Old Aug 06, 2012, 09:37 AM
Varekai is offline
Find More Posts by Varekai
Sir
Varekai's Avatar
United States, FL, Clearwater
Joined Jul 2010
If they did a Commanche, I'd be all over that.
Varekai is offline Find More Posts by Varekai
Old Aug 06, 2012, 12:17 PM
tonyastro is offline
Find More Posts by tonyastro
3D VFX Artist
tonyastro's Avatar
USA, CA, Monrovia
I figured this would be faster than searching the whole thread. What is the best lipo for a BL mcpx? The HK nanotechs don't seem to last very long.
tonyastro is offline Find More Posts by tonyastro
Old Aug 06, 2012, 01:09 PM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
How far(deep) are you discharging them. No LiPoly will give max. cycle life if you fly to below 3.7 per cell often. Increased life comes from not using more than 80% of thier capacity and not leaving them fully charged all of the time just in case you get a chance to fly on the spur of the moment.
I have a Nano 300 with 89 flights on it and it is still going strong. My son has over a hundred on one and it is still one of his strongest Lipolys. We set timer for 3 minutes and cell is right at 3.7 a few minures after flight.
Most agree that the Hyperions are the best but they are not exactly inexpensive and others swear by the Thunder Powers but they are the most expensive ones available.
Charles
Old Aug 06, 2012, 01:28 PM
3D VFX Artist
tonyastro's Avatar
USA, CA, Monrovia
Charles
I always store at 3.8V immediately after flying but I fly for 4 mins. Can you give a link to the Hyperions? Thanks.
Old Aug 06, 2012, 02:45 PM
Southern Pride
One good source is rclipos.com or just do a Goggle. One of the members her RC Babble sells an assortment of Hyperions and some Thunder Powers that are stripped of heatshrink to reduce weight and fitted with correct connectors.
The stock 250 mAh Hyperions are plug and play with same housing / coonector as Blade uses.
johnnyrocco123 is offline
Find More Posts by johnnyrocco123
You down with EPP?
johnnyrocco123's Avatar
Houston, Tx
Joined May 2009
Hyperions
http://www.rcgroups.com/forums/showthread.php?t=1705873
johnnyrocco123 is offline Find More Posts by johnnyrocco123
Old Aug 06, 2012, 03:21 PM
3D VFX Artist
tonyastro's Avatar
USA, CA, Monrovia
Thanks guys!
Old Aug 07, 2012, 12:14 AM
jlk69 is offline
Find More Posts by jlk69
RC Aircraft Junkie
jlk69's Avatar
USA, CA, Chula Vista
Joined Sep 2004
Originally Posted by boredom.is.me View Post
If you strolled over to my thread, you would see that...
I did and that's how I found the link. I just wanted to make it a little easier for others to find the link. Thank you very much for sharing.
jlk69 is offline Find More Posts by jlk69
Old Aug 07, 2012, 08:56 AM
cale10 is offline
Find More Posts by cale10
3dizzle 4 lyfe
cale10's Avatar
United States, OH
Joined Jul 2011
http://www.hobbyking.com/hobbyking/s...ear_Servo.html
http://www.hobbyking.com/hobbyking/s...washplate.html
http://www.hobbyking.com/hobbyking/s..._Grommets.html
http://www.hobbyking.com/hobbyking/s...2pcs_bag_.html
thers more too. just some things we might use on our flying turds!
cale10 is offline Find More Posts by cale10
Old Aug 09, 2012, 02:27 AM
3D VFX Artist
tonyastro's Avatar
USA, CA, Monrovia
Is it ok to hot glue the 3in1 board? My battery wires keep coming off no matter how good my solder is. I'm thinking of hot gluing the wires to the bottom of the board so the solder can't come loose.
Old Aug 09, 2012, 02:45 AM
GrahamWilson is offline
Find More Posts by GrahamWilson
Beating air into submission!
GrahamWilson's Avatar
Australia, NSW, Vaucluse
Joined Aug 2011
Try a dab of silicon sealant on the wires. This will take the load off the joints but is reasonably easy to remove.
GrahamWilson is offline Find More Posts by GrahamWilson
Old Aug 09, 2012, 07:21 AM
Wade1 is offline
Find More Posts by Wade1
Australia
Joined Jul 2008
do the walkera 120 size blades fit a mcpx ?
Wade1 is offline Find More Posts by Wade1
Old Aug 09, 2012, 10:58 AM
BuzzBomber is offline
Find More Posts by BuzzBomber
BuzzBomber's Avatar
Newton, NJ
Joined May 2003
If you do this, make sure to use a sealant that is electronics-safe. Many types of regular RTV-type silicone are corrosive to electronics, so you don't want to use them around the board due to the acidic curing process.
BuzzBomber is offline Find More Posts by BuzzBomber
Old Aug 09, 2012, 11:19 AM
3D VFX Artist
tonyastro's Avatar
USA, CA, Monrovia
Thanks Graham, Buzz. What about you? What do you guys do to prevent the battery wires from coming off?
Old Aug 09, 2012, 11:25 AM
BuzzBomber's Avatar
Newton, NJ
Joined May 2003
Thankfully, it hasn't been an issue for me (knock on wood). Mine still has the little bit of sealant at the solder point from the factory intact. Perhaps the routing of the wires from the board to the battery plays a role? I let mine sit loose from the board so the wires don't bend too much, then route the lead outside the front skid support and inside the rear support to the battery connector. It looks like it would contact the servo gears this way, but I haven't had any problem in a couple hundred flights.
Discussion Blade mCP X BNF Heli... ChuckTseeker Micro Helis 15679 Today 02:40 AM
Discussion Blade mCP X Discuss anything thread A Rdnek Micro Helis 457 Jul 26, 2011 11:34 PM
Discussion The New BLADE mCP X Has Arrived... ChuckTseeker Electric Heli Talk 38 Mar 27, 2011 07:35 PM
Discussion new blade mcp X anyone know anything new. epoweredrc Atlanta Area RC 6 Mar 16, 2011 08:14 PM
Discussion Blade mCP x - strictly on topic Q and A thread jdog83 Micro Helis 58 Feb 07, 2011 02:28 PM
