved two of his sad issues but am left with a third I didn't anticipate. It won't do a normal soft start on the main rotor motor, it's is either fully on or fully off, no proportional speed control in 'normal' flight mode.
It goes fully on at about 10% pitch stick and does it so hard that the heli flips over on it's side every time. My other MCP X works fine on the same TX and the same model memory, so it's not a TX programming issue. If I hold the heli by hand during the violent spool up it can be flown, so the rest of the 3-in-1 FC board seems to work normally. I've tried rebinding twice or more times...
Has anyone seen this before and know if it's a 3-in-1 board fault or maybe something else ??
Martin
PLMS is offline Find More Posts by PLMS
Old Dec 05, 2012, 09:21 PM
Beancounter is offline
Find More Posts by Beancounter
Beancounter's Avatar
United States, MA, Sterling
Joined Sep 2009
Originally Posted by PLMS View Post
I have two MCP X's.
Martin
I have something close to that, mine won't spool up until until it gets over half throttle then I seem to have full control. This happened to me after I sent the 3 in1 to get a new FET. I have also replaced the main motor and main gear but nothing seems to work.
Beancounter is offline Find More Posts by Beancounter
Old Dec 06, 2012, 02:18 AM
PLMS is offline
PLMS's Avatar
Joined May 2004
[QUOTE=Beancounter;23453007 This happened to me after I sent the 3 in1 to get a new FET.[/QUOTE]Can you see if you can read the FET's marking ?
I'm curious to see if they used an original part or a different one (there are two side by side BTW on the board for the main rotor motor).
There is a driver transistor between the MCU and the FET. I also wonder now if it's damaged...
Martin
Old Dec 07, 2012, 01:50 PM
coolboarder is offline
Find More Posts by coolboarder
Plane on the Brain
coolboarder's Avatar
Joined Apr 2005
Howdy. I picked up a v2 for $99 and got my first 6 packs through it.
I was happy with the power and predictability with rolls, flips, and inverted (nose first) figure 8s especially since there was a constant 4mph wind. I was disappointed with any tail first circuits since i need practice so i don't dork in my 450
I think i will get the extended tail boom next time i'm at the hobby shop, but none-the-less this is a great value. I hope i can keep it in one piece
coolboarder is offline Find More Posts by coolboarder
Old Dec 07, 2012, 10:29 PM
PLMS is offline
PLMS's Avatar
Joined May 2004
Martin
Quoting myself above. It did not turn out to be the driver transistor at fault, and I have resolved the issue. I used an oscilloscope and probed from the MCU pin through to the FET output under different throttle conditions to find out what was going on.
The resolution was to lower the value of the pull-up resistor on the input of the main motor FET's. The reason that was a problem was that they were replacement FET's and have a higher gate capacitance than the originals. With the original 10K pull-up, the output transistors were not switching off in between PWM pulses. With 5K it's now fine, and the startup is now gentle, maybe even better than my other mcp X with original FET's.
While testing lower value pull-up resistors I noted that at really low values (like 300ohms or so) the amount of throttle stick required for motor startup gets up above half. Which is what beancounter has on his 3-in-1 after it was repaired. It may be that the repairer fitted a new resistor as well as FET's and it's way too low a value...
Normally I find that motor control FET's are driven fully on/off quite hard, but the mcpX 3-in-1 has the pull-up value set to round-off the falling edge of the PWM pulse quite a lot it seems, rather than a square falling edge. This pulse rounding is adjustable by the value of the pull-up resistor, and needs to be changed to suit the type of replacement FET's used, if they are not working like the originals.
Martin
Old Dec 08, 2012, 04:48 AM
Aviefly is offline
Find More Posts by Aviefly
Aviefly's Avatar
United Kingdom, Aviemore
Joined Feb 2005
Wow having skills like that must come in handy. I wouldn't have a clue where to start and most of that fired clean over my head. Wouldn't it be easier to just replace the FET's with an identical part to avoid all of this? I haven't had to do it yet but I'm sure the time will come at some point.
Aviefly is offline Find More Posts by Aviefly
Old Dec 08, 2012, 06:32 PM
PLMS is offline
PLMS's Avatar
Joined May 2004
I was fortunate to be in the last batch of properly trained radio technicians in Australia (AFAIK), back in the mid 1980's.
The FET's I used are the higher power of the two commonly suggested (Si2333CDS and Si2315BDS). The Si2333CDS is the one rated at 7.1Amps, and while they are never likely to blow up again it does have about double the gate capacitance, and that is a potential issue unless the pull-up resistor value is halved.
So yep, if I'd picked the Si2315BDS I would have had no issue, but the higher rating of the Si2333CDS got to me
At least now I (we) know how to use the Si2333CDS on the motor side and what the effect of the value of the pull-up resistor is on the start-up characteristic of the motor.
There will be somebody sometime here who will be happy to know the info I guess...
Bye.
Martin
Old Dec 08, 2012, 07:10 PM
keithy4129 is offline
Find More Posts by keithy4129
United States, NJ, Clayton
Joined Aug 2010
Hey guys, how many flights are you averaging on the main motor and a tail motor. I don't do.3d (yet) but I am hard on the collective sometimes.
keithy4129 is offline Find More Posts by keithy4129
Old Dec 08, 2012, 07:17 PM
Zeta30 is offline
Find More Posts by Zeta30
Team Mulikow
Zeta30's Avatar
Joined May 2007
I've gone through two, the first one lasted about 100 flights the second 80. From what I've read 100 flights is about average.
Zeta30 is offline Find More Posts by Zeta30
Old Dec 08, 2012, 07:24 PM
Joined Aug 2010
OK, mine seems okay, I should pick one up to have on hand, how do you know its done, is it a little loss of power or does it just quit? Also, does your tail motor run warm?
Old Dec 08, 2012, 07:34 PM
Zeta30 is offline
Team Mulikow
Zeta30's Avatar
Joined May 2007
Mine was a gradual loss of power. When I put in the new motors it was very obvious that the old ones were worn out.
Old Dec 08, 2012, 11:56 PM
Joined Sep 2009
Martin
I can't really tell if there is any damage, and to be honest I am not 100% sure which fet was replaced electronics are not in my area of expertise. A which is the whole I had some one else fix it.
Discussion Blade mCP X BNF Heli... ChuckTseeker Micro Helis 15679 Today 02:40 AM
Discussion Blade mCP X Discuss anything thread A Rdnek Micro Helis 457 Jul 26, 2011 11:34 PM
Discussion The New BLADE mCP X Has Arrived... ChuckTseeker Electric Heli Talk 38 Mar 27, 2011 07:35 PM
Discussion new blade mcp X anyone know anything new. epoweredrc Atlanta Area RC 6 Mar 16, 2011 08:14 PM
Discussion Blade mCP x - strictly on topic Q and A thread jdog83 Micro Helis 58 Feb 07, 2011 02:28 PM
