Old Aug 09, 2012, 11:32 AM
tonyastro is offline
Find More Posts by tonyastro
3D VFX Artist
tonyastro's Avatar
USA, CA, Monrovia
I was thinking of soldering the wires at an angle where I could lay them flat on the board then somehow glue them to the board. Every time I plug/remove the lipos it tugs on the solder joint.
tonyastro is offline Find More Posts by tonyastro
Old Aug 09, 2012, 12:19 PM
daveapplemotor is offline
Find More Posts by daveapplemotor
Activist
Joined Jun 2009
Originally Posted by tonyastro View Post
Thanks Graham, Buzz. What about you? What do you guys do to prevent the battery wires from coming off?
Tin your pins with a little solder. It does two things:
It makes a better connection & It won;t fall out.
daveapplemotor is offline Find More Posts by daveapplemotor
Old Aug 09, 2012, 04:06 PM
f.a.r.m.e.r is offline
Find More Posts by f.a.r.m.e.r
Farmer
f.a.r.m.e.r's Avatar
United States, CA
Joined Oct 2011
Is it ok to hot glue the 3in1 board? My battery wires keep coming off no matter how good my solder is. I'm thinking of hot gluing the wires to the bottom of the board so the solder can't come loose.
your battery wires should not come off the board at the solder joint.. you must of over heated the pad..
the wires break behind the solder joint after a while from bending back and forth.. I would send it to someone who can fix the pad or get longer wire and solder to the back of the board, can you provide a upclose picture??
f.a.r.m.e.r is offline Find More Posts by f.a.r.m.e.r
Old Aug 10, 2012, 12:06 PM
DMala is offline
Find More Posts by DMala
DMala's Avatar
New Jersey
Joined Sep 2009
I took again my McpX V1 (stock except for the 1cm longer solid CF tail boom) + the trusted JR9303 with me on vacation (to Italy) and I did some good practice to extend the duration of my flips from a fraction of a second to a few seconds long now. I am also practicing (safe) altitude control. I am very happy with this little heli. I need more sim time to improve the control of the asset and of direction, and I feel the McpX is still going to be a good choice to improve further. Yes maybe 1/2 of the crashes are due to the tail blowing out (I still have the V1 tail prop), but this happens typically when I am trying to recover from a mistake, it's not entirely the heli's fault..... so from the training point of view to have little margin for error is not actually bad.
Anyway after 160+ cumulative flights I finally busted the original landing gear (the battery holder gave up) and broke both front canopy pins of the frame. The main motor is original (and so is the head except for some links) and the tail motor must have about 60 flights. Time to do some reconstructive surgery I guess....
If I decide to replace the frame (as opposite to connecting a carbon rod section to the frame to replace the broken front pins), what is the best sequence to reinstall the servos and the main motor? Motor first, then servos, then board I guess? Suggestions are welcome.
Even if still usable, I am going to replace the original motor (it seems to still have enough power to handle inverted hovering and altitude adjustment) since I doubt it will last much longer anyway. I also got the V2 tail props now and I will install one on the last v1 spare tail motor I have left.
Is the current boom longer than the original V1? Even if it is, I am thinking that I better keep using the solid carbon fiber boom I currently have, since an hollow boom would not last long with the type of crashes I am having now.
DMala is offline Find More Posts by DMala
Old Aug 10, 2012, 01:31 PM
RCMattG is offline
Find More Posts by RCMattG
Joined Mar 2011
http://www.rcgroups.com/forums/showthread.php?t=1709160 Selling stuff here!
RCMattG is offline Find More Posts by RCMattG
Old Aug 11, 2012, 06:43 AM
steveap1 is offline
Find More Posts by steveap1
United States, AL, Morris
Joined Mar 2012
Is the Xtreme Carbon Chassis any good?
http://www.wowhobbies.com/xtm-mcpx01...hassisset.aspx
I'm not doing anthng extreme, I'm just tired of breaking canopy mounts. Anyone using this?
steveap1 is offline Find More Posts by steveap1
Old Aug 11, 2012, 08:03 PM
DMala is offline
DMala's Avatar
New Jersey
Joined Sep 2009
I have no information on this frame but from the look I would guess that it is a bit heavy, especially for the brushed motor.
I have been having a similar problem with broken canopy posts and here is how I am handling it:
- it seems to me that the canopy posts break because when the nose of the canopy hits the ground, force is transferred onto the posts. I do not know if it is an original idea, but I have cut away the nose of the canopy and superglued a strip of foam that has been working quite well as shock absorber, not only for the posts but also for the board. Added bonus is that the McpX is now very quiet, with a pleasant buzzzing sound. Note that the inside of the foam strip needs to be notched for the battery.
- just this morning I tied with sewing thread a carbon rod to the frame, which is nearly in the same position as the original canopy posts. Run the thread between the frame and the motor then towards the front, down around the post and back again a few times. I was about to CA it but for now I am going to see if leaving a bit of free play actually helps to absorb shocks. The canopy lost the grommets long ago and to replace them I positioned on the inside a square of electrician's tape, and I punctured with an awl. The tape "grips" the post quite well. I have not yet crashed so only time will tell how good it holds.
In terms of maintenance this morning I decided to just replace the tail motor/tail prop, file down the dents on the leading edge of the main blades, and re-balance them. The main motor is still good and I decided to do as little work and as much flying as possible ....
I made several flips and the heli is running nicely again, not bad for such a veteran.
Old Aug 11, 2012, 10:53 PM
GBR2 is offline
Find More Posts by GBR2
Stress Be Gone
GBR2's Avatar
Snohomish, WA
Joined May 2000
Try these skids from Airtime RC products. You can also search YouTube for some videos of them being assembled and trying to be smashed.
http://www.ebay.com/itm/Blade-MCPX-L...item2c65df52e8
GBR2 is offline Find More Posts by GBR2
Old Aug 11, 2012, 11:40 PM
Torch8 is offline
Find More Posts by Torch8
Torch8's Avatar
NYC
Joined Aug 2010
Loops and Rolls
Stock Mcpx v2 good enough to perform basic Loops and Rolls? I'm not advance 3D, but like to add looping and rolls skills. I flied V120d02s and has started doing loops but rolls are difficult for me and getting expensive o replacing servos, rather has linear servos.
Torch8 is offline Find More Posts by Torch8
Old Aug 12, 2012, 12:37 AM
Farmer
United States, CA
Joined Oct 2011
If you are still crashing enough to break stock canopy mounts, you will
destroy this frame within a few crashes.. first thing to go will be the tail boom mount lol
This Heli Is Going Up For Sale.. Figured I'd post it here first..
Mcpx V2 Testing Black Dragon BL Motor With BLHeli (2 min 18 sec)
$200.00 obo
Old Aug 12, 2012, 07:22 PM
steveap1 is offline
Joined Mar 2012
That's an interesting mod. I've seen a couple others using wire wrapped aroung the frame and protruding in such a way the canopy can mount to it. Someone else said building up the area where the mounts attach to the frame with JB Weld. I just thought for $30 bucks the wow CF frame might solve the problem quickly.
Funny, I've had very little problem with the skids.
I've seen it done, but I'm not quite ready for it..
http://www.youtube.com/watch?v=RvWwH...e_gdata_player
$200.00 obo
I'm not crashing all that much now, but when I do, it seems the mounts are always the first to go. Nice looking heli.If I didn't have my eye on the 130x, I'd seriously consider it.
Old Aug 12, 2012, 07:41 PM
Farmer
United States, CA
Joined Oct 2011
Blade mCpx V2 Stock 3D Flight With Walkera 6mm Tail motor (3 min 1 sec)
yeah I'm 100% sure it can
you will love it
Old Aug 12, 2012, 07:49 PM
Farmer
United States, CA
Joined Oct 2011
http://astroid-designs.myshopify.com...px-carbon-cage
this carbon cage will solve your problem..
but that xtreme frame might be a good idea aslong as your not bombing the heli down hard on concrete lol only reason why i like the aftermarket frames is that you can replace the posts for dirt cheap or any part on it dirt cheap rather then having to strip the heli and replacing the whole stock frame all the time..
they also have aluminum upgrades like boom suport for it..
now that i think about it id say go for it lol
Old Aug 14, 2012, 09:54 PM
mmurray70 is offline
Find More Posts by mmurray70
Joined Mar 2007
I had the same trouble but sort of though alot of it was still my fault. After going brushless I can mess up and bang the sticks around where ever i want to recover and most times now I do recover it. Tail never blows out. Its great!
Hey everyone, I figured out my 90 random tail movements that I posted about a few weeks ago. I was running a 120 tail, but switched back to an extended stock tail with kbdd blade and problem dissappeared.
This is the first time I've had my mcpx flying properly since I bought it. Great little heli with the C05 brushless. really happy with it now.
mmurray70 is offline Find More Posts by mmurray70
Old Aug 16, 2012, 07:17 PM
3D VFX Artist
tonyastro's Avatar
USA, CA, Monrovia
I do. After soldering it looks very solid but after a few flights it just comes lose.
Yes the break is not behind the solder joint but on the board itself. I managed to solder it flat to the board and keep it from moving using tape. Hope this works
Discussion Blade mCP X BNF Heli... ChuckTseeker Micro Helis 15676 Aug 30, 2015 11:28 PM
Discussion Blade mCP X Discuss anything thread A Rdnek Micro Helis 457 Jul 26, 2011 11:34 PM
Discussion The New BLADE mCP X Has Arrived... ChuckTseeker Electric Heli Talk 38 Mar 27, 2011 07:35 PM
Discussion new blade mcp X anyone know anything new. epoweredrc Atlanta Area RC 6 Mar 16, 2011 08:14 PM
Discussion Blade mCP x - strictly on topic Q and A thread jdog83 Micro Helis 58 Feb 07, 2011 02:28 PM
