Old Oct 26, 2012, 02:25 PM
dbennettya is offline
Find More Posts by dbennettya
Joined Apr 2009
Yes, if the motor has a short or locked rotor. You'd need a very good DVM that can read less than 1 Ohm. An easy test would be to connect it up to a standard 1.5V Alkaline battery and see if it runs or use a power supply with a current meter. The motor should take about 0.5A or so at no load running.
Good Luck, Don
dbennettya is offline Find More Posts by dbennettya
Old Oct 26, 2012, 03:30 PM
J_skaggs is offline
Find More Posts by J_skaggs
United States, CA
Joined Jan 2012
Good Luck, Don
Thanks Don. Very helpful.
Jim
J_skaggs is offline Find More Posts by J_skaggs
Old Oct 26, 2012, 04:11 PM
3d astronaut is offline
Find More Posts by 3d astronaut
3d astronaut's Avatar
United States, MI, Kalamazoo
Joined Sep 2011
Does anyone have a finished er9x mcpx template? I am having a heck of a time getting my mcpx to fly the way I want and the best template I have found, will not work as it is stuck in rage check mode. I have made my own and so far it has been worthless lol. Any help is appreciated!
3d astronaut is offline Find More Posts by 3d astronaut
Old Oct 27, 2012, 10:37 PM
mckolit is offline
Find More Posts by mckolit
mckolit's Avatar
Southern California
Joined Apr 2007
So after crashing my mcpx into a gnarly bush which took me almost an hour to get out of, I got smart and got away from the bushes and crashed onto my neighbor's roof I need to stick to football fields or pitch for those across the pond.
mckolit is offline Find More Posts by mckolit
Old Oct 28, 2012, 02:29 AM
eagle777 is offline
Find More Posts by eagle777
Closed Account
Joined Aug 2007
I have a couple mCPX (v1 and v2). The v2 started started kicking out 45-90 left. It's like a periodic kick every 2 seconds or so. No crashes on this to speak of.
I put on the v1 motor/boom that works well, and it is exactly the same. Any advice?
eagle777 is offline Find More Posts by eagle777
Old Oct 28, 2012, 10:52 AM
BuzzBomber is offline
Find More Posts by BuzzBomber
BuzzBomber's Avatar
Newton, NJ
Joined May 2003
Does the motor cut when it does this?
BuzzBomber is offline Find More Posts by BuzzBomber
Old Oct 28, 2012, 11:35 AM
J_skaggs is offline
United States, CA
Joined Jan 2012
I have the nano CPX, mCPX and 130X and to my surprise, though I like them all greatly. I find myself flying the mCPX the most. I find that it gives me the most versatility and overall enjoyment. I can fly it under more conditions than the other two. The nano is good for small areas but, not in wind and is the most durable. The 130X needs more space and flies in the wind. The 130X is least durable. The mCPX is a good compromise as it falls directly in the middle. I don't fly 3D just scale flying.
Old Oct 28, 2012, 06:37 PM
segroegt is offline
Find More Posts by segroegt
Canada, QC, Montreal
Joined Jan 2009
+1 . Best Regards.
segroegt is offline Find More Posts by segroegt
Old Oct 30, 2012, 11:27 PM
eagle777 is offline
Closed Account
Joined Aug 2007
Hi thanks, It looked like a harmonic vibration that happened every 0.75 seconds or so after I loosened the main blade grips.
I replaced the main gear, loosened up the blades a bit more, and tightened every screw. Now it just has a bit of tail hunting. I'll use a bit of hot glue for the battery holder/skid where it inserts into the frame and dynamically balance the blades. Any other suggestions?
Old Nov 02, 2012, 04:16 PM
BuzzBomber's Avatar
Newton, NJ
Joined May 2003
Kinda sounds like what mine was doing when the batteries were getting weak - It would shake on increases in collective, but different from the grommet/dirty servo type shake, and the tail would kick out periodically, but the LVC wouldn't kick in. Not so much a suggestion as an observation.
Old Nov 02, 2012, 10:12 PM
eagle777 is offline
Closed Account
Joined Aug 2007
I have new Hyperions and old HK Nanos, no difference between them. I did hot glue the battery holder posts into the frame, and it is much better. The post fit was very loose, and the post would slip a bit every other flight. Next is balancing the blades this weekend, and that should be it.
Old Nov 04, 2012, 01:00 PM
joker24458 is online now
Find More Posts by joker24458
Whatever goes up must go BOOM
joker24458's Avatar
United States, OH, Kent
Joined Mar 2012
I havent been on here in a long while. Ive decided that helis are just not my thing and I am settling for planes so I am selling both my MCPX V2 and my MCX2 in a couple of weeks. BTW I bought two sets of KBDD blades, extra batt, two green canopies, one green tail fin, long tail boom, barely used pair of bulleted blades, etc. Also for my MCX2 I bought glow in the dark blades and tail fin and two thunder power batts. PM me if you are interested in either one.
NOTE: These helis are not in the classfields yet so you guys have the first grabs for them.
ALSO: I am selling my DX6i with the AR6210 and satellite, you can find it here: http://www.rcgroups.com/forums/showthread.php?t=1763736
Sorry if you think that this is the worst place to post this stuff in but I need the attention so I can get the $. Thx for understanding.....even if you dont
-joker
joker24458 is online now Find More Posts by joker24458
Old Nov 13, 2012, 07:42 AM
Beancounter is offline
Find More Posts by Beancounter
Beancounter's Avatar
United States, MA, Sterling
Joined Sep 2009
I have an version 1 about 1 year old with 50 flights on it maybe. I had to send it out to get a FET replaced and I just got it back together last night and no it has another issue. The Main motor won't spool up until it gets to at least half throttle. Even in stunt mode it doesn't want to start up right away. Has anyone had this happen? It this heli now spare parts? Thanks
Beancounter is offline Find More Posts by Beancounter
Old Nov 13, 2012, 09:55 AM
J_skaggs is offline
United States, CA
Joined Jan 2012
I have had similar problem with mine. I changed the motor and that corrected it.
Old Nov 13, 2012, 11:45 AM
Joined Sep 2009
Yea I tried that along with rebinding but nothing seems to work
Discussion Blade mCP X BNF Heli... ChuckTseeker Micro Helis 15679 Jun 29, 2016 02:40 AM
Discussion Blade mCP X Discuss anything thread A Rdnek Micro Helis 457 Jul 26, 2011 11:34 PM
Discussion The New BLADE mCP X Has Arrived... ChuckTseeker Electric Heli Talk 38 Mar 27, 2011 07:35 PM
Discussion new blade mcp X anyone know anything new. epoweredrc Atlanta Area RC 6 Mar 16, 2011 08:14 PM
Discussion Blade mCP x - strictly on topic Q and A thread jdog83 Micro Helis 58 Feb 07, 2011 02:28 PM
