Old Sep 17, 2012, 03:39 PM
Bunch of RCs,can't fly 1/2
United States, CA, Long Beach
Joined Aug 2011
Originally Posted by johnnyrocco123 View Post
My MCPX barely has enough power to get off the ground. It does not respond to idle up anymore. Is there something else I should check before assuming the motor is bad?
checked
pitch on blades looks good
main gear on pinion
main shaft not moving
batteries are good
Try putting it on throttle hold, and moving the throttle from 0-100% to see if the servos are moving enough. Try changing blades, and try taking the main gear off, then throttling from 0-100 to hear if the motor seems to run up to 100. Good luck
alphanate is offline Find More Posts by alphanate
Old Sep 17, 2012, 06:02 PM
eranrc's Avatar
Joined Feb 2010
checked
main gear on pinion
batteries are good
How about changing the main motor?
eranrc is offline Find More Posts by eranrc
Old Sep 17, 2012, 06:03 PM
eranrc's Avatar
Joined Feb 2010
Originally Posted by joker24458 View Post
Yes it does help
I thought that I was supposed to do something on the transmitter thanks.
-joker
Sweet!
Old Sep 17, 2012, 06:25 PM
Team Mulikow
Zeta30's Avatar
Joined May 2007
checked
main gear on pinion
batteries are good
Is this after a crash? If so double check the main gear, (I realize you have already checked it but double checking never hurts). A lot of the times the main gear will still be on the main shaft but will slip down. Even if it slips by a fraction of an inch the heli will act like you have to push the throttle stick all the way forward to get it off the ground. There should only be about 1/16" gap between the main gear and the bearing. Conversely if you pushed the main gear up and pressed it too tight on the bearing it will act as if you have no power and won't lift off the ground.
You also mention that it does not respond to idle up any more. Can you be more specific? Does the motor stop when you go in to idle up, or what exactly is happening?
Zeta30 is offline Find More Posts by Zeta30
Old Sep 17, 2012, 07:09 PM
United States, MA, Rutland
Joined Oct 2011
checked
main gear on pinion
batteries are good
Any radio settings that can be upped?
ScottGridley is offline Find More Posts by ScottGridley
Old Sep 17, 2012, 07:26 PM
Heli Mad
stevebarrow's Avatar
Australia, VIC, Elsternwick
Joined Feb 2002
Check that the flat on the main gear is lined up as well.
stevebarrow is offline Find More Posts by stevebarrow
Old Sep 17, 2012, 07:27 PM
Heli Mad
Joined Feb 2002
Weird that it doesn't respond to idle up have you tried rebinding?
Old Sep 17, 2012, 08:24 PM
You down with EPP?
johnnyrocco123's Avatar
Houston, Tx
Joined May 2009
When I flip idle up, nothing happens, not pitch change, the motorr keeps going as if nothing happened. It takes full throttle to keep the heli a few inches off the ground. The main gear is good. I guess I will look over a few more things ans then assume it's the motor.
No wreck involved. One day it worked, and then it didn't.
johnnyrocco123 is offline Find More Posts by johnnyrocco123
Old Sep 18, 2012, 12:23 AM
Just fly
evltoy's Avatar
Australia, VIC, Glen Waverley
Joined Jan 2011
what battery are you running and how many cycles have you done on it? Also how many mins do you fly for and what it the end voltage when you finish your flight?
evltoy is offline Find More Posts by evltoy
Old Sep 18, 2012, 06:33 AM
Team Mulikow
Zeta30's Avatar
Joined May 2007
It could be a few different things then,
1. Motor going out, (if you get 100 flights out of one your doing good).
2. Batteries going bad. (These small batteries only seem to last about 50 flights if you're lucky), some of the cheaper batteries only last 15 -20 flights.
3. Bad 3 in 1 board.
Old Sep 18, 2012, 06:57 AM
You down with EPP?
Houston, Tx
Joined May 2009
I bought 4 brand new Spyder 250mah batteries. So they are good.
I have 105 flights on thre heli, so it very well could be the motor. I just don't want to get a motor and find that it was something else.
I already did that with the batteries
If it is the 3 in 1 board, I wouldn't know. I think I will just try a new motor.
Thanks for the input guys.
Old Sep 19, 2012, 05:42 PM
United States, FL, Jacksonville
Joined Jun 2008
Is there any difference between the MCPX V1 and MCPX V2 main board?
richord is offline Find More Posts by richord
Old Sep 19, 2012, 05:53 PM
Heli Mad
Joined Feb 2002
Yes, there are improved settings on the V2 board, especially for the tail.
Old Sep 19, 2012, 05:55 PM
Thread Crapper
JohnVH's Avatar
Lynden, WA
Joined Nov 2000
when mine lost power it was the main motor that was bad, and it didnt have very many flights on it, but it goes ok now with a new motor. They are so cheap try it!
JohnVH is offline Find More Posts by JohnVH
Old Sep 19, 2012, 06:52 PM
Joined Jun 2008
I burnt my tail fet when my tail wires shorted.
The symptom was smoke and the tail motor just kept on running.
I replaced the fet and now I have rudder in only one direction and not the other. The tail stops when I input left rudder, but right rudder accelerated the tail in the correct direction.
Is there a 2nd tail fet? If so, which one is it?
If not, any other thoughts?
Discussion Blade mCP X BNF Heli... ChuckTseeker Micro Helis 15126 Jun 16, 2013 02:00 PM
Discussion Blade mCP X Discuss anything thread A Rdnek Micro Helis 457 Jul 26, 2011 11:34 PM
Discussion The New BLADE mCP X Has Arrived... ChuckTseeker Electric Heli Talk 38 Mar 27, 2011 07:35 PM
Discussion new blade mcp X anyone know anything new. epoweredrc Atlanta Area RC 6 Mar 16, 2011 08:14 PM
Discussion Blade mCP x - strictly on topic Q and A thread jdog83 Micro Helis 58 Feb 07, 2011 02:28 PM
