Old Sep 21, 2012, 04:20 PM
richord is online now
Find More Posts by richord
United States, FL, Jacksonville
Joined Jun 2008
I see people posting regarding the Pitch travel setting being at 70%.
Mine is currently set at 75% and looking at the aileron and elevator, they are at 100%. Shouldn't they all be the same or is it different than setting up a TREX 450?
richord is online now Find More Posts by richord
Old Sep 21, 2012, 05:43 PM
hydro_pyro is offline
Find More Posts by hydro_pyro
Blade mSR freak
hydro_pyro's Avatar
Irish Hills - SE Michigan
Joined Jan 2010
Mixing is on-board and automatic. Not like your 450.
Aile and elev control the overall cyclic throw, and pitch controls the overall collective travel.
You can change pitch range without adjusting anything else. You can change aile and elev throw without affecting collective pitch range.
hydro_pyro is offline Find More Posts by hydro_pyro
Old Sep 21, 2012, 06:59 PM
Joined Jun 2008
Makes sense. Thank you.
Old Sep 25, 2012, 08:26 AM
Joined Jun 2008
My KBDD main blades seem to have warped. Has anyone attempted to straighten them by putting them in hot water and pressing them under heavy books or any other methods?
Old Sep 25, 2012, 09:04 AM
jhroof is offline
Find More Posts by jhroof
Orlando, Fl
Just straighten them with your hands.
jhroof is offline Find More Posts by jhroof
Old Sep 25, 2012, 11:23 AM
Jovanx is offline
Find More Posts by Jovanx
Tossing planes into the snow
Canada, BC, Smithers
Joined Nov 2011
After working fine for several months, my MCPx is having troubles. As soon as the battery is connected, it goes to max throttle. The throttle channel on the TX is not reversed, and re-binding doesn't help. The throttle stick will activate the tail rotor, but nothing will stop the main one except unplugging the battery. Is the main board fried?
Jovanx is offline Find More Posts by Jovanx
Old Sep 25, 2012, 12:03 PM
Blade mSR freak
hydro_pyro's Avatar
Joined Jan 2010
Not the entire board, just one of the driver FET's. (the two little 3-pronged black transistors next to the main motor connector.) Those are essentially the electrical "valves" that regulate power to the motor, and they're stuck open (closed, actually.) They can be replaced by any technician with surface-mount skills.
Old Sep 25, 2012, 12:06 PM
eranrc is offline
Find More Posts by eranrc
eranrc's Avatar
Joined Feb 2010
+ 1 for sure!
eranrc is offline Find More Posts by eranrc
Old Sep 25, 2012, 12:17 PM
rynldgalano is offline
Find More Posts by rynldgalano
REYNALDO
rynldgalano's Avatar
Cyprus, Nicosia
Joined Dec 2011
unplug all your servos and plug only the motors and punch quickly the troutle. do it also to yor tail motor.
rynldgalano is offline Find More Posts by rynldgalano
Old Sep 25, 2012, 04:39 PM
Jovanx is offline
Joined Nov 2011
I might be able to do it myself if I had the correct replacement part. Is it a standard size FET or would I only be able to get it from HH? How would you know which one is the bad one?
Old Sep 25, 2012, 07:44 PM
Blade mSR freak
hydro_pyro's Avatar
Joined Jan 2010
There's two FETs near the main motor connector, and they're connected in parallel. Just replace them both. Replacements can be found on EBay if you don't know which ones to order from Mouser.
Clip the legs on the old ones, then de-solder and push away the legs one at a time. Add a few dots of liquid flux, then re-flow the legs on the new FETs one at a time.
Old Sep 26, 2012, 09:05 PM
eaglescry24 is offline
Find More Posts by eaglescry24
Flying the Spyder
eaglescry24's Avatar
United States, TX, Spring
Joined Mar 2008
Just tried a 7a brushless esc and converter all in one with a 11kpv inrunner motor. It seems like it's drawing too much power. It flew for a little while then the board blue light turned off and the chopper fell. I fealt the batt and was fairly warm. Any suggestions?
I like the stability of the stock setup. This apparently has something wrong.
eaglescry24 is offline Find More Posts by eaglescry24
Old Oct 01, 2012, 08:15 AM
Joined Jun 2008
If I do a brushless conversion on the MCPX, with this resolve tail blow outs.
I recently have been attempting flips and rolls and the tail blows out way to often. My only real complaint regarding this heli.
I have the solid extended tail boom and have tried the KBDD Main blades and tail blade.
I recently blew out a tail FET and replace the FET. I was just starting to do the flips and rolls, so I don't recall if this was an issue prior to the FET change. Is this typical with a stock setup, with the exception of an extended tail boom.
I didn't really want to go brushless, but if it will provide a fairly rock solid tail during 3D, then I may try it.
Old Oct 01, 2012, 08:24 PM
Flying the Spyder
Joined Mar 2008
I would try putting new motors in then if that doesn't work try new batteries.
Old Oct 01, 2012, 09:27 PM
johnnyrocco123 is offline
Find More Posts by johnnyrocco123
You down with EPP?
johnnyrocco123's Avatar
Houston, Tx
Joined May 2009
I was thinking about going brushless to solve the blow out problem as well as more power.
It's a tough one.... Brushless or 130x???
johnnyrocco123 is offline Find More Posts by johnnyrocco123
Discussion Blade mCP X BNF Heli... ChuckTseeker Micro Helis 15686 Sep 07, 2016 02:54 AM
Discussion Blade mCP X Discuss anything thread A Rdnek Micro Helis 457 Jul 26, 2011 11:34 PM
Discussion The New BLADE mCP X Has Arrived... ChuckTseeker Electric Heli Talk 38 Mar 27, 2011 07:35 PM
Discussion new blade mcp X anyone know anything new. epoweredrc Atlanta Area RC 6 Mar 16, 2011 08:14 PM
Discussion Blade mCP x - strictly on topic Q and A thread jdog83 Micro Helis 58 Feb 07, 2011 02:28 PM
